Topic: Mikrotik + Arduino + LCD (Read 9598 times) previous topic - next topic
hugo007
May 09, 2013, 10:44 pm Last Edit: May 09, 2013, 10:47 pm by HugoPT Reason: 1
Hi everyone
I want to share my recent weekend Arduino Project where I connect the powerfull Mikrotik RouterBoard to the Arduino using the USB native port on Mikrotik. My idea was enable the LCD module in the Mikrotik and them received  data in Arduino and pass it to an LCD HD44780 using an I2C Bus.
Here is the code I used to accomplish the task.
Code: [Select]
04-05-2012
Writen by Hugo Santos
e-mail: hugo.santos@i9box.net
For more info please visit
http://devforum.i9box.net/index.php?topic=4.0
Not translated yet, maybe next week :)
#include <SoftwareSerial.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x20,20,4);  // set the LCD address to 0x20 for a 16 chars and 2 line display
SoftwareSerial mikrotik(10, 11); // RX, TX
bool validDataFound = false;
char buffer[100];
 mikrotik.begin(9600);
 lcd.init();
 lcd.backlight();
 writeLcd("Reading Mikrotik");
 storeData();
 writeLcd(buffer);
void writeLcd(char * name)
 lcd.clear();
 lcd.setCursor(1,0);//Collum 1, Row 0
 lcd.print("Arduino + Mikrotik");
 lcd.setCursor(3,1);//Collum 3, Row 1
 lcd.print("Mikrotik name:");
 lcd.setCursor(3,2);//Collum 3, Row 2
 lcd.print(name);
void findMarker()
 byte tester;
 while(1)
  if(mikrotik.available()>0)
       tester = mikrotik.read();
       Serial.write(tester);
  if(tester == 0x3A)break; //Means de marker : has been found
void storeData()
uint8_t i =0;
byte temp;
buffer[0] = '\0';
findMarker();
while(1)
    temp = mikrotik.read();
    if(temp != 0x20 )
      //Insert the byte on the char array
      validDataFound = true;
      buffer[i++] = temp;
      buffer[i] = '\0';
    if(validDataFound == true && temp == 0x20)
Serial.println(buffer);
Here is the final result.Nothing particular remarkable just a raining weekend in Portugal  :smiley-mr-green: :smiley-mr-green: :smiley-mr-green:
Debian,Mint,Ubuntu
Arduino Mega 2560
Arduino Nano
Arduino Duemilanove
MAC OS Montain Lion
Raspberry PI Model B
