Topic: utouch ssd1963 5 inch problem (Read 21880 times) previous topic - next topic
nonamejohn
so ive got the ssd1963 5 inch tft from itead on the itdb02 v2 on an arduino mega 2560
the problem is when i use the quickdraw eksamble and draw on the screen and try to draw a line all around the all around the screen it only draws from about (0,0) to (550,240) about that cordinate do eny one now how to change it so i can draw all over my tft the same problem is in the button eksample
HazardsMind
#1
May 10, 2013, 02:33 pm Last Edit: May 10, 2013, 02:36 pm by HazardsMind Reason: 1
Does your library allow you to see the X and Y coordinates of where you touch on the screen, the RAW data? Im assuming it does. But the question after that would be, are those coordinates mapped to your screen layout? Meaning if you make a box on screen at say (300, 200), and you touch that box, does the touch coords match?
If they do not, then you will need to map them by hand, or use a callibration sketch.
What I had to do was touch the edges of where the screen, (not the touch pad itself) stops for both the X and again for the Y. Now when I touch my screen, I get the correct numbers.
Once you are able to get the touch coords to match the screen coords, then you can simply use a draw pixel function.
Example:
  X = getXcoord(); // the raw data for X
  Y = getYcoord(); // the raw data for Y
  tx = map( X, 0, 3550, 0, 239); // the screen data for X
  ty = map( Y, 0, 4860, 0, 319); // the screen data for Y
  myGLCD.drawPixel(tx, ty); // draw pixel at tx, ty
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
nonamejohn
If i press at right bottom corner The dot is about in The middel og The screen
HazardsMind
Ok, so then your touch pad is not mapped to your screen.
My GitHub:
nonamejohn
Year but I dont now how to map it
HazardsMind
Look at the example I gave you.
Do you have any sketches that came with the library?
My GitHub:
nonamejohn
ive got this sketch
Quote
// UTouch_QuickDraw (C)2010-2012 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a quick demo of how to use the library.
// This program requires the UTFT library.
// It is assumed that the display module is connected to an
// appropriate shield or that you know how to change the pin
// numbers in the setup.
#include <UTFT.h>
#include <UTouch.h>
// Uncomment the next two lines for the Arduino 2009/UNO
//UTFT        myGLCD(ITDB24D,19,18,17,16);   // Remember to change the model parameter to suit your display module!
//UTouch      myTouch(15,10,14,9,8);
// Uncomment the next two lines for the Arduino Mega
UTFT        myGLCD(SSD1963_800, 38,39,40,41);   // Remember to change the model parameter to suit your display module!
UTouch      myTouch(6,5,4,3,2);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.InitTouch();
  myTouch.setPrecision(PREC_MEDIUM);
  long x, y;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
    x = myTouch.getX();
    y = myTouch.getY();
    if ((x!=-1) and (y!=-1))
      myGLCD.drawPixel (x, y);
nonamejohn
and this for calibration
Quote
// UTouch_Calibration (C)2012 Henning Karlsen
#include <UTFT.h>
#include <UTouch.h>
// Define the orientation of the touch screen. Further
// information can be found in the instructions.
#define TOUCH_ORIENTATION  PORTRAIT
// Declare which fonts we will be using
extern uint8_t SmallFont[];
UTFT        myGLCD(SSD1963_800,38,39,40,41);   // Remember to change the model parameter to suit your display module!
// DO NOT EDIT ANYTHING BELOW THIS LINE
uint32_t cx, cy;
uint32_t rx[10], ry[10];
uint32_t clx, crx, cty, cby;
float px, py;
int dispx, dispy, text_y_center;
uint32_t calx, caly, cals;
char buf[13];
 myGLCD.InitLCD();
 myGLCD.clrScr();
 myGLCD.setFont(SmallFont);
 myTouch.InitTouch(TOUCH_ORIENTATION);
 myTouch.setPrecision(PREC_LOW);
 dispx=myGLCD.getDisplayXSize();
 dispy=myGLCD.getDisplayYSize();
 text_y_center=(dispy/2)-6;
void drawCrossHair(int x, int y)
 myGLCD.drawRect(x-10, y-10, x+10, y+10);
 myGLCD.drawLine(x-5, y, x+5, y);
 myGLCD.drawLine(x, y-5, x, y+5);
void readCoordinates()
 int iter = 2000;
 int cnt = 0;
 uint32_t tx=0;
 uint32_t ty=0;
 boolean OK = false;
 while (OK == false)
   myGLCD.setColor(255, 255, 255);
   myGLCD.print("*  PRESS  *", CENTER, text_y_center);
   while (myTouch.dataAvailable() == false) {}
   myGLCD.print("*  HOLD!  *", CENTER, text_y_center);
   while ((myTouch.dataAvailable() == true) && (cnt<iter))
     myTouch.read();
     tx = myTouch.TP_X;
     ty = myTouch.TP_Y;
     cnt++;
   if (cnt>=iter)
     OK = true;
     tx = 0;
     ty = 0;
     cnt = 0;
 cx = tx / iter;
 cy = ty / iter;
void calibrate(int x, int y, int i)
 drawCrossHair(x,y);
 myGLCD.setBackColor(255, 0, 0);
 readCoordinates();
 myGLCD.print("* RELEASE *", CENTER, text_y_center);
 myGLCD.setColor(80, 80, 80);
 drawCrossHair(x,y);
 rx=cx;
 ry=cy;
   myTouch.read();
void waitForTouch()
   myTouch.read();
   myTouch.read();
void toHex(uint32_t num)
 buf[0] = '0';
 buf[1] = 'x';
 buf[10] = 'U';
 buf[11] = 'L';
 buf[12] = 0;
 for (int zz=9; zz>1; zz--)
   if ((num & 0xF) > 9)
     buf[zz] = (num & 0xF) + 55;
     buf[zz] = (num & 0xF) + 48;
   num=num>>4;
void startup()
 myGLCD.setColor(255, 0, 0);
 myGLCD.fillRect(0, 0, dispx-1, 13);
 myGLCD.drawLine(0, 14, dispx-1, 14);
 myGLCD.print("UTouch Calibration", CENTER, 1);
 myGLCD.setBackColor(0, 0, 0);
 if (dispx==220)
   myGLCD.print("Use a stylus or something", LEFT, 30);
   myGLCD.print("similar to touch as close", LEFT, 42);
   myGLCD.print("to the center of the", LEFT, 54);
   myGLCD.print("highlighted crosshair as", LEFT, 66);
   myGLCD.print("possible. Keep as still as", LEFT, 78);
   myGLCD.print("possible and keep holding", LEFT, 90);
   myGLCD.print("until the highlight is", LEFT, 102);
   myGLCD.print("removed. Repeat for all", LEFT, 114);
   myGLCD.print("crosshairs in sequence.", LEFT, 126);
   myGLCD.print("Touch screen to continue", CENTER, 162);
   myGLCD.print("INSTRUCTIONS", CENTER, 30);
   myGLCD.print("Use a stylus or something similar to", LEFT, 50);
   myGLCD.print("touch as close to the center of the", LEFT, 62);
   myGLCD.print("highlighted crosshair as possible. Keep", LEFT, 74);
   myGLCD.print("as still as possible and keep holding", LEFT, 86);
   myGLCD.print("until the highlight is removed. Repeat", LEFT, 98);
   myGLCD.print("for all crosshairs in sequence.", LEFT, 110);
   myGLCD.print("Further instructions will be displayed", LEFT, 134);
   myGLCD.print("when the calibration is complete.", LEFT, 146);
   myGLCD.print("Do NOT use your finger as a calibration", LEFT, 170);
   myGLCD.print("stylus or the result WILL BE imprecise.", LEFT, 182);
   myGLCD.print("Touch screen to continue", CENTER, 226);
 waitForTouch();
 myGLCD.clrScr();
void done()
 myGLCD.clrScr();
 if (dispx==220)
   myGLCD.print("To use the new calibration", LEFT, 30);
   myGLCD.print("settings you must edit the", LEFT, 42);
   myGLCD.setColor(160, 160, 255);
   myGLCD.print("UTouchCD.h", LEFT, 54);
   myGLCD.print("file and change", 88, 54);
   myGLCD.print("the following values. The", LEFT, 66);
   myGLCD.print("values are located right", LEFT, 78);
   myGLCD.print("below the opening comment.", LEFT, 90);
   myGLCD.print("CAL_X", LEFT, 110);
   myGLCD.print("CAL_Y", LEFT, 122);
   myGLCD.print("CAL_S", LEFT, 134);
   toHex(calx);
   myGLCD.print(buf, 75, 110);
   toHex(caly);
   myGLCD.print(buf, 75, 122);
   toHex(cals);
   myGLCD.print(buf, 75, 134);
   myGLCD.print("CALIBRATION COMPLETE", CENTER, 30);
   myGLCD.print("To use the new calibration", LEFT, 50);
   myGLCD.print("settings you must edit the", LEFT, 62);
   myGLCD.print("UTouchCD.h", LEFT, 74);
   myGLCD.print("file and change", 88, 74);
   myGLCD.print("the following values.", LEFT, 86);
   myGLCD.print("The values are located right", LEFT, 98);
   myGLCD.print("below the opening comment in", LEFT, 110);
   myGLCD.print("the file.", LEFT, 122);
   myGLCD.print("CAL_X", LEFT, 150);
   myGLCD.print("CAL_Y", LEFT, 162);
   myGLCD.print("CAL_S", LEFT, 174);
   toHex(calx);
   myGLCD.print(buf, 75, 150);
   toHex(caly);
   myGLCD.print(buf, 75, 162);
   toHex(cals);
   myGLCD.print(buf, 75, 174);
 startup();
 drawCrossHair(dispx-11, 10);
 drawCrossHair(dispx/2, 10);
 drawCrossHair(10, 10);
 drawCrossHair(dispx-11, dispy/2);
 drawCrossHair(10, dispy/2);
 drawCrossHair(dispx-11, dispy-11);
 drawCrossHair(dispx/2, dispy-11);
 drawCrossHair(10, dispy-11);
 myGLCD.print("***********", CENTER, text_y_center-12);
 myGLCD.print("***********", CENTER, text_y_center+12);
 calibrate(10, 10, 0);
 calibrate(10, dispy/2, 1);
 calibrate(10, dispy-11, 2);
 calibrate(dispx/2, 10, 3);
 calibrate(dispx/2, dispy-11, 4);
 calibrate(dispx-11, 10, 5);
 calibrate(dispx-11, dispy/2, 6);
 calibrate(dispx-11, dispy-11, 7);
 if (TOUCH_ORIENTATION == LANDSCAPE)
   cals=(long(dispx-1)<<12)+(dispy-1);
   cals=(long(dispy-1)<<12)+(dispx-1);
 if (TOUCH_ORIENTATION == PORTRAIT)
   px = abs(((float(rx[2]+rx[4]+rx[7])/3)-(float(rx[0]+rx[3]+rx[5])/3))/(dispy-20));  // PORTRAIT
   px = abs(((float(rx[5]+rx[6]+rx[7])/3)-(float(rx[0]+rx[1]+rx[2])/3))/(dispy-20));  // LANDSCAPE
   clx = (((rx[0]+rx[3]+rx[5])/3));  // PORTRAIT
   crx = (((rx[2]+rx[4]+rx[7])/3));  // PORTRAIT
   clx = (((rx[0]+rx[1]+rx[2])/3));  // LANDSCAPE
   crx = (((rx[5]+rx[6]+rx[7])/3));  // LANDSCAPE
 if (clx<crx)
   clx = clx - (px*10);
   crx = crx + (px*10);
   clx = clx + (px*10);
   crx = crx - (px*10);
   py = abs(((float(ry[5]+ry[6]+ry[7])/3)-(float(ry[0]+ry[1]+ry[2])/3))/(dispx-20));  // PORTRAIT
   py = abs(((float(ry[0]+ry[3]+ry[5])/3)-(float(ry[2]+ry[4]+ry[7])/3))/(dispx-20));  // LANDSCAPE
   cty = (((ry[5]+ry[6]+ry[7])/3));  // PORTRAIT
   cby = (((ry[0]+ry[1]+ry[2])/3));  // PORTRAIT
   cty = (((ry[0]+ry[3]+ry[5])/3));  // LANDSCAPE
   cby = (((ry[2]+ry[4]+ry[7])/3));  // LANDSCAPE
 if (cty<cby)
   cty = cty - (py*10);
   cby = cby + (py*10);
   cty = cty + (py*10);
   cby = cby - (py*10);
 calx = (long(clx)<<14) + long(crx);
 caly = (long(cty)<<14) + long(cby);
   cals = cals + (1L<<31);
 done();
 while(true) {}
HazardsMind
Ok perfect, this here is your raw data.
myTouch.read();
x = myTouch.getX(); // raw x
y = myTouch.getY(); // raw y
Now what you need to do is see what the x coords are when you touch the edges of the screen and the same for the y coord.
________________
|                        | 0
|                        |  Y
|_______________| 5000?
0            X       3550?
My GitHub:
nonamejohn
how do i se what the x coords are?
is there a place i can se them?
(im am a noob in this)
guix
Maybe orientation problem, try change
Code: [Select]
to
Code: [Select]
#define TOUCH_ORIENTATION  LANDSCAPE
HazardsMind
#11
May 10, 2013, 10:11 pm Last Edit: May 11, 2013, 02:02 am by HazardsMind Reason: 1
UPDATED
For that you will need to make your own display.
I need to see your .cpp and .h files to know exactly what I can write. My library might not be the same as yours.
Also, your code needs to be put into [ code ] ....... [/ code ] tags " # ", NOT quote tags.
Code: [Select]
#include <UTFT.h>
#include <UTouch.h>
uint32_t cx, cy;
float px, py;
char buf[13];
void waitForTouch()
    myTouch.read();
    myTouch.read();
  myGLCD.InitLCD();
  myGLCD.clrScr();
myTouch.read();
tx = myTouch.TP_X;
ty = myTouch.TP_Y;
//Something like this
myGLCD.setColor(0, 0, 0);
    toHex(tx);
    myGLCD.print("X:", 30, 75);
    myGLCD.print(buf, 75, 0);
    toHex(ty);
    myGLCD.print("Y:", 110, 75);
    myGLCD.print(buf, 75, 80);
void startup()
  if (dispx==220)
  waitForTouch();
  myGLCD.clrScr();
  buf[0] = '0';
  buf[1] = 'x';
  buf[10] = 'U';
  buf[11] = 'L';
  buf[12] = 0;
    num=num>>4;
My GitHub:
nonamejohn
the cpp.
Code: [Select]
  UTouch.cpp - Arduino/chipKit library support for Color TFT LCD Touch screens
  Copyright (C)2010-2012 Henning Karlsen. All right reserved
  Basic functionality of this library are based on the demo-code provided by
  ITead studio. You can find the latest version of the library at
  If you make any modifications or improvements to the code, I would appreciate
  that you share the code with me so that I might include it in the next release.
  I can be contacted through http://www.henningkarlsen.com/electronics/contact.php
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include "UTouch.h"
#include "UTouchCD.h"
UTouch::UTouch(byte tclk, byte tcs, byte din, byte dout, byte irq)
    T_CLK        = tclk;
    T_CS         = tcs;
    T_DIN        = din;
    T_DOUT       = dout;
    T_IRQ        = irq;
void UTouch::InitTouch(byte orientation)
orient = orientation;
_default_orientation = CAL_S>>31;
touch_x_left = (CAL_X>>14) & 0x3FFF;
touch_x_right = CAL_X & 0x3FFF;
touch_y_top = (CAL_Y>>14) & 0x3FFF;
touch_y_bottom = CAL_Y & 0x3FFF;
disp_x_size = (CAL_S>>12) & 0x0FFF;
disp_y_size = CAL_S & 0x0FFF;
prec = 10;
pinMode(T_CLK,  OUTPUT);
    pinMode(T_CS,   OUTPUT);
    pinMode(T_DIN,  OUTPUT);
    pinMode(T_DOUT, INPUT);
    pinMode(T_IRQ,  OUTPUT);
digitalWrite(T_CS,  HIGH);
digitalWrite(T_CLK, HIGH);
digitalWrite(T_DIN, HIGH);
void UTouch::touch_WriteData(byte data)
byte temp;
byte nop;
temp=data;
digitalWrite(T_CLK,LOW);
for(byte count=0; count<8; count++)
if(temp & 0x80)
digitalWrite(T_DIN, LOW);
temp = temp << 1;
digitalWrite(T_CLK, LOW);
nop++;
nop++;
word UTouch::touch_ReadData()
byte nop;
word data = 0;
for(byte count=0; count<12; count++)
data <<= 1;
nop++;
nop++;
if (digitalRead(T_DOUT))
data++;
return(data);
void UTouch::read()
unsigned long tx=0, temp_x=0;
unsigned long ty=0, temp_y=0;
int datacount=0;
digitalWrite(T_CS,LOW);
for (int i=0; i<prec; i++)
touch_WriteData(0x90);
digitalWrite(T_CLK,HIGH);
temp_x=touch_ReadData();
touch_WriteData(0xD0);
temp_y=touch_ReadData();
if (!((temp_x>max(touch_x_left, touch_x_right)) or (temp_x==0) or (temp_y>max(touch_y_top, touch_y_bottom)) or (temp_y==0)))
ty+=temp_x;
tx+=temp_y;
datacount++;
digitalWrite(T_CS,HIGH);
if (datacount>0)
if (orient == _default_orientation)
TP_X=tx/datacount;
TP_Y=ty/datacount;
TP_X=ty/datacount;
TP_Y=tx/datacount;
TP_X=-1;
TP_Y=-1;
bool UTouch::dataAvailable()
bool avail;
pinMode(T_IRQ,  INPUT);
avail = !digitalRead(T_IRQ);
return avail;
int UTouch::getX()
long c;
c = long(long(TP_X - touch_x_left) * (disp_x_size)) / long(touch_x_right - touch_x_left);
if (c<0)
c = 0;
if (c>disp_x_size)
c = disp_x_size;
if (_default_orientation == PORTRAIT)
c = long(long(TP_X - touch_y_top) * (-disp_y_size)) / long(touch_y_bottom - touch_y_top) + long(disp_y_size);
c = long(long(TP_X - touch_y_top) * (disp_y_size)) / long(touch_y_bottom - touch_y_top);
if (c<0)
c = 0;
if (c>disp_y_size)
c = disp_y_size;
return c;
int UTouch::getY()
int c;
c = long(long(TP_Y - touch_y_top) * (disp_y_size)) / long(touch_y_bottom - touch_y_top);
if (c<0)
c = 0;
if (c>disp_y_size)
c = disp_y_size;
c = long(long(TP_Y - touch_x_left) * (disp_x_size)) / long(touch_x_right - touch_x_left);
c = long(long(TP_Y - touch_x_left) * (-disp_x_size)) / long(touch_x_right - touch_x_left) + long(disp_x_size);
if (c<0)
c = 0;
if (c>disp_x_size)
c = disp_x_size;
return c;
void UTouch::setPrecision(byte precision)
switch (precision)
case PREC_LOW:
prec=1;
case PREC_MEDIUM:
prec=10;
case PREC_HI:
prec=25;
case PREC_EXTREME:
prec=100;
default:
prec=10;
nonamejohn
the utouch.H
Code: [Select]
  UTouch.h - Arduino/chipKit library support for Color TFT LCD Touch screens
#ifndef UTouch_h
#define UTouch_h
#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#define PORTRAIT 0
#define LANDSCAPE 1
#define PREC_LOW 1
#define PREC_MEDIUM 2
#define PREC_HI 3
#define PREC_EXTREME 4
class UTouch
public:
word TP_X ,TP_Y;
UTouch(byte tclk, byte tcs, byte tdin, byte dout, byte irq);
void InitTouch(byte orientation = LANDSCAPE);
void read();
bool dataAvailable();
int getX();
int getY();
void setPrecision(byte precision);
    private:
byte T_CLK, T_CS, T_DIN, T_DOUT, T_IRQ;
long _default_orientation;
byte orient;
byte prec;
byte display_model;
long disp_x_size, disp_y_size, default_orientation;
long touch_x_left, touch_x_right, touch_y_top, touch_y_bottom;
void touch_WriteData(byte data);
word touch_ReadData();
#endif
HazardsMind
Oh wow, your library has nothing but the bare basics. Not going to lie, but it is going to be tough to write your sketch.
My GitHub:
