Topic: utouch ssd1963 5 inch problem (Read 20484 times) previous topic - next topic
HazardsMind
I hate to bring this back up again.  But I am dealing with the same problem.  I am using those same libraries.  The display only reads an X_touch and Y_touch of 320x240.  So clearly the screen is not mapped properly.  I attempted to use the sketch in reply 11 as suggested seeing as how it was noted that changes have been made to it multiple times.  Nothing appears on my screen.  This, however, is after I declared: long tx and long ty.  The compiler says these were not declared.  Regardless, nothing is happening.  What should I be expecting to see?  How can I fix the mapping?
If you have this exact library, then you have "myTouch.getX(), and myTouch.getY();" these are your raw touch data. So if you use myGLCD.printNumI(myTouch.getX(), 10, 50); you should see a value for the X axis.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
JHawk88
At the moment, I have been using Serial.println(x); to display the coordinates.  So far, they tell me only 320x240
-------------------ARDUINO-------------------
A Radical Developing Unit In Northern Oklahoma
HazardsMind
320 x 240? Then your screen is already mapped. So if you touch the middle of the screen do you get something like 160 x 120? Basically if you touch the screen anywhere, do the values change?
My GitHub:
JHawk88
Yes.  I get a value wherever I touch the screen.  I have my serial print out the x and y coordinates.  Out of curiosity I went ahead and did a trace program.  Draws the coordinates as I touch the screen.  I drew on the entire screen and it only drew in the top left.  Which I assume to be coordinates 320x240.  You mentioned that my screen is already mapped.  How can I remap it?
HazardsMind
Can you post a picture or make a small video? Its possible that your screen is 800 x 600 (maybe a little smaller), but the way its coded "myGLCD(SSD1963_800, 38,39,40,41);" may be set for a screen of 320x240, and not what you have.
My GitHub:
JHawk88
Ok, so I uploaded a video.  Here's the link.
http://youtu.be/MCAA80sr7_g
HazardsMind
#36
Jul 25, 2013, 07:47 pm Last Edit: Jul 25, 2013, 08:14 pm by HazardsMind Reason: 1
I'm curious, what happens if you do this,
myGLCD.drawPixel(myTouch.getX(),myTouch.getY());
I posted a reply on your youtube video.
EDIT:
I took a look at the UTFT library and you do have the screen set correctly.
Now what you need to do is print out the X coordinates as you touch the screen, and keep track of the screen boundaries. So you touch the screen as close to the left edge, to where it is still on the screen and not touching the black plastic part. Then do the same for the right side of the screen. Then once you have those two values, you can map them like so.
tx = myTouch.TP_X;
XC= constrain (map(tx, 205, 3900,0,239),0,239);
// this filters out the black plastic part of the screen and just gives me the visual part.
My actual screen size is 0 - 239, but my touch data goes from 205 - 3900, So this is what I did to map my touch data to my screen. Yours may be "map(tx, 5, 235, 0, 479)"
My GitHub:
JHawk88
Quote
I am currently trying to make an excel sheet mapping.  But if what you suggested fixes the problem, then that would resolve my problem and I would no longer have to waste my time w/ this array.  But to answer you question, coordinate (25,25) tells me that it is approx (0,10).  (105,25) reports a coordinate of (23,15). (265,25) reports a coordinate of (47,15).  So you can see my frustration as to what is going on here.  I was thinking that maybe I'd come up with some equation that just resolves this matter (exponential by the looks of it) but I know that doesn't really solve the problem and will leave a lot to be desired.  The code you offered, do I put this in the library or on my main sketch?
Code: [Select]
tx = myTouch.TP_X;
HazardsMind
Quote
No, that just what I did to map my screen. But you may be able to reverse it for yours. Use this as a test and see what you get map(tx, 5, 235, 0, 479)"
My GitHub:
JHawk88
In the setup?  Also, just a peculiar problem I am dealing with.... (745,457) = (226,315)?  Weird yes?
HazardsMind
My GitHub:
JHawk88
Ok, so I found that my X_max = 3850, X_min = 150(prob make 200), Y_max = 3800, Y_min = 150(prob make 200).  So do I apply these values to that constrain?  What exactly is that XC?
HazardsMind
XC = X Coordinate
ok, so you will do this then, X = map( myTouch.getX(), 200, 3800, 0, 479);
Also your Y max and min should be much bigger than X. They should not be the same.
My GitHub:
JHawk88
I agree that they shouldn't be, but that doesn't change the fact that they are.  Perhaps I've done something wrong?
I have:
x = myTouch.TP_X;
y = myTouch.TP_Y;
and then I am printing both x and y via serial to read their values
I went ahead and printed my code, perhaps you'd like to test it on your display and see if you read similar values.  I am thinking that at this point, I should just apply the ratios. 800/3800 and 480/3800 with an offset of 800/200 or something along those lines.
Code: [Select]
#include <UTFT.h>
#include <UTouch.h>
#define TOUCH_ORIENTATION  PORTRAIT
extern uint8_t BigFont[];
UTFT        myGLCD(SSD1963_800, 38,39,40,41);   // Remember to change the model parameter to suit your display module!
UTouch      myTouch(6,5,4,3,2);
unsigned long tx = 0;
unsigned long XC = 0;
void drawCrossHair(int x, int y)
  myGLCD.drawRect(x-10, y-10, x+10, y+10);
  myGLCD.drawLine(x-5, y, x+5, y);
  myGLCD.drawLine(x, y-5, x, y+5);
void displayCrosshair() {
  for (int i = 25; i <= 745; i = i + 80) {
    delay(1);
    for (int j = 25; j <= 457; j = j + 48) {
      myGLCD.setColor(255, 255, 255);
      drawCrossHair(i,j);
void txtdisplay() {
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.setFont(BigFont);
  myGLCD.print("Here is 25,25", 25, 25);
  myTouch.InitTouch(TOUCH_ORIENTATION);
  myGLCD.InitLCD();
  myGLCD.clrScr();
  myTouch.setPrecision(PREC_MEDIUM);
  //tx = myTouch.TP_X;
  //map(tx, 5, 235, 0, 479);
  displayCrosshair();
  //txtdisplay();        //Allos me to know where the top left corner is
  Serial.println(tx);
  long x, y;
  while (myTouch.dataAvailable() == true)
    myTouch.read();
    x = myTouch.TP_X;
    y = myTouch.TP_Y;
    if ((x!=-1) and (y!=-1)) {
      Serial.println("X Coordinate");
      Serial.println(x);
      Serial.println("Y Coordinate");
      Serial.println(y);
HazardsMind
Try this.
Code: [Select]
    myTouch.read();
    x = myTouch.TP_X;
    y = myTouch.TP_Y;
    int XC = map(x, 200, 3800, 0, 479);
      Serial.print("X Coordinate");
      Serial.print(x);
      Serial.print("  ");
      Serial.print("Y Coordinate");
      Serial.print(y);
      Serial.print("  ");
      Serial.print("Mapped X");
      Serial.println(XC);
My GitHub:
