Topic: Controlling the ITDB02 backlight (Read 1 time) previous topic - next topic
franciscoprado
I have an ITDB02 shield + 2.4" LCD. In its manual (https://www.google.com.br/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDoQFjAB&url=http%3A%2F%2Fitdb02.googlecode.com%2Ffiles%2FITDB02shield_Manual.pdf&ei=wUaOUdmGHo_M9AT0uIGgBQ&usg=AFQjCNH5ww6GKdFzgBHFOgAT-wpqyldAzA&sig2=Lz-k8D_ghpSyhSSXx0rpuA&cad=rja) is described a resistor becoming it able to handle the backlight, but I don't know which is.
I got the following code in one of these Arduino's forums by here. It draws a group of parallel coloured lines and text, but it backlight is not changed. I tried set different values in backlight_pin variable, but it didn't solve. Anyone knows how to? Tks
Code: [Select]
#include <UTFT.h>
const int backlight_pin = 8;
const int backlight_on = 0;
const int backlight_off = 255;
const int backlight_half = 127;
const int backlight_quarter = 192;
const int backlight_3quarter = 64;
extern uint8_t BigFont[];
// Uncomment the next line for chipKit Uno32
UTFT myGLCD(ITDB24E_8,19,18,17,16);   // Remember to change the model parameter to suit your display module!
// initialisation
// Setup the LCD
  myGLCD.InitLCD();
  myGLCD.setFont(BigFont);
  myGLCD.lcdOn();
  analogWrite(backlight_pin, backlight_on);
  drawBackground();
// Fool with the backlight
  screenMessage("    Full Backlight    ");
  delay(3000);
  screenMessage("    Half Backlight    ");
  analogWrite(backlight_pin, backlight_half);
  delay(3000);
  screenMessage("  Quarter Backlight   ");
  delay(3000);
  screenMessage("      Fade  Down      ");
  for(int i=0;i<256;i++) {
    analogWrite(backlight_pin, i);
    delay(25);
  screenMessage("      Fade  Up       ");
  for(int i=255;i>-1;i--) {
    delay(25);
// Display the backlight state
void screenMessage(String message) {
  myGLCD.setColor(255,255,255);
  myGLCD.setBackColor(0,0,0);
  myGLCD.print(message, CENTER, 113);
// Put some mixed colours in
void drawBackground() {myGLCD.clrScr();
  int r=255;
  int g,b=0;
  for(int y=0;y<100;y+=20){
    myGLCD.setColor(r, g, b);
    myGLCD.fillRect (0,y,319,y+10);
    r-=16;
    g+=16;
    b+=16;
  r=0;
  g,b=255;
  for(int y=226;y>100;y-=20){
    myGLCD.fillRect (0,y,319,y-10);
    r+=16;
    g-=16;
    b-=16;
guix
#1
May 11, 2013, 05:51 pm Last Edit: May 11, 2013, 05:53 pm by guix Reason: 1
That blue thing with the screw, is the variable resistor.
franciscoprado
#2
May 18, 2013, 07:51 pm Last Edit: May 18, 2013, 07:56 pm by franciscoprado Reason: 1
Blue thing on the shield? Mine does not have (or I didn't find). :(
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
