Topic: ECG-EMG Arduino Shield (Read 5192 times) previous topic - next topic
MostafaHamdy
i need to know where the data of sensor saved because  i need signal from sensor andmove servo motors
i use this sheild
http://store.fut-electronics.com/111MED0002.html
http://store.fut-electronics.com/111MED0003.html
Code: [Select]
/* Demo program for:                                      */
/*    Board: SHIELD-EKG/EMG + Olimexino328                */
/*  Manufacture: OLIMEX                                   */
/*  COPYRIGHT (C) 2012                                    */
/*  Designed by:  Penko Todorov Bozhkov                   */
/*   Module Name:   Sketch                                */
/*   File   Name:   ShieldEkgEmgDemo.ino                  */
/*   Revision:  Rev.A                                     */
/*    -> Added is suppport for all Arduino boards.        */
/*       This code could be recompiled for all of them!   */
/*   Date: 19.12.2012                                     */
/*   Built with Arduino C/C++ Compiler, version: 1.0.3    */
Purpose of this programme is to give you an easy way to
connect Olimexino328 to ElectricGuru(TM), see:
https://www.olimex.com/Products/EEG/OpenEEG/EEG-SMT/resources/ElecGuru40.zip
where you'll be able to observe yours own EKG or EMG signal.
It is based on:
* ModularEEG firmware for one-way transmission, v0.5.4-p2
* Copyright (c) 2002-2003, Joerg Hansmann, Jim Peters, Andreas Robinson
* License: GNU General Public License (GPL) v2
For proper communication packet format given below have to be supported:
////////// Packet Format Version 2 ////////////
// 17-byte packets are transmitted from Olimexino328 at 256Hz,
// using 1 start bit, 8 data bits, 1 stop bit, no parity, 57600 bits per second.
// Minimial transmission speed is 256Hz * sizeof(Olimexino328_packet) * 10 = 43520 bps.
struct Olimexino328_packet
  uint8_t sync0; // = 0xa5
  uint8_t sync1; // = 0x5a
  uint8_t version; // = 2 (packet version)
  uint8_t count; // packet counter. Increases by 1 each packet.
  uint16_t data[6]; // 10-bit sample (= 0 - 1023) in big endian (Motorola) format.
  uint8_t switches; // State of PD5 to PD2, in bits 3 to 0.
#include <compat/deprecated.h>
#include <FlexiTimer2.h>
//http://www.arduino.cc/playground/Main/FlexiTimer2
// All definitions
#define NUMCHANNELS 6
#define HEADERLEN 4
#define PACKETLEN (NUMCHANNELS * 2 + HEADERLEN + 1)
#define SAMPFREQ 256                      // ADC sampling rate 256
#define TIMER2VAL (1024/(SAMPFREQ))       // Set 256Hz sampling frequency
#define LED1  13
#define CAL_SIG 9
// Global constants and variables
volatile unsigned char TXBuf[PACKETLEN];  //The transmission packet
volatile unsigned char TXIndex;           //Next byte to write in the transmission packet.
volatile unsigned char CurrentCh;         //Current channel being sampled.
volatile unsigned char counter = 0;   //Additional divider used to generate CAL_SIG
volatile unsigned int ADC_Value = 0;   //ADC current value
// Functions
/*  Function name: Toggle_LED1                      */
/*  Parameters                                      */
/*    Input   :  No                             */
/*    Output  :  No                                 */
/*    Action: Switches-over LED1.                   */
void Toggle_LED1(void){
if((digitalRead(LED1))==HIGH){ digitalWrite(LED1,LOW); }
else{ digitalWrite(LED1,HIGH); }
/*  Function name: toggle_GAL_SIG                   */
/*  Parameters                                      */
/*    Input   :  No                             */
/*    Output  :  No                                 */
/*    Action: Switches-over GAL_SIG.                */
void toggle_GAL_SIG(void){
if(digitalRead(CAL_SIG) == HIGH){ digitalWrite(CAL_SIG, LOW); }
else{ digitalWrite(CAL_SIG, HIGH); }
/*  Function name: setup                            */
/*  Parameters                                      */
/*    Input   :  No                             */
/*    Output  :  No                                 */
/*    Action: Initializes all peripherals           */
noInterrupts();  // Disable all interrupts before initialization
// LED1
pinMode(LED1, OUTPUT);  //Setup LED1 direction
digitalWrite(LED1,LOW); //Setup LED1 state
pinMode(CAL_SIG, OUTPUT);
//Write packet header and footer
TXBuf[0] = 0xa5;    //Sync 0
TXBuf[1] = 0x5a;    //Sync 1
TXBuf[2] = 2;       //Protocol version
TXBuf[3] = 0;       //Packet counter
TXBuf[4] = 0x02;    //CH1 High Byte
TXBuf[5] = 0x00;    //CH1 Low Byte
TXBuf[6] = 0x02;    //CH2 High Byte
TXBuf[7] = 0x00;    //CH2 Low Byte
TXBuf[8] = 0x02;    //CH3 High Byte
TXBuf[9] = 0x00;    //CH3 Low Byte
TXBuf[10] = 0x02;   //CH4 High Byte
TXBuf[11] = 0x00;   //CH4 Low Byte
TXBuf[12] = 0x02;   //CH5 High Byte
TXBuf[13] = 0x00;   //CH5 Low Byte
TXBuf[14] = 0x02;   //CH6 High Byte
TXBuf[15] = 0x00;   //CH6 Low Byte
TXBuf[2 * NUMCHANNELS + HEADERLEN] =  0x01; // Switches state
// Timer2
// Timer2 is used to setup the analag channels sampling frequency and packet update.
// Whenever interrupt occures, the current read packet is sent to the PC
// In addition the CAL_SIG is generated as well, so Timer1 is not required in this case!
FlexiTimer2::set(TIMER2VAL, Timer2_Overflow_ISR);
FlexiTimer2::start();
// Serial Port
Serial.begin(57600);
//Set speed to 57600 bps
// MCU sleep mode = idle.
//outb(MCUCR,(inp(MCUCR) | (1<<SE)) & (~(1<<SM0) | ~(1<<SM1) | ~(1<<SM2)));
interrupts();  // Enable all interrupts after initialization has been completed
/*  Function name: Timer2_Overflow_ISR              */
/*  Parameters                                      */
/*    Input   :  No                             */
/*    Output  :  No                                 */
/*    Action: Determines ADC sampling frequency.    */
void Timer2_Overflow_ISR()
  // Toggle LED1 with ADC sampling frequency /2
  Toggle_LED1();
  //Read the 6 ADC inputs and store current values in Packet
  for(CurrentCh=0;CurrentCh<6;CurrentCh++){
    ADC_Value = analogRead(CurrentCh);
    TXBuf[((2*CurrentCh) + HEADERLEN)] = ((unsigned char)((ADC_Value & 0xFF00) >> 8)); // Write High Byte
    TXBuf[((2*CurrentCh) + HEADERLEN + 1)] = ((unsigned char)(ADC_Value & 0x00FF)); // Write Low Byte
  // Send Packet
  for(TXIndex=0;TXIndex<17;TXIndex++){
    Serial.write(TXBuf[TXIndex]);
  // Increment the packet counter
  TXBuf[3]++;
  // Generate the CAL_SIGnal
  counter++; // increment the devider counter
  if(counter == 12){ // 250/12/2 = 10.4Hz ->Toggle frequency
    counter = 0;
    toggle_GAL_SIG(); // Generate CAL signal with frequ ~10Hz
/*  Function name: loop                             */
/*  Parameters                                      */
/*    Input   :  No                             */
/*    Output  :  No                                 */
/*    Action: Puts MCU into sleep mode.             */
__asm__ __volatile__ ("sleep");
PeterH
It looks as if the data is stored in TXBuf.
It also looks as if it's doing serial output within an interrupt service routine, which is not generally regarded as a smart thing to do, but if it's not causing a problem then I suppose you could ignore that.
MostafaHamdy
i try to read data from TXBuf but i failed can you tell me how can i read it ? thanks
bia2
Good Afternoon,
I'm doing a project for college on electrocardiogram using Arduino UNO (the code I'm using is what is on the site of OLIMEX) .. The display of the ECG signal is done in software ElectricGuru coming site (https://www .olimex.com / Products / Duino / Shields / SHIELD-EKG-EMG /).
However I was asked me to detect the time of the heartbeat, to average between them and send these values ??to the software that lets you view. Someone can help me? I have many difficulties ...
Thank you
