Topic: ATMEGA2560 + Ethernet Shield + SD Read/Write Can't access both at same time (Read 1 time) previous topic - next topic
As per the requirements of my project; I need to read/write data to/from Ethernet. Since both uses same SPI (i guess) thus as  a result I see that sometime card does not respond or sometime ethernet loses connection.
both (ethernet connectivity and SD read/write) works find individually but do not work collectively.
My requirements of projects does not allow me to use any one of the shields at one time. i need to write/read to/from ethernet.
Can anyone please guide me.
I don't have a problem. Here is a sketch that uses the w5100 and the SD together.
It uses two sockets on the w5100 and the SD.
Maybe you should post the code you are trying.
