Topic: Wifi WebClient (Read 817 times) previous topic - next topic
layla
Hallo Gemeinde,
ich versuche das Beispiel Wifi WebClient zubenutzen doch es funktioniert nicht und ich sehe keinen Lösungsansatz
Verwenden tue ich ein Arduino Mega 2560 mit originalem Arduino WiFi Shield.
Der Verbindungsaufbau zum Netzwerk scheint zufunktionieren aber der connect zum Server schlägt wohl fehl.
Hab ihr evt eine Lösung für mich parat?
Hier noch die SerialMoitor ausgabe:
Attempting to connect to SSID: FRITZ!Box 6360 Cable
Connected to wifi
IP Address: 192.168.0.23
signal strength (RSSI):-62 dBm
Starting connection to server...
Connection fail
disconnecting from server.
Code: [Select]
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "FRITZ!Box 6360 Cable"; //  your network SSID (name)
char pass[] = "xxxxxXXXxxxx";    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;            // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
IPAddress server(173,194,73,105);  // numeric IP for Google (no DNS)
//char server[] = "www.google.com";    // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while(true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  Serial.println("Connected to wifi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  // if you get a connection, report back via serial:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    // Make a HTTP request:
    client.println("GET /search?q=arduino HTTP/1.1");
    client.println("Host:www.google.com");
    client.println("Connection: close");
    client.println();
  else {
    Serial.print("Connection fail");
  // if there are incoming bytes available
  // from the server, read them and print them:
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  // if the server's disconnected, stop the client:
  if (!client.connected()) {
    Serial.println("disconnecting from server.");
    client.stop();
    // do nothing forevermore:
    while(true);
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
pylon
Installiere einen Netzwerk-Sniffer (z.B. WireShark) auf einen Notebook, das im selben WLAN hängt und sniffe den Traffic mit, während der Arduino den Connect versucht. Das dürfte Dir den Hinweis geben, was schief gehen könnte.
mkl0815
Lass Dir in der Funktion printWifiStatus() auch die Gateway-Adresse und die Netzmaske mit ausgeben. Ggf. fehlt das Gateway und Du kommst gar nicht aus Deinem eigenen Netz raus.
Code: [Select]
  Serial.println(ip);
// print your gateway address:
  IPAddress  gateway = WiFi.gatewayIP();
  Serial.print("GATEWAY: ");
  Serial.println(gateway);
  // print your subnet mask:
    IPAddress  subnet = WiFi.subnetMask();
    Serial.print("NETMASK: ");
  Serial.print(rssi);
jurs
Ich habe noch nie ein WiFi-Shield gehabt, aber wenn ich mal von meinen Ethernet-Shields ausgehe und was sich da bewährt hat, würde ich folgende zwei Dinge mal testen:
1. Zwischen Herstellen der Verbindung zum Netzwerk und dem ersten Connecten mit einem Internet-Server mindestens eine Sekunde vergehen lassen, in der das Netz sich auf den neuen Teilnehmer einstellen kann:
2. Wenn sich auf dem Shield mehrere SPI-Gerätschaften befinden, dann würde ich die gerade nicht verwendete SPI-Hardware ausdrücklich abschalten, was beim WiFi-Shield wohl wie auch beim Ethernet-Shield den SD-Kartenadapter betrifft. Am besten im Setup einfügen:
  pinMode(4,OUTPUT);
  digitalWrite(4,HIGH);
  Serial.println(F("SD card adapter deactivated"));
layla
Danke für eure Tips ;)
Ich konnte das Problem nun losen. Ich hatte zuvor das Shield mit einem Code Snippsel für UDP Send/Receive getestet, dies lief auch wunderbar, dazu habe ich aber eine andere Firmware aufladen müssen.
Fazit: Mit originaler Firmware funktioniert das Beispiel 1A
Grüße Layla
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
