Topic: Arduino Mega with NRF24L01+ and NRF24L01+ with Atmega328p (Read 5245 times) previous topic - next topic
Maks
Hello all,
im here, trying to get help to get myself out of misery... I've been searching for info on how to achieve my goal, but i still couldn't find :S
Basically i have an Arduino Mega 2560, 2x NRF24L01+ (5v capable) and an Atmega328p on a breadboard...
I would like to know the connections i should make, since i have already found several versions and none worked...
I know that this post asks for a lot, but im quite desperate...
First Step:
NRF24L01+ / Arduino Mega
1-GND             GND
2-VCC             VCC
3-CE                 ?
4-CSN               ?
5-SCK               ?
6-MOSI              ?
7-MISO              ?
8-IRQ                ?
Can you fill the ? please
Second Step:
NRF24L01+ / Atmega328p (breadboard with 16mhz crystal)
1-GND             GND
2-VCC             VCC
3-CE                 ?
4-CSN               ?
5-SCK               ?
6-MOSI              ?
7-MISO              ?
8-IRQ                ?
The purpose of this is to use the arduino to activate a relay on the breadboard and then receive the completed order
If i know that the hardware part is correct, i can go and deal only with the software part
Thanks in advance
fungus
5-SCK               ?
6-MOSI              ?
7-MISO              ?
Those connect to the Mega/Mega328 pins with the same name.
All the others will depend on the driver you want to use.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Maks
5-SCK               ?
6-MOSI              ?
7-MISO              ?
Thank you for the reply... in that case, i should first get the "code" part.
I'll get by when i have more work done on that matter
Again, Thanks
Maks
#3
May 13, 2013, 12:03 am Last Edit: May 13, 2013, 12:20 am by Maks Reason: 1
i chose the RF24 library to go to.
RF24 radio(9,10); these would be the CSN and CE?
9 and 10 would be on arduino side, and on the uC?
fungus
I haven't used that library but it looks like it, yes.
The IRQ pin isn't needed to make it work. You can leave it unconnected.
Maks
Thank you for the answers, i'll update this thread if needed
Maks
Unfortunatly i'm back with some bad news :S
first of all, ill post my code on each side then the connections...
Arduino Side (tx)
Code: [Select]
Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
#include <RF24Network.h>
#include <RF24.h>
#include <SPI.h>
// nRF24L01(+) radio attached using Getting Started board
RF24 radio(49,53);
// Network uses that radio
RF24Network network(radio);
// Address of our node
const uint16_t this_node = 1;
// Address of the other node
const uint16_t other_node = 0;
// How often to send 'hello world to the other unit
const unsigned long interval = 2000; //ms
// When did we last send?
unsigned long last_sent;
// How many have we sent already
unsigned long packets_sent;
// Structure of our payload
struct payload_t
  unsigned long ms;
  unsigned long counter;
void setup(void)
  Serial.begin(57600);
  Serial.println("RF24Network/examples/helloworld_tx/");
  SPI.begin();
  radio.begin();
  network.begin(/*channel*/ 90, /*node address*/ this_node);
void loop(void)
  // Pump the network regularly
  network.update();
  // If it's time to send a message, send it!
  unsigned long now = millis();
  if ( now - last_sent >= interval  )
    last_sent = now;
    Serial.print("Sending...");
    payload_t payload = { millis(), packets_sent++ };
    RF24NetworkHeader header(/*to node*/ other_node);
    bool ok = network.write(header,&payload,sizeof(payload));
    if (ok)
      Serial.println("ok.");
      Serial.println("failed.");
Connections:
nrf24l01+          Arduino Mega 2560
1-GND               GND
2-VCC               5v
3-CE                 53 or 49
4-CSN               49 or 53
5-SCK               52
6-MOSI              51
7-MISO              48
ATMega328p on breadboard (RX)
Code: [Select]
//RX
#include <RF24.h>
#include <SPI.h>
RF24 radio(49,53);
const uint16_t this_node = 0;
const uint16_t other_node = 1;
struct payload_t
  unsigned long ms;
void setup(void)
  SPI.begin();
  radio.begin();
void loop(void)
  network.update();
  // Is there anything ready for us?
  while ( network.available() )
    // If so, grab it and print it out
    RF24NetworkHeader header;
    payload_t payload;
    network.read(header,&payload,sizeof(payload));
    Serial.print("Received packet #");
    Serial.print(payload.counter);
    Serial.print(" at ");
    Serial.println(payload.ms);
Connections:
nrf24l01+          ATMega328p
1-GND               GND
2-VCC               5v
3-CE                 14
4-CSN               15
5-SCK               19
6-MOSI              17
7-MISO              18
Results:
On Arduino (tx)
with CE on 53 and CSN on 49
Code: [Select]
Sending...failed.
Sending...failed.
Sending...failed.
only with CSN on 49
Code: [Select]
Sending...RF24Network/examples/helloworld_tx/
Sending...failed.
Sending...failed.
Sending...failed.
Without CE or CSN
Code: [Select]
Sending...ok.
Sending...ok.
Something must be wrong and im too blind/newb to see. Maybe the pins on ATMega328p (breadboard)? maybe arduino? maybe both?
I tried to be as explicit as possible and btw, the code was from http://maniacbug.wordpress.com/2012/03/30/rf24network/
Thanks in advance
Maks
Just so you know, i'm not asking for you to check the code, but the pin assignment, cause that's what i'm really struggling. I've never worked with uC before, so this is mostly new to me
Maks
got it working now... My problem was the connections, they were wrong.
Thanks for the help
wvdakker
What in the pins was wrong? The assignments in your list? Or did you plug in wrong?
Maks
the problem was on the mega side... i was connecting it wrong...
if i recall correctly, (i made a pause o the project, lack of time) i use the pins 49, 50, 51 and 52, the power/gnd and the assigned pins for comms
