Topic: MPU 6050 to Arduino Mega 2560 Connections and code (Read 15031 times) previous topic - next topic
rdrprsdm
Hello all,
I am doing a project in which it requires the accelerations of hand. So, I purchased an accelerometer MPU 6050 (GY 521) and Arduino Mega 2560. All I want is to get the accelerations on my desktop screen whenever I move the accelerometer.
Please help me in getting me the connections and code.
A Quick Glimpse:
1. My connections - Vcc to 3.3v ; GND to GND; SCL to SCL 21; SDA to SDA 20; AD0 to GND;
2. Message displaying is MPU Connections are failed.
3. Tried using I2Cdev to check and it is showing I2C devices not found.
How to solve these things?
Thanks a lot in advance.
Rudra
Erdin
#1
May 13, 2013, 08:52 am Last Edit: May 13, 2013, 08:54 am by Erdin Reason: 1
You give us good information about the problem with screen dumps and a photo: very good.
The GY-521 has an onboard voltage regulator for 3.3V. If you supply 3.3V to Vcc, the resulting voltage might be a little lower.
The Mega 2560 is an older chip which requires a high voltage for a valid '1'.
That seems to be the problem.
Solution: Use the Arduino 5V pin for the Vcc of the sensor board.
Or use a level shifter for the I2C signals.
The I2Cdevlib requires an interrupt. Connect INT to pin 2 (pin 2 is int.0).
http://arduino.cc/en/Reference/AttachInterrupt
AD0 has a pull-up or pull-down resistor, you don't have to connect it.
Note: the sensor board is running at 3.3V so if you want it to be high, connect it to 3.3V and never to 5V.
This is basic information to start, http://playground.arduino.cc/Main/MPU-6050
To get an i2c device working, try the i2c scanner as the first test.
http://playground.arduino.cc/Main/I2cScanner
rdrprsdm
Thanks a lot, sir. It is working now. I have sent you a personal message to you. It would be great if you reply to that mail :)
elciobardeli
Hello.
I'm using this code and I want to know where and how can I able the int 0 on the board and the script
#include <ADXL345.h>
#include <bma180.h>
#include <HMC58X3.h>
#include <ITG3200.h>
#include <MS561101BA.h>
#include <I2Cdev.h>
#include <MPU60X0.h>
#include <EEPROM.h>
//#define DEBUG
#include "DebugUtils.h"
#include "CommunicationUtils.h"
#include "FreeIMU.h"
#include <Wire.h>
#include <SPI.h>
int raw_values[9];
//char str[512];
float ypr[3]; // yaw pitch roll
float val[9];
// Set the FreeIMU object
FreeIMU my3IMU = FreeIMU();
  Wire.begin();
  delay(5);
  my3IMU.init(); // the parameter enable or disable fast mode
  delay(5);
  my3IMU.getYawPitchRoll(ypr);
  Serial.print("Yaw: ");
  Serial.print(ypr[0]);
  Serial.print(" Pitch: ");
  Serial.print(ypr[1]);
  Serial.print(" Roll: ");
  Serial.print(ypr[2]);
  Serial.println("");
  delay(10);
