Topic: Doubt about IF statement [SOLVED] (Read 688 times) previous topic - next topic
blastboot
May 13, 2013, 11:40 pm Last Edit: May 14, 2013, 01:23 am by blastboot Reason: 1
Is there any difference between
if (main condition) {
if (1st condition) {
do something...
} else if (2nd condition) {
do something...
and this:
do something...
do something...
between using only if's or if and if else's..
Thanks in adance!
Arrch
Yes. The 2nd do something will be run for 1st condition and 2nd condition being true for the second example, but not for the first.
blastboot
Sorry but i couldn't understand
guix
#3
May 14, 2013, 01:01 am Last Edit: May 14, 2013, 01:03 am by guix Reason: 1
Yes there is a difference, it depend what you want to do.
In the first case, the "else if" will be checked only if the first "if" condition wasn't true. In the second case, both conditions will be checked.
So for example in this case:
if ( a == 2 )
 // do something
if ( a == 3 )
 // do something else
it is better to use a "else if".
But in this case for example:
if ( a == 2 )
 // do something
if ( b == true )
 // do something unrelated to the first condition
Using a "else if" here, will not be what you want the program to do
blastboot
i got it! many thanks for your help!
Cheers
