Topic: Problem Serial.available() = 0, ( SOLVED ) (Read 1 time) previous topic - next topic
ignaciot
May 14, 2013, 07:32 am Last Edit: May 14, 2013, 06:53 pm by ignaciot Reason: 1
hi, i always control arduino via serial  without problem. but I changed my pc, and i cant send data from pc to arduino, and now when I do it I always obtain "Serial.available() = 0"
even with the most basic program to do it i obtain "Serial.available() = 0"
if (Serial.available() > 0) {
       else{
           Serial.println("serial is not available");
i always obtain "serial is not available" in my new pc, i return to the old pc and  works perfect
can any help me? thanks!
pYro_65
You need to send data to it for any other result. Serial.available() only returns the number of bytes in the receive buffer, not weather the serial functionality is available.
Forum Mod anyone?
https://arduino.land/Moduino/
ignaciot
#2
May 14, 2013, 07:48 am Last Edit: May 14, 2013, 07:51 am by ignaciot Reason: 1
i always send data from monitor serial or matlab to arduino, but now these data are not read. obviously i erase this line
in my programs
UKHeliBob
What baud rate is the Serial monitor set to ?
ignaciot
ignaciot
i think that my PC have a driver problem, but i can send data via serial using serial.print from arduino to PC.
ignaciot
I solved it! at left  "blaud rate" in monitor serial I select "carriage return". thanks!
UKHeliBob
That does not make any sense.
What you have done is to tell the Serial monitor to append a Carriage Return to the text sent to the Arduino, but the code that you posted does not rely on the CR being present.
