Topic: Using MP3 Player Shield with custom pressure sensor (Read 944 times) previous topic - next topic
Falxhor
Hey all,
I'm using pressure sensors to trigger the MP3 Player shield to play certain .mp3 files. When it comes to the arduino code however I'm having trouble getting started on linking these pressure sensors (analog pins) to play mp3 files from the SD card.
For now I just want to make sure 1 pressure sensor triggers 1 mp3 while the other pressure sensors can simaltaneously do the same for the other mp3 files (every pressure sensor should be linked to 1 seperate mp3 file).
Later I'm aiming to have about 30 mp3 files in 6 groups of 5 files and I want the sensor to choose 1 out of 5 at random everytime its corresponding analog pin voltage value reaches 0 and then goes up again.
Also I'm under the impression that for my pressure sensors I need to place a resistance in my circuit of a value that's in the middle of the range of the resistance my pressure sensor gives, is this true?
Grumpy_Mike
Quote
No idea because you haven't posted a link to what sensor you are using.
Get one going first.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
