Topic: Is there a project to improve/replace the official examples? (Read 9141 times) previous topic - next topic
Louis Davis
#30
Jun 12, 2013, 05:40 pm Last Edit: Jun 12, 2013, 05:53 pm by Louis Davis Reason: 1
The regular examples are here:
https://github.com/arduino/Arduino/tree/master/build/shared/examples
The following library examples are in github here:
https://github.com/arduino/Arduino/tree/master/libraries
Code: [Select]
libraries/SD/examples/Files/Files.ino
libraries/Servo/examples/Knob/Knob.ino
libraries/Servo/examples/Sweep/Sweep.ino
libraries/GSM/examples/SendSMS/SendSMS.ino
libraries/SD/examples/CardInfo/CardInfo.ino
libraries/SD/examples/DumpFile/DumpFile.ino
libraries/SD/examples/ReadWrite/ReadWrite.ino
libraries/SD/examples/listfiles/listfiles.ino
libraries/SD/examples/Datalogger/Datalogger.ino
libraries/GSM/examples/ReceiveSMS/ReceiveSMS.ino
libraries/LiquidCrystal/examples/Blink/Blink.ino
libraries/GSM/examples/Tools/TestGPRS/TestGPRS.ino
libraries/LiquidCrystal/examples/Cursor/Cursor.ino
libraries/LiquidCrystal/examples/Scroll/Scroll.ino
libraries/Stepper/examples/MotorKnob/MotorKnob.ino
libraries/TFT/examples/Arduino/TFTPong/TFTPong.ino
libraries/Ethernet/examples/WebClient/WebClient.ino
libraries/Ethernet/examples/WebServer/WebServer.ino
libraries/Firmata/examples/EchoString/EchoString.ino
libraries/Firmata/examples/I2CFirmata/I2CFirmata.ino
libraries/GSM/examples/GsmWebClient/GsmWebClient.ino
libraries/GSM/examples/GsmWebServer/GsmWebServer.ino
libraries/GSM/examples/Tools/TestModem/TestModem.ino
libraries/LiquidCrystal/examples/Display/Display.ino
libraries/Robot_Control/examples/learn/Beep/Beep.ino
libraries/TFT/examples/Arduino/TFTGraph/TFTGraph.ino
libraries/EEPROM/examples/eeprom_read/eeprom_read.ino
libraries/Ethernet/examples/ChatServer/ChatServer.ino
libraries/WiFi/examples/ScanNetworks/ScanNetworks.ino
libraries/Wire/examples/slave_sender/slave_sender.ino
libraries/Firmata/examples/StandardFirmata/LICENSE.txt
libraries/GSM/examples/MakeVoiceCall/MakeVoiceCall.ino
libraries/EEPROM/examples/eeprom_clear/eeprom_clear.ino
libraries/EEPROM/examples/eeprom_write/eeprom_write.ino
libraries/WiFi/examples/WiFiWebClient/WiFiWebClient.ino
libraries/WiFi/examples/WiFiWebServer/WiFiWebServer.ino
libraries/Wire/examples/master_reader/master_reader.ino
libraries/Wire/examples/master_writer/master_writer.ino
libraries/Firmata/examples/ServoFirmata/ServoFirmata.ino
libraries/LiquidCrystal/examples/setCursor/setCursor.ino
libraries/Robot_Control/examples/learn/Melody/Melody.ino
libraries/TFT/examples/Arduino/TFTBitmapLogo/arduino.bmp
libraries/Ethernet/examples/TelnetClient/TelnetClient.ino
libraries/Ethernet/examples/UdpNtpClient/UdpNtpClient.ino
libraries/Firmata/examples/OldStandardFirmata/LICENSE.txt
libraries/WiFi/examples/ConnectWithWEP/ConnectWithWEP.ino
libraries/WiFi/examples/ConnectWithWPA/ConnectWithWPA.ino
libraries/WiFi/examples/WiFiChatServer/WiFiChatServer.ino
libraries/Wire/examples/slave_receiver/slave_receiver.ino
libraries/Firmata/examples/AnalogFirmata/AnalogFirmata.ino
drjiohnsmith
SO
how do we want to improve them ?
a standard format ?
  compatible with which version of the IDE ?
any suggestions on how we 'regression test them' ?
   do we branch the code ?
will the branch be bought back onto trunk, by who ?
GoForSmoke
I'd like to see errors and bad practices that new members learn taken out, starting with using long for time variables but mostly get the String use out and char arrays in.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
Sergegsx
+1 !
