Topic: Cornering fog lights / turning assistant. (Read 2169 times) previous topic - next topic
Hants
May 14, 2013, 04:18 pm Last Edit: May 14, 2013, 04:19 pm by Hants Reason: 1
Can somebody help me to add another functionality to the code?
I would like to add an another / INT / and if there is a 5V /HIGH/  - both foglamps should go on.
Code: [Select]
/* Light turning assistant for cars (cornering lights)
  Credits to user Dr_P at http://mjlorton.com forum
int fogL = 8;                               // 55W Relay for L fog lamp
int fogR = 7;                               // 55W Relay for R fog lamp
int indL = 4;                               // Circuit between multiswitch and indicator relay
int indR = 2;                               // Circuit between multiswitch and indicator relay
pinMode(fogL, OUTPUT);
pinMode(fogR, OUTPUT);
pinMode(indL, INPUT);
pinMode(indR, INPUT);
    int i=100;                                    // counter initialized with "done" value
    if(digitalRead(indR))
           i=0;                                   //if indicators were reversed, the cycle needs to be reset to full 5s
           while(digitalRead(indR) && i<100)
                 i++;
                 digitalWrite(fogR, HIGH);
                 digitalWrite(fogL, LOW);
                 delay(50);
     if(digitalRead(indL))                        //same as right side
           i=0;
           while(digitalRead(indL) && i<100)
                 i++;
                 digitalWrite(fogR, LOW);
                 digitalWrite(fogL, HIGH);
                 delay(50);
     if(!digitalRead(indR) && !digitalRead(indL))      // no indicators currently on
           if(i==100)                                  //neither indicators were on OR the 5s cycle is over
           else                                        //one or both indicators were on for less than 5s
                 while(!digitalRead(indR) && !digitalRead(indL) && i<100)      //but not any more
                       i++;                           //finish the 5s cycle in the last foglight configuration
                       delay(50);
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
like this?
Code: [Select]
void SignalHigh() {
  attachInterrupt(1, SignalHigh, RISING);
  int i = 100;                                    // counter initialized with "done" value
  if (digitalRead(indR)) {
    while(digitalRead(indR) && i<100) {
      i++;
      delay(50);
  if (digitalRead(indL)) {                        //same as right side
    i = 0;
    while(digitalRead(indL) && i<100) {
      i++;
      delay(50);
  if (!digitalRead(indR) && !digitalRead(indL))   // no indicators currently on
    if (i == 100) {                               //neither indicators were on OR the 5s cycle is over
    } else                                        //one or both indicators were on for less than 5s
      while(!digitalRead(indR) && !digitalRead(indL) && i<100) { //but not any more
        delay(50);
PeterH
After changing RISING to INPUT - both lamps are on permanently..
I can't think of any place where it would be correct to use RISING where it would also be correct to use INPUT.
INPUT is not a proper mode parameter for attachInterrupt. However, it results in generating an interrupt request on the low level of the pin.
AWOL
Quote
Any idea how to fix it?
Post code and schematic
Hants
#6
May 16, 2013, 02:02 am Last Edit: May 17, 2013, 02:17 am by Hants Reason: 1
[font=Verdana]SORTED[/font][/size]
Code: [Select]
Credits to users Dr_P and jucole at http://mjlorton.com forum
Version designed for use with relays equipped with photocoupler (JD-VCC pin)
(Pinout bank 1: [[JD-VCC, VCC]], GND;                        Pinout bank 2: GND, IN1, IN2, VCC)
More details about reversed connection: http://arduino.cc/forum/index.php?topic=79745.0
int swBoth = 3;                           // Separate switch for both fog lights
void setup()  {
  pinMode(swBoth, INPUT);
  if(digitalRead(indR)) {
      i++;
      if(! digitalRead(swBoth) ) {
      else {
      delay(50);
  if(digitalRead(indL)) { //same as right side
    i=0;
      i++;
      else {
      delay(50);
  if(!digitalRead(indR) && !digitalRead(indL)) { // no indicators currently on
      if(i==100) { //neither indicators were on OR the 5s cycle is over
        else {
      else  { //one or both indicators were on for less than 5s
        while(!digitalRead(indR) && !digitalRead(indL) && i<100 && !digitalRead(swBoth)  ) { //but not any more
          delay(50);
    else {
AWOL
Quote
Code looks like
Can I recommend you use the auto-format tool in the IDE before posting.
I'm getting travel-sick reading that.
Hants
Please, feel free to delete the whole topic.
AWOL
