Topic: RTC causing program problems (Read 940 times) previous topic - next topic
blastboot
May 14, 2013, 07:56 pm Last Edit: May 14, 2013, 08:03 pm by blastboot Reason: 1
I'm experiencing some program running problem when i uncomment the RTC function to read date and time for program save it with data to a log file. I'm getting the data by RF with virtualwire and if program runs with RTC uncomment i can't even get the data it shows in serial monitor something like "ggggggggggggggggggggggggggggggg..." and keeps going for eternity.
I i comment in everithing works just fine.
#include <SPI.h>
#include <avr/pgmspace.h>
#include <Ethernet.h>
#include <VirtualWire.h>
#include <Wire.h>
#include "SdFatUtil.h"
#define DS1307_I2C_Endereco 0x68  //SCL<--> Analog Input 5  SDA<--> Analog Input 4
#define I2C_Write Wire.write
#define I2C_Read Wire.read
prog_char noMes_0[] PROGMEM = "";
prog_char noMes_1[] PROGMEM = "Jan";
prog_char noMes_2[] PROGMEM = "Fev";
prog_char noMes_3[] PROGMEM = "Mar";
prog_char noMes_4[] PROGMEM = "Abr";
prog_char noMes_5[] PROGMEM = "Mai";
prog_char noMes_6[] PROGMEM = "Jun";
prog_char noMes_7[] PROGMEM = "Jul";
prog_char noMes_8[] PROGMEM = "Ago";
prog_char noMes_9[] PROGMEM = "Set";
prog_char noMes_10[] PROGMEM = "Out";
prog_char noMes_11[] PROGMEM = "Nov";
prog_char noMes_12[] PROGMEM = "Dez";
PROGMEM const char* noMes[] = {
 noMes_0, noMes_1, noMes_2, noMes_3, noMes_4, noMes_5, noMes_6, noMes_7, noMes_8, noMes_9, noMes_10,
 noMes_11, noMes_12};
byte segundo, minuto, hora, diaSemana, diaMes, mes, ano;
char nomeMes[10];
char ficheiroLer[10];
char mensagem[30];
unsigned int dadosAgua = 0;
float dadosBat = 0.0;
float percentagem = 0.0;
unsigned long litros = 0;
 delay(100);
 //DEFINE OS PINOS DE ENTRADA E DE SAÍDA
 pinMode(ledInfo, OUTPUT);
 pinMode(ledRececao, OUTPUT);
 pinMode(10, OUTPUT);
 //INICIA A COMUNICAÇÃO I2C
 Wire.begin();
 //LIGA E DESLIGA OS 2 LEDS PARA INDICAR QUE ESTÃO OPERACIONAIS
 digitalWrite(ledInfo, HIGH);
 digitalWrite(ledRececao, HIGH);
 digitalWrite(10, HIGH);
 digitalWrite(ledInfo, LOW);
 digitalWrite(ledRececao, LOW);
Ethernet.begin(mac, ip);
 server.begin();
 delay(100);
 //CONFIGURA E INICIA O RECEPTOR
 vw_set_tx_pin(6);
 vw_set_rx_pin(8);
 vw_set_ptt_pin(5);
 vw_setup(2000);
 vw_rx_start();
 //actDataHora();
 rececaoRF();
 clienteLigado();
void actDataHora() {
 //FAZ O STACK POINTER IR PARA O INÍCIO
 Wire.beginTransmission(DS1307_I2C_Endereco);
 I2C_Write(0x00);
 Wire.endTransmission();
 Wire.requestFrom(DS1307_I2C_Endereco, 7);
 segundo  = bcdToDec(I2C_Read() & 0x7f); //MASCARA PQ É BIT DE CONTROLE
 minuto   = bcdToDec(I2C_Read());
 hora     = bcdToDec(I2C_Read() & 0x3f); //MÁSCARA PQ É BIT DE CONTROLE
 diaSemana= bcdToDec(I2C_Read());
 diaMes   = bcdToDec(I2C_Read());
 mes      = bcdToDec(I2C_Read());
 ano      = bcdToDec(I2C_Read());
//CONVERSÃO DOS DADOS DE BCD PARA DECIMAL - RTC
byte bcdToDec(byte val)
 return ((val/16*10) + (val%16));
//RECEPÇÃO DOS DADOS POR RF 433MHz
void rececaoRF() {
 byte buf[VW_MAX_MESSAGE_LEN];
 byte buflen = VW_MAX_MESSAGE_LEN;
 if (vw_get_message(buf, &buflen)) {
   for (int j = 0; j<buflen; j++) {
     mensagem[j] = char(buf[j]);
   mensagem[buflen] = '\0';
   if (mensagem[0] == 'R') {
     dadosAgua = atoi(&mensagem[1]);
     if (dadosAgua > 0 && dadosAgua <= 465) {
       calcAgua();
       //Serial.println(dadosAgua);
   else if (mensagem[0] == 'B') {
     dadosBat = atof(&mensagem[1]);
     if (dadosBat > 0.00 && dadosBat <= 9.99) {
       gravarDados();
       //Serial.println(dadosBat);
   Serial.println(mensagem);
   memset(&buf, 0, sizeof(buf));
   memset(&mensagem, 0, sizeof(mensagem));
void gravarDados() {
 char ficheiroLog[10];
 strcpy_P(nomeMes, (char*)pgm_read_word(&(noMes[mes])));
 sprintf(ficheiroLog,"%s.csv", nomeMes);
 boolean Log = false;
 Serial.println(ficheiroLog);
 Log = file.open(&root, ficheiroLog, O_WRITE | O_APPEND);
 if (Log) {
   actDataHora();
   //DATA E HORA
   file.print(diaMes, DEC);
   file.print(" ");
   file.print(nomeMes);
   file.print(" ");
   file.print("20");
   if (ano < 10) {
     file.print("0");
   file.print(ano, DEC);
   file.print(" , ");
   if (hora < 10) {
     file.print("0");
   file.print(hora, DEC);
   file.print(":");
   if (minuto < 10) {
     file.print("0");
   file.print(minuto, DEC);
   file.print(":");
   if (segundo < 10) {
     file.print("0");
   file.print(segundo, DEC);
   //DADOS
   file.print(" , ");
   file.print(percentagem, 1);
   file.print(" , ");
   file.println(litros);
   file.close();
   Log = false;
 else {
   Serial.println(F("ERRO grav LOG!"));
   for (int i = 0; i<5; i++) {
     delay(250);
     delay(250);
 memset(&ficheiroLog, 0, sizeof(ficheiroLog));
I haven't posted the whole code because it is a little big, but i think that i've posted the most important parts.
I'm using RTC library from http://combustory.com/wiki/index.php/RTC1307_-_Real_Time_Clock
Thanks in advance for your help!
MarkT
If the code is big it could simply be you've run out of RAM space when using the RTC code as well...
blastboot
I'm using arduino mega. it is not ram problem because i've already do a lots of debugg and it only happens when i "turn on" rtc. It could be some variable overload but i'm using everything lalmost like it is on the rtc page i've posted. If there is any better library to use please tell me
craigcurtin
If you are using the mega shouldn;t you be using pin 20 and pin 21 for i2c - not pin4 and 5 ?
I just went through a whole heap of stuff over the last two days trying to find THE RIGHT library to use with the 1307
It does work when the pins are right
Craig
