Topic: jumpy analog values [Solved]-thankyou (Read 869 times) previous topic - next topic
grendle
May 14, 2013, 09:42 pm Last Edit: May 15, 2013, 12:24 am by grendle Reason: 1
hi all,
quick questions, running a sensor on analog0, and a coin cell on analog1, and then on analog2. both sharing the same ground, when run by themselves i get correct values. when i run them in the same sketch i get jumpy and incorrect values? any ideas? serial monitor pics enclosed.
float battery;
float temperature;
float b;
float a;
void setup(){
void loop(){
 b=0;
 a=0;
 battery=0;
 temperature=0;
 battery=analogRead(0);
 b=battery/1023*5.0;
 Serial.println(b);
 delay(100);
 get();
void get(){
 temperature=analogRead(2);
 a=(5.0*temperature*100.0)/1023.0;
 Serial.println(a);
AWOL
Try two readings each time you do an analogRead, and chuck the first one away.
DVDdoug
Right... There is really only one analog-to-digital converter in the chip, and the analog inputs are multiplexed (switched).    I haven't studied the timing-diagrams, but it takes some time to process & "settle".
holmes4
Your using 0 and 2 in the combined code not 0 and 1!
Mark
grendle
Mark
yes i was trying it both ways right now the sensors are on 0, 2.
grendle
#5
May 14, 2013, 11:35 pm Last Edit: May 14, 2013, 11:38 pm by grendle Reason: 1
ok thx im gnna try this now
this looks like its working the values are more consistent now. thank you guys.
