Topic: Redefine "on fly" custom CGRAM characters problem (Read 3214 times) previous topic - next topic
ekaki
Hi all -.^
[With Arduino2009 + SparkFun SerLCD 16x2]
Since I'm trying to define more than 8 CGRAM characters without success (HD44780 speak about more ?) I saw what is possible to redefine "on fly" custom characters because CGRAM is refresh continuously.
It could be another way to make small animate icons etc. ^.^
But I get something unexpected: When I try to write after half the bottom line of the LCD it compromises other parts of the screen O.o
(start blinking, etc.)
I'm a bit noob with those gears, so here is a simple code:
#include <SoftwareSerial.h>
#define txPin 2
SoftwareSerial LCD = SoftwareSerial(0, txPin);
 pinMode(txPin, OUTPUT);
 LCD.begin(9600);
 // définition des graphiques par défaut
 setGFX(0,152,152,128,131,132,132,131,128); // °C
 setGFX(1,128,128,130,135,130,128,128,128); // +
 setGFX(2,128,128,128,135,128,128,128,128); // -
 setGFX(3,138,159,145,142,132,132,152,128); // prise
 setGFX(4,142,145,145,145,145,145,159,128); // batterie (vide à l'origine)
 setGFX(5,128,128,128,128,128,128,128,128); //
 setGFX(6,128,128,128,128,128,128,128,128); //
 setGFX(7,128,128,128,128,128,128,128,128); //
 // initilisation de l'affichage
 setBackLight();
 clearLCD();
 selectLineOne();
 LCD.print(3, BYTE);
 LCD.print(" 14.21V");
 LCD.print(" ");
 LCD.print(1, BYTE);
 LCD.print("19.4");
 LCD.print(0, BYTE);
 selectLineTwo();
 LCD.print(4, BYTE);
 LCD.print("  3.12A");
 //LCD.print("  ");
 //LCD.print("test");
 setGFX(4,142,145,145,145,145,145,159,128); // batterie vide
 setGFX(4,142,145,145,145,145,159,159,128); // batterie 1/5
 setGFX(4,142,145,145,145,159,159,159,128); // batterie 2/5
 setGFX(4,142,145,145,159,159,159,159,128); // batterie 3/5
 setGFX(4,142,145,159,159,159,159,159,128); // batterie 4/5
 setGFX(4,142,159,159,159,159,159,159,128); // batterie pleine
 delay(750);
void setGFX(byte pos, byte b1, byte b2, byte b3, byte b4, byte b5, byte b6, byte b7, byte b8){
 LCD.print(0xFE, BYTE); // appel de fonction sur le HD44780
 LCD.print(64 + pos * 8, BYTE); // accès à la CGRAM
 LCD.print(b1, BYTE);
 LCD.print(b2, BYTE);
 LCD.print(b3, BYTE);
 LCD.print(b4, BYTE);
 LCD.print(b5, BYTE);
 LCD.print(b6, BYTE);
 LCD.print(b7, BYTE);
 LCD.print(b8, BYTE);
void selectLineOne(){ // place le curseur au début de la ligne 1
 LCD.print(128, BYTE);
 delay(2);
void selectLineTwo(){ // place le curseur au début de la ligne 2
 LCD.print(192, BYTE);
 delay(2);
void setBackLight(){
 LCD.print(0x7C, BYTE);
 LCD.print(130, BYTE);
 delay(100);
void clearLCD(){
 LCD.print(0x01, BYTE);
 delay(10);
void resetLCD(){
 LCD.print(0x72, BYTE);
If you uncomment lines 36 & 37 you can see what's append.
I hope my code and my English is not too bad,
thanks for any help *.*
Grumpy_Mike
I am not sure where you read that. The problem is that the refresh rate of the LCD is not synchronized to the arduino so I doubt if you can do this at all.
ekaki
I don't read it somewhere, in fact.
When I saw how CGRAM access works I just imagine it could be possible >.>
And for my previous code, there's something strange.. Maybe a timing RAM access problem.
But I rewrite some parts, and if the re-definition loop is not ending by a delay(), it's working ^.^
Here is a code where you can see it's working:
#define txPin 2
 LCD.begin(9600);
 setGFX(3,138,159,145,142,132,132,152,128); // prise 220V
 setGFX(5,128,128,128,159,128,128,159,128); // sortie 12V
 setGFX(6,128,128,136,149,130,128,159,128); // sortie 220V
 setGFX(7,128,128,135,133,135,130,129,128); // petite prise
 setBackLight();
 clearLCD();
 selectLineOne();
 LCD.print(3, BYTE);
 LCD.print(" ");
 LCD.print(1, BYTE);
 LCD.print("19.4");
 LCD.print(0, BYTE);
 selectLineTwo();
 LCD.print(4, BYTE);
 LCD.print(" ");
 LCD.print(7, BYTE);
 LCD.print(6, BYTE);
 LCD.print(7, BYTE);
 LCD.print(5, BYTE);
 LCD.print(7, BYTE);
 LCD.print(5, BYTE);
 LCD.print(" ");
 animGFX();
void animGFX(){
 setGFX(6,128,128,130,149,136,128,159,128);
 delay(750);
 delay(2);
 delay(2);
 delay(100);
void clearLCD(){
 delay(10);
void resetLCD(){
I imagine it can help some people who's looking for a solution to use more than 8 customs chars -.^
Or who want to make animate icons, like you can see in the code just here ^.^
Grumpy_Mike
I think I misunderstood you problem. I thought you wanted to redefine them on the fly so that you had more than 8 custom characters being displayed at the same time, not having the custom characters being redefined once they were on the screen. That is an old trick we used to use in 8 bit desktop computers to get animation.
ekaki
Harf... indeed, my English is "possibly" not very good  ::)
Of course, like I said, there's no easy way to have more than 8 customs chars.
I'll try to be more... Clear, next time -.^
carp
This may help . . .
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1268281540
There's more if you type "custom characters lcd" in the search box.
(Your English is fine.)
ekaki
Oops, I missed this post..
It's exactly the same thing I'm doing ^.^
I'll see to adapt it for serial use, thank you Sparks -.^
