Topic: I thought I understood arrays? (Read 852 times) previous topic - next topic
SteveHi
I guess I only understand simplistic arrays...
I was hoping someone would be kind enough to double check my code. I have been over it and over it for several hours, and by all accounts it should be working. I think. I am hoping a fresh pair of eyes will spot what I am missing.
I am trying to write a Sunrise/Sunset simulation using 9 LED channels on the pwm pins. I wrote a matrix to call start times, ramp up times, ramp down times, and led intensities. I also wrote a function to determine where the current point the lighting matrix is at.
I believe my mistake lies somewhere in my array/index calls, but I can't seem to locate it.
The follow is the code I wrote, and it is not giving accurate lighting results. It could also be a RTC issue.
Code: [Select]
//*******Included Libraries*******//
#include <ITDB02_Touch.h>
#include <avr/pgmspace.h>
#include <UTFT.h>
#include <tinyFAT.h>
#include <UTFT_tinyFAT.h>
#include <RTClib.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//********    Declare Touch/LCD/RTC    **********
UTFTtf  myGLCD(ITDB32S, 38, 39, 40, 41);
ITDB02_Touch  myTouch(46,45,44,43,42);
RTC_DS1307 RTC;
//********   Call Fonts    **********
extern uint8_t Sinclair_M[];
extern uint8_t Sinclair_S[];
extern uint8_t SevenSegNumFontPlus[];
//*******   Declare 1-Wire for TEMP sensors  ********
#define ONE_WIRE_BUS 1
#define TEMPERATURE_PRECISION 9
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature Sensors(&oneWire);
//***************   Sunrise/sunset Variables **************************//
const int CHANNELS = 9;
const int MAXPERIODS = 3;
//###   Clock Varibles ################################
boolean AM_PM;
int Hours;
int Minutes;
int Seconds;
int Day;
int Month;
int Year;
int Weekday;
String Current_time;
int Time_Format = 2;
boolean Daytime = true;
boolean Was_day;
//### LED Variables ############################
const int Wht_Ch1 = 3;
const int RBlue_Ch1 = 5;
const int Blue_Ch1 = 7;
const int Wht_Ch2 = 8;
const int RBlue_Ch2 = 9;
const int Blue_Ch2 = 10;
const int Wht_Ch_3 = 11;
const int RBlue_Ch3 = 12;
const int UV_Ch1 = 13;
//###   Sunrise/SunSet Variables #########################
boolean Sun_rise = true;
boolean Equinox_mode = true;
int Sunrise_Hour;
int Sunrise_Min;
int Sunrise_Sec;
int Sunset_Hour;
int Sunset_Min;
int Sunrise_length = 0;
int Sun_level;
int sunMatrix[CHANNELS][MAXPERIODS][5] =
    (0, 0, 9, 15, 0),
    (9, 45, 18, 45, 255),    //Wht_ch1
    (19, 15, 24, 0, 0),
    (0, 0, 8, 0, 0),
    (8, 30, 20, 0, 255),     //RBlue_Ch1
    (20, 30, 24, 0, 0),
    (0, 0, 8, 45, 0),
    (9, 15, 19, 30, 255),   //Blue Ch1
    (20, 0, 24, 0, 0),
    (0, 0, 9, 30, 0),
    (10, 0, 19, 0, 255),    //Wht_Ch2
    (19, 30, 24, 0, 0),
    (0, 0, 8, 15, 0),
    (8, 45, 20, 15, 255),    //RBlue_Ch2
    (20, 45, 24, 0, 0),
    (0, 0, 9, 0, 0),
    (9, 30, 19, 45, 255),    //Blue_Ch2
    (8, 15, 24, 0, 0),
    (0, 0, 9, 45, 0),
    (10, 15, 19, 15, 255),     //Wht_Ch_3
    (19, 30, 24, 0, 0),
    (0, 0, 8, 30, 0),
    (9, 0, 20, 30, 255),     //RBlue_Ch3
    (21, 0, 24, 0, 0),
    (0, 0, 7, 45, 64),
    (8, 0, 21, 0 , 128),       //UV_Ch1
    (21, 15, 24, 0, 64),
int sunValue[CHANNELS] = {0, 0, 0, 0, 0, 0, 0, 0, 0};
//*******************************************      $Setup      ********************************[#SETUP]
void setup(){
  myGLCD.InitLCD(PORTRAIT);                           //Initiate LCD Screen
  myGLCD.clrScr();
  file.initFAT(SPISPEED_VERYHIGH);                    //Initiate SD Card for FAT16 Lib
  Wire.begin();
  RTC.begin();                                        //Initiate Real Time Clock
  myTouch.InitTouch(PORTRAIT);                        //Initiate Touch Screen for Portriat
  myTouch.setPrecision(PREC_HI);
  Sensors.begin();                                                //Begin Dallas 1-Wire Temperature
  pinMode(1, OUTPUT);
  RTC.adjust(DateTime(__DATE__, __TIME__));            //Sets clock to current upload time
  boolean home_screen = true;
  Home_Screen();
/////////************* FUNCTIONS ***********//////////
////////########### Sunrise/Sunset #################//
void Sunrise_set(long seconds){
     for(int channel = 0; channel < CHANNELS; channel ++){  //for each channel
        for(int period = 0; period < MAXPERIODS; period++){  //for each possible period
           long pEnd = GetSeconds(sunMatrix[channel][period][Sunset_Hour], sunMatrix[channel][period][Sunset_Min], 0);
if(pEnd >= seconds) { // Period is currently happening
sunValue[channel] = sunMatrix[channel][period][Sun_level]; // Set light to defined value
break; // Found correct period, don't check the rest
} else { // Period has not yet happened
long pNextStart = GetSeconds(sunMatrix[channel][period+1][Sunrise_Hour], sunMatrix[channel][period+1][Sunrise_Min], 0); // Get next period start time in seconds
if(pNextStart > seconds) { // Currently in between periods
int preVal = sunMatrix[channel][period][Sun_level];     // Old light value
int postVal = sunMatrix[channel][period+1][Sun_level]; // New light value
int tDur = pNextStart - pEnd; // Transition duration
int intensityDiff = postVal - preVal; // Difference in light intesity between periods
if(intensityDiff > 0) { // Intensity increasing
sunValue[channel] = (int)((seconds - pEnd) * ((float)intensityDiff / tDur)); // Light value
} else { // Intensity decreasing
sunValue[channel] = preVal - (int)((seconds - pEnd) * ((float)(0-intensityDiff) / tDur)); // Light value
long GetSeconds(int hours, int minutes, int seconds) // Convert HH:mm:ss -> Seconds since midnight
return ((long)hours * 60 * 60) + (minutes * 60) + seconds ;
//################################################# MAIN LOOP ################################################################//
void loop(){
//This code segment reads the current touch screen data (position pressed by the user) and stores the
//x value and the y value.
  if (myTouch.dataAvailable()){          //Get Curent Screen Data
    myTouch.read();
    x = myTouch.getX();
    y = myTouch.getY();
    Serial.print(x);
    Serial.print(" / ");
    Serial.println(y);
//######################## CLOCK ##############################//
// This segment of code starts and draws Clock for all screens
  DateTime now = RTC.now();             //sets Datetime "now" to the current time
  Hours = now.hour();                         //Sets time varibles to Current RTC time
  Minutes = now.minute();
  Seconds = now.second();
  Day = now.day();
  Month = now.month();
  Year = now.year();
  Weekday = now.dayOfWeek();
  Draw_Clock(24, 252);
  //################## sunrise_sunset code ###################//
  Sunrise_set(GetSeconds(Hours, Minutes, Seconds));
  analogWrite(Wht_Ch1, sunValue[0]);
  analogWrite(RBlue_Ch1, sunValue[1]);
  analogWrite(Blue_Ch1, sunValue[2]);
  analogWrite(Wht_Ch_3, sunValue[3]);
  analogWrite(RBlue_Ch2, sunValue[4]);
  analogWrite(Blue_Ch2, sunValue[5]);
  analogWrite(Wht_Ch_3, sunValue[6]);
  analogWrite(RBlue_Ch3, sunValue[7]);
  analogWrite(UV_Ch1, sunValue[8]);
Any thoughts would be appreciated.
econjack
I can't get the code to compile, but nowhere do I see Sunset_Hour set to a value. The assumption the code is making is that it is 0, but it that what you intended? If it is always 0, there's no need for a variable.
SteveHi
Sorry. In deleting all the navigation code, and other code unnecessary to this section I had forgotten a thing or 2.
Also, I had originally had Sunrise_Min, and others = 0...I have changed that back.
This code should compile for you:
Code: [Select]
#include <UTFT.h>
#include <RTClib.h>
#include <Wire.h>
RTC_DS1307 RTC;
//*************** Named Sunrise/sunset Variables **************************//
//###########################################      $Global Varibles      #############################[#VAR]
//###   Touch Screen Varibles  ########################
int x, y;
int Hours;
int Minutes;
int Seconds;
int Day;
int Month;
int Year;
int Weekday;
boolean Was_day;
int Sunrise_Hour = 0;
int Sunrise_Min = 0;
int Sunrise_Sec = 0;
int Sunset_Hour = 0;
int Sunset_Min = 0;
int Sun_level = 0;
    (0, 0, 9, 15, 0),
    (19, 15, 24, 0, 0),
    (0, 0, 8, 0, 0),
    (20, 30, 24, 0, 0),
    (0, 0, 8, 45, 0),
    (20, 0, 24, 0, 0),
    (0, 0, 9, 30, 0),
    (19, 30, 24, 0, 0),
    (0, 0, 8, 15, 0),
    (20, 45, 24, 0, 0),
    (0, 0, 9, 0, 0),
    (8, 15, 24, 0, 0),
    (0, 0, 9, 45, 0),
    (19, 30, 24, 0, 0),
    (0, 0, 8, 30, 0),
    (21, 0, 24, 0, 0),
    (0, 0, 7, 45, 64),
void setup(){
  myGLCD.clrScr();
  Wire.begin();
void loop(){
    myTouch.read();
    x = myTouch.getX();
    y = myTouch.getY();
    Serial.print(x);
    Serial.println(y);
  Day = now.day();
  Year = now.year();
Thanks for looking!
SteveHi
Maybe someone could just answer this for me.
In this statement
int sunMatrix [CHANNELS][MAXPERIODS][5]
CHANNELS is the index to array for all included PWM pins in the matrix
MAXPERIODS is the index to array for timing periods within the matrix
5 = ?
What does the 5 index?
