Topic: Chiefstons Planted Tank controller proj (Read 2806 times) previous topic - next topic
Chiefston
May 15, 2013, 09:05 am Last Edit: May 15, 2013, 09:21 am by Chiefston Reason: 1
Hey all,
I have gotten started on my own planted tank controller which will control my newest addition, an ADA 60P tank sitting on a custom stand I have built.  As I am a complete newb programmer, and this project is definitely overambitious, I have decided to chronicle my labors here.  Also, if the good people of the community would like to help clean up my newbie code, I would be grateful  :D  I have been working on this for about a week in my spare time, so some of the things I wish to accomplish are in place.  Others are waiting on parts to arrive, and time to get to them! So...
My basic goals are:
 - Record temperature of the tank, using 2-wire thermistor from adafruit
 - Have 20x4 LCD for display
 - Automate injection of Micro and Macro nutrients on alternating days
   - This will require a peristaltic pump, hall-effect flow meter, and alarms
   -  The flow meter will keep track of injection amount and also amount left in nutrient bottle
 - A small piezo buzzer to warn when nutrient solution is getting low
As mentioned, I have already gotten started.  I intend to update this topic whenever I manage to get a new state completed.  Today I was able to get my nutrient solution levels stored on the DS1307 SRAM, retrieve it, and then post a graphical representation on the LCD.  Doesn't sound like much, but it was a pretty big pain!  Reading others code really only gets you so far, then its all experimentation and slamming your head against the desk  :0
Well, heres the code in its current form, the next task to handle is allowing myself to set the time using the pushbuttons, and having it update the RTC.  Hope you all enjoy the posts!
Code: [Select]
The LCD circuit for reference
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
// include the library code:
#include <LiquidCrystal.h>
#include <Wire.h>
#include <DS1307RTC.h>
#include <Time.h>
#include <Bounce.h>
// Definitions for the thermistor code, copied from learn.adafruit.com
#define THERMISTORPIN A0
#define THERMISTORNOMINAL 10000
#define TEMPERATURENOMINAL 25
#define NUMSAMPLES 10
#define BCOEFFICIENT 3950
#define SERIESRESISTOR 9940
// Global variables, or a convienent place to put stuff
int samples[NUMSAMPLES];  // Used in thermistor calc
float temp;  // Used in thermistor calc
int enterPin = 7;  // Pin def
int movePin = 8;   // Pin def
int screen = 1;  // This is for state machine
int z = 0;  // whatever variable
boolean yesNo = true;  // used for selection menus
int btl1maxlvl = 2000;  // Will hold Micro full bottle mL
int btl2maxlvl = 2000;  // Will hold Macro full bottle mL
byte updatebottles;  // Used in function to update bottles once a min.
//setup debounce functions
Bounce bounceEnter = Bounce(enterPin, 50);
Bounce bounceMove = Bounce(movePin, 50);
// Create custom characters for bottle levels and underline
byte lowLvl[8] = {
 0x0,0x0,0x0,0x0,0x0,0x0,0x1f
byte highLvl[8] = {
 0x0,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f
byte midLvl[8] = {
 0x0,0x0,0x0,0x1f,0x1f,0x1f,0x1f
byte underline[8] = {
 0x1f,0x0,0x0,0x0,0x0,0x0,0x0
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
******* Setup **************
 // Setup input pins
 pinMode(enterPin, INPUT);
 pinMode(movePin, INPUT);
 digitalWrite(enterPin, HIGH);
 digitalWrite(movePin, HIGH);
 // setup custom char
 lcd.createChar(0, lowLvl);
 lcd.createChar(1, highLvl);
 lcd.createChar(2, midLvl);
 lcd.createChar(3, underline);
 // set analogRead to 3.3v
 analogReference(EXTERNAL);
 // set up the LCD's number of columns and rows:
 lcd.begin(20, 4);
 lcd.clear();
 // setup RTC
 setSyncProvider(RTC.get);
 Wire.begin();
 // Simulating values stored for mL left in fert bottles
 WriteRam(1, 1134);
 WriteRam(2, 1025);
******* Loop ***************
 // State machine
 switch (screen) {
 case 1:
   mainScreen();
 case 2:
   resetBottle();
 case 3:
   whichBottle();
 case 4:
   setAlarm();
******* MainScreen *********
void mainScreen() {
 time_t t = now();
 lcd.setCursor(0, 0);
 lcd.print("Temperature :");
 lcd.print(getTemp()); // Get temp from thermistor
 lcd.print((char)223); // Degree symbol
 // Print Time
 lcd.setCursor(6, 1);
 if (hour(t) < 10) {  // Formatting the hour correctly
   lcd.print("0");
 lcd.print(hour(t));
 lcd.print(":");
 if (minute(t) < 10) {  // Formatting the minutes correctly
   lcd.print("0");
 lcd.print(minute(t));
 lcd.print(":");
 if (second(t) < 10) {  // Formatting the seconds correctly
   lcd.print("0");
 lcd.print(second(t));
 // Print fertilizer levels
 SetLevel(second(t));
 // Get enter button press
 if (bounceEnter.update()) {
   if (bounceEnter.read() == LOW) {
     lcd.clear();
     screen = 2;  // Enter takes us to ResetBottle screen
****** resetBottle() *******
void resetBottle() {
 lcd.setCursor(5,0);
 lcd.print("Reset bottle?");
 lcd.setCursor(2, 2);
 lcd.print("Yes     /     No");
 // Print out underline characters for selection purposes
 if (yesNo == true) {
   lcd.setCursor(16,3);
   lcd.print("   ");
   lcd.setCursor(2, 3);
   for (z=0; z<3; z++) {
     lcd.write(byte(3));
 else {
   lcd.setCursor(2,3);
   lcd.print("   ");
   for (z=0; z<2; z++) {
     lcd.write(byte(3));
 // Check button presses and move on
 if (bounceMove.update()) {
   if (bounceMove.read() == LOW) {
     yesNo = !yesNo;
       screen = 3;
       lcd.clear();
     else {
       screen = 4;
       lcd.clear();
****** whichBottle() *******
void whichBottle() {
 lcd.setCursor(2,0);
 lcd.print("Which bottle?");
 lcd.setCursor(2,2);
 lcd.print("Micro");
 lcd.setCursor(12,2);
 lcd.print("Macro");
 if (yesNo == true) {  // Underline Micro and unselect Macro
   lcd.setCursor(12,3);
   lcd.print("     ");  // Clear previous underline
   lcd.setCursor(2,3);
   for (z=0; z<5; z++) {
     lcd.write(byte(3));  // Writing underline characters
 else {
   lcd.setCursor(2,3);
   lcd.setCursor(12, 3);
 //Check button presses
     yesNo = !yesNo;  // This will change the underline selection
       screen = 1;  // Currently placeholding
       lcd.clear();
     else {
       lcd.clear();
Chiefston
In the future, I will only post updated states.  But for the moment, here is the rest of the code:
Code: [Select]
//***  setAlarm()   ***
void setAlarm(void) {
  lcd.setCursor(2,0);
  lcd.print("Set Dose Alarm?");
  lcd.setCursor(2,2);
    lcd.print("   ");  // Remove previous selection underline
      lcd.write(byte(3)); // Underline new selection
  else {
    lcd.setCursor(2,3);
    lcd.print("   ");  // Remove previous underline
      yesNo = !yesNo;  // Switch selection
        lcd.clear();
      else {
        lcd.clear();
//***  getTemp()    ***
float getTemp() {
  //Thermistor Stuff
  uint8_t i;
  float average;
  // take N samples in a row, with a slight delay
  for (i=0; i< NUMSAMPLES; i++) {
    samples[i] = analogRead(THERMISTORPIN);
    delay(10);
  // average all the samples out
  average = 0;
    average += samples[i];
  average /= NUMSAMPLES;
  // convert the value to resistance
  average = 1023 / average - 1;
  average = SERIESRESISTOR / average;
  // convert to degrees
  float steinhart;
  steinhart = average / THERMISTORNOMINAL;     // (R/Ro)
  steinhart = log(steinhart);                  // ln(R/Ro)
  steinhart /= BCOEFFICIENT;                   // 1/B * ln(R/Ro)
  steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
  steinhart = 1.0 / steinhart;                 // Invert
  steinhart -= 273.15;   // convert to C
  steinhart = (steinhart * 1.8) + 32;  // convert to F
  return steinhart;
//***  WriteRam()   ***
void WriteRam(int address, int data) {
  byte datalow, datahigh;  // Used to write a 2-byte int to SRAM
  datalow = lowByte(data);
  datahigh = highByte(data);
  Wire.beginTransmission(0x68);
  Wire.write((address * 2) + 8);  // (address * 2) used for 2-byte storage
  Wire.write(datalow);
  Wire.write(datahigh);
  Wire.endTransmission();
//***   ReadRam()   ***
int ReadRam(int address) {
  byte datalow, datahigh;  // Used to read a 2-byte int from SRAM
  word data;  // Used to merge 2 bytes into one word
  Wire.requestFrom(0x68, 2);
  datalow = Wire.read();
  datahigh = Wire.read();
  data = word(datahigh, datalow);  // Combines low&high bytes into integer.
  return data;
//***  SetLevel()   ***
void SetLevel(byte t) {
  if (t == updatebottles) {  // Used to only update once a second
    return;
  updatebottles = t;
  int btl1, btl2;
  float percent;
  btl1 = ReadRam(1);
  btl2 = ReadRam(2);
  // Get and set bottle 1 display
  percent = (float) btl1 / (float)btl1maxlvl * 10;  // Get percent full
  percent = percent / 2;  // Used because only 5 characters to display fullness
  int blocks = (int) percent;  // How many full blocks to print
  lcd.setCursor(0,4);
  lcd.print("1:");
  for (int y = 0; y < 5; y++) {
    lcd.write(byte(0));  // Write all low characters as starting point
  lcd.setCursor(2,4);
  for (int y = 0; y < blocks; y++) {
    lcd.write(byte(1));  // This writes the full blocks out
  if ((percent - blocks) > .33 && (percent - blocks) < .66) {
    lcd.write(byte(2));  // Determine if half block used
  if ((percent - blocks) >= .66) {
    lcd.write(byte(1));  // Determine if extra full block used
  // Get and set bottle 2 display
  percent = (float) btl2 / (float)btl2maxlvl * 10;
  lcd.setCursor(13,3);
  lcd.print("2:");
    lcd.write(byte(0));
  lcd.setCursor(15,3);
    lcd.write(byte(1));
    lcd.write(byte(2));
    lcd.write(byte(1));
Chiefston
So, I managed to get the clock set functions kinda working.  For whatever reason, it will only update the RTC on the 2nd pass through the function tmSet();
It never updates correctly on the 1st pass through, but on the 2nd pass, it updates to the first setting... if that makes sense.  (i.e. if I set the clock to 12:41:00 Sat, then set the clock again to 14:49:00 Sun, when I recycle the power it defaults back to the 12:41:00 Sat setting...)
I have included the appropriate functions below.  Any help?
Code: [Select]
  // State machine
  switch (screen) {
  case 1:
    mainScreen();
  case 2:
    resetBottle();
  case 3:
    whichBottle();
  case 4:
    setAlarm();
  case 5:
    printTime();
  case 6:
    tmSet();
//***  printTime()  ***
void printTime() {
  hr = hour(t), mn = minute(t), sc = 0, dy = weekday(t);
  // Print Time
  lcd.setCursor(3, 1);
    lcd.print("0");
  lcd.print(hour(t));
  lcd.print(":");
    lcd.print("0");
  lcd.print(":");
    lcd.print("0");
  lcd.setCursor(14,1);
  lcd.print(dayName[dy]);
  screen = 6;
******** tmSet() ********
void tmSet() {
  switch (digit) {
  case 1:    // Set hours
    lcd.setCursor(3,2);    // Set cursor for underline
    lcd.write(byte(0));    // Print underline twice for 2 hour digits
    lcd.write(byte(0));
    lcd.setCursor(3,1);
    if (hr < 10) {  // Formatting the hour correctly
      lcd.print("0");
    lcd.print(hr);
    // Get button presses
        hr++;
        if (hr == 24) hr = 0;  // update hr
        setTime(hr, minute(t), sc, day(t), month(t), year(t));
        digit = 2;
        lcd.setCursor(3,2);  // Erase underline character for next
        lcd.print("  ");
  case 2:    // Set minutes
    lcd.setCursor(6,2);    // Set cursor for underline character
    lcd.write(byte(0));    // Underline character twice for "12"
    lcd.write(byte(0));
    lcd.setCursor(6,1);
    if (mn < 10) {  // Formatting the hour correctly
      lcd.print("0");
    lcd.print(mn);
        mn++;
        if (mn == 60) mn = 0;  // update mn
        setTime(hr, mn, sc, day(t), month(t), year(t));
        digit = 3;
        lcd.setCursor(6,2);    // Erase underline characters
        lcd.print("  ");
  case 3:    // Set days
    lcd.setCursor(14,2);  // Set cursor for underline
    lcd.write(byte(0));    // Used 3 times to underline "Mon"...
    lcd.write(byte(0));
    lcd.setCursor (14,1);
        dy++;
        if (dy == 8) dy = 0;  // update dy
        setTime(hr, mn, sc, dy, 12, 2013);
        RTC.set(t);
        digit = 1;
        lcd.setCursor(14,2);    // Erase underline characters
        lcd.print("   ");
        screen = 1;
        lcd.clear();
inthebatcave
Good luck with your project, I'm planning on a very similar project myself. I'm looking to do a basic tank controller, to control lighting and temperature, and possibly to do some filter monitoring with tracking differential pressure across the supply and  return on my canister filter.
You might be able to simplify your project a little and skip the hall effect sensors, peristaltic pumps have very consistent flow rates since they are positive displacement and will pump the same volume per revolution every time. You might be able to attach a simple cam and microswitch to the pump shaft and count off ticks to calculate flow.
I just registered this morning to do research on my project, I'm a complete newbie when it comes to arduino, but I have years of experience in HVAC automation and control, so I might be able to help you out a little.
mrpreston
Good morning,, sorry to dig up this old thread but i am having trouble adding the updated code, original sketch complied without errors but when i inserted the new code i get errors,, pretty sure its just a placement issue in my part.
Any help would be greatly appreciated[
Chiefstons.ino: In function 'void printTime()':
Chiefstons:361: error: 'hr' was not declared in this scope
Chiefstons:361: error: 't' was not declared in this scope
Chiefstons:361: error: 'mn' was not declared in this scope
Chiefstons:361: error: 'sc' was not declared in this scope
Chiefstons:361: error: 'dy' was not declared in this scope
Chiefstons:380: error: 'dayName' was not declared in this scope
Chiefstons.ino: In function 'void tmSet()':
Chiefstons:389: error: 'digit' was not declared in this scope
Chiefstons:395: error: 'hr' was not declared in this scope
Chiefstons:398: error: 'hr' was not declared in this scope
Chiefstons:409: error: 't' was not declared in this scope
Chiefstons:409: error: 'sc' was not declared in this scope
Chiefstons:421: error: 'mn' was not declared in this scope
Chiefstons:424: error: 'mn' was not declared in this scope
Chiefstons:435: error: 'sc' was not declared in this scope
Chiefstons:435: error: 't' was not declared in this scope
Chiefstons:448: error: 'dayName' was not declared in this scope
Chiefstons:448: error: 'dy' was not declared in this scope
Chiefstons:458: error: 'sc' was not declared in this scope
Chiefstons:459: error: 't' was not declared in this scope
errors starting near ******** tmSet() ********    (see code below)
quote author=Chiefston link=msg=1241659 date=1368687693]
Code: [Select]
  // State machine
  switch (screen) {
  case 1:
    mainScreen();
  case 2:
    resetBottle();
  case 3:
    whichBottle();
  case 4:
    setAlarm();
  case 5:
    printTime();
  case 6:
    tmSet();
void printTime() {
  // Print Time
    lcd.print("0");
  lcd.print(hour(t));
  lcd.print(":");
    lcd.print("0");
  lcd.print(":");
    lcd.print("0");
  screen = 6;
void tmSet() {
  switch (digit) {
    lcd.write(byte(0));
    lcd.setCursor(3,1);
      lcd.print("0");
    lcd.print(hr);
        hr++;
        digit = 2;
        lcd.print("  ");
    lcd.write(byte(0));
    lcd.setCursor(6,1);
      lcd.print("0");
    lcd.print(mn);
        mn++;
        digit = 3;
        lcd.print("  ");
  case 3:    // Set days
    lcd.write(byte(0));
        dy++;
        RTC.set(t);
        digit = 1;
        lcd.print("   ");
        screen = 1;
        lcd.clear();
[/quote]
