Topic: Problem with Servo. I/OException (Read 859 times) previous topic - next topic
elseine
May 15, 2013, 12:00 pm Last Edit: May 15, 2013, 12:39 pm by elseine Reason: 1
Hello. I am using Arduino One with a Servo. I make the circuit like this: http://arduino.cc/en/uploads/Tutorial/sweep_BB.png
with this code:
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
int val = 0;
 myservo.attach(10);  // attaches the servo on pin 10 to the servo object
 while(Serial.available()==0){}
 pos=Serial.parseInt();
 myservo.write(pos);
 Serial.print(pos);
So, when I put a number in the monitor, the servo turns in that degrees. The problem is: when I introduce a number, give me that:
java.io.IOException: Error de entrada/salida in writeArray
   at gnu.io.RXTXPort.writeArray(Native Method)
   at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1124)
   at processing.app.Serial.write(Serial.java:517)
   at processing.app.Serial.write(Serial.java:540)
   at processing.app.SerialMonitor.send(SerialMonitor.java:200)
   at processing.app.SerialMonitor.access$100(SerialMonitor.java:32)
   at processing.app.SerialMonitor$3.actionPerformed(SerialMonitor.java:89)
   at javax.swing.JTextField.fireActionPerformed(JTextField.java:508)
   at javax.swing.JTextField.postActionEvent(JTextField.java:721)
   at javax.swing.JTextField$NotifyAction.actionPerformed(JTextField.java:836)
   at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1661)
   at javax.swing.JComponent.processKeyBinding(JComponent.java:2870)
   at javax.swing.JComponent.processKeyBindings(JComponent.java:2917)
   at javax.swing.JComponent.processKeyEvent(JComponent.java:2833)
   at java.awt.Component.processEvent(Component.java:6282)
   at java.awt.Container.processEvent(Container.java:2229)
   at java.awt.Component.dispatchEventImpl(Component.java:4861)
   at java.awt.Container.dispatchEventImpl(Container.java:2287)
   at java.awt.Component.dispatchEvent(Component.java:4687)
   at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1895)
   at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:762)
   at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1027)
   at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:899)
   at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:727)
   at java.awt.Component.dispatchEventImpl(Component.java:4731)
   at java.awt.Window.dispatchEventImpl(Window.java:2719)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:729)
   at java.awt.EventQueue.access$200(EventQueue.java:103)
   at java.awt.EventQueue$3.run(EventQueue.java:688)
   at java.awt.EventQueue$3.run(EventQueue.java:686)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
   at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
   at java.awt.EventQueue$4.run(EventQueue.java:702)
   at java.awt.EventQueue$4.run(EventQueue.java:700)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:699)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
And I dont know why. Another problem that I have, is that the Servo dont follow the instructions. When I only put servo.write(45), it starts turn aroung with no pause.
Anyone knows why?
Thank you.
EDIT: I add some images of my circuit.
AWOL
Quote
Uh-oh...this sounds like an ex-servo, aka "continuous rotation servo".
Are you saying it never hits hard end-stops?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
elseine
#2
May 15, 2013, 12:14 pm Last Edit: May 15, 2013, 12:16 pm by elseine Reason: 1
Quote
Yes, it stops, sorry. He stop at the limit, and then, turn to the other side until he finally stops in an arbitrary position.
EDIT: Oh, and another thing. Aleatory, he starts moving in a tiny range and stops, and maybe has passed more than a minute without move.
AWOL
Have you connected the ground to the Arduino?
How are you powering the servo?
elseine
Yes, the ground is conected and the servo is powered with the pin of 5V.
AWOL
Have you tried just running the servo sweep demo?
You should not really be running the servo off the 5V pin. Try powering the servo from four AA batteries, and remember to connect the grounds.
elseine
Yes, i tried the servo sweep demo and dont work. Why is not good idea to use 5V? And how I power it with four AA?
Arrch
Because the servos can draw more current than the Arduino's 5V pin can comfortably source.
Quote
By connecting the four AA batteries in series to the Servo.
elseine
Quote
I have a HK15298 Servo. It need the bateries too?  Now i am using the USB power.
Arrch
What do you mean by "too"? Do you have more than one servo? USB power is fine for the Arduino, but not for the Servo.
