Topic: Matrix keypad library not working Properly (Read 787 times) previous topic - next topic
khkarthik
In the below Program "Release" and "Idle" are not working...
i have connected all rows and columns correctly...
ANY HELP???????????????????????????
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {8, 7, 6}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
void loop(){
  // Fills kpd.key[] array with up-to 10 active keys.
  // Returns true if there are ANY active keys.
  if (kpd.getKeys())
    for (int i=0; i<LIST_MAX; i++)   // Scan the entire list.
      if (kpd.key.kchar != NO_KEY)    // Test for an active key.
        switch (kpd.key.kstate) {  // Test for key state IDLE, PRESSED, HOLD, or RELEASED
            case HOLD:
                Serial.print("Key ");
                Serial.print(kpd.key.kchar);
                Serial.print(" is being HELD and the state ");
                if (!kpd.key.stateChanged)
                    Serial.println("has not changed.");
                    Serial.println("has changed.");
            case PRESSED:
                Serial.print(" is PRESSED and the state ");
            case RELEASED:
                Serial.print(" has been RELEASED and the state ");
            default:
                Serial.print(" is IDLE and the state ");
}  // End loop
johnwasser
What, exactly, do you mean by 'not working'?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
khkarthik
I have connected the matrix key pad ...and when I press any key....I get the msg on my serial console as "pressed " and when I continue to hold ..I get the msg as "hold "...
but when I release the key...I'm not getting the " release " msg ...
I mean to say that ....in the switch case...the program is never entering the "release " and " idle " case...
I don't know wat could be the problem...either with the code which I've posted.. or with the keypad library ....
AWOL
You're likely to get better help if you observe these simple rules:
Don't cross-post (don't worry, I've deleted the duplicate of this one)
Don't SHOUT or allow your punctuation keys to auto-repeat...
Use code tags when posting code, so your code is legible.
it is all set out here - I'm really surprised you didn't see it.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
johnwasser
My first guess is:
Code: [Select]
  if (kpd.getKeys())
Perhaps a Released key is not considered 'active' so this returns 'false'.
