Topic: Looking for USB Host Shield *WORKING* library (Read 872 times) previous topic - next topic
AlxDroidDev
I've been trying, without any success, to use Felis' USB Host Shield 2.0 Library.
The problem is that this library won't compile in IDE 1.0.4.
My final objective is to have his PTP 2.0 Library working, but none of the examples in that library compile.
So, my question is: can anyone please refer me to a working USB Host Shield library that actually works with IDE 1.0.4 ?
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
johnwasser
I just downloaded the 2.0 library from: https://github.com/felis/USB_Host_Shield_2.0 by clicking on the ZIP button.  I copied USB_Host_Shield_2.0-master.zip into Documents/Arduino/libraries/.  Unzipped the file. Renamed the new USB_Host_Shield_2.0-master folder to 'usbhub'.  Re-started the IDE.  Then File->Examples->usbhub->HID->USBHIDJoystick compiled without error.
Could you have skipped one of those steps?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
AlxDroidDev
#2
May 15, 2013, 06:21 pm Last Edit: May 15, 2013, 06:25 pm by AlxDroidDev Reason: 1
Thanks, John.
That is pretty much what I did. the only difference is that the library folder is inside my sketchbook\libraries folder, so it is visible across all the IDEs I use.
This is what I get when I try to compile that very same sketch:
USBHIDJoystick.pde: At global scope:
USBHIDJoystick:22: error: redefinition of 'USB Usb'
USBHIDJoystick:22: error: 'USB Usb' previously declared here
USBHIDJoystick:23: error: redefinition of 'USBHub Hub'
USBHIDJoystick:23: error: 'USBHub Hub' previously declared here
USBHIDJoystick:24: error: redefinition of 'HIDUniversal Hid'
USBHIDJoystick:24: error: 'HIDUniversal Hid' previously declared here
USBHIDJoystick:25: error: redefinition of 'JoystickEvents JoyEvents'
USBHIDJoystick:25: error: 'JoystickEvents JoyEvents' previously declared here
USBHIDJoystick:26: error: redefinition of 'JoystickReportParser Joy'
USBHIDJoystick:26: error: 'JoystickReportParser Joy' previously declared here
USBHIDJoystick.pde: In function 'void setup()':
USBHIDJoystick:28: error: redefinition of 'void setup()'
USBHIDJoystick:28: error: 'void setup()' previously defined here
USBHIDJoystick.pde:39: warning: only initialized variables can be placed into program memory area
USBHIDJoystick.pde: In function 'void loop()':
USBHIDJoystick:42: error: redefinition of 'void loop()'
USBHIDJoystick:42: error: 'void loop()' previously defined here
I know some of those messages make absolutely no sense.
I've made sure there are no other USB-like libraries in use.
Also, I've tried the above in 2 IDEs, with the same unsuccessful results: Arduino 1.0.3 and ERW 1.0.3
