Topic: Arduino restarts when DC motors are turned on (Read 2875 times) previous topic - next topic
TheNonbeing
Hello!
My robot's various circuits (sensor arrays, motor controller, indicators+LCD, Arduino, ..) are powered form the single supply point via dedicated voltage regulators -78xx (with decoupling capacitors). When I make Arduino turn on the DC motors, it restarts. (If the Arduino is powered from USB -no problem).
Arduino model: Mega2560
Power supply: 7.5V from a power regulator (Imax > 2A)
Motor controller circuit
IC: L298
V. regulator: L7809CV (Imax = 1.5A)
Decoupling capacitors: 0.47uF & 3.3uF at IN and 0.1uF at OUT
Motors: 2 x DC 9V cassette motors
I think the fairly large current draw from motors at start up makes the Arduino's supply go wonky. Will it help if I added ..maybe a 220uF cap at IN of Motor controller's regulator? Or is it something else?
Thanks.
AlxDroidDev
Try starting them using PWM on the EN pins of the L298.
I do this with my L293D: instead of simply setting EN to high when I want to turn on the motors, I use PWM on the EN pin (that's why I had the L293D EN1 and EN2 pins connected to PWM pins on the Arduino).
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
TheNonbeing
semicolo
Yes try a big capacitor on the motor supply rail.
You say your supply is 7.5V but you use a 7809 regulator, do you have a DC/DC converter somewhere to convert the 7.5V to something greater than 9V to feed the regulator?
TheNonbeing
Thanks you for the reply! :)
What value of cap would you suggest?
No actually, I temporarily lowered voltage down to 7.5V because a couple of 7805s (in different sections) started heating up rather rapidly (@12V and to a lesser extent @9V) and I don't have decent heat-sinks to fit inside the cramped space of the chassis. Could this be the cause of my problem?
semicolo
#5
May 15, 2013, 09:09 pm Last Edit: May 15, 2013, 09:10 pm by semicolo Reason: 1
try 100 or 220 uF
Well you've got a problem because the 7809 is supposed to regulate a voltage higher than 11V to 9V but you're feeding it 7.5V, you could remove it completely since it's just in the way.
And I dont't think the L298 has flywheel diodes, did you add some?
TheNonbeing
I'm going to change the supply back to 9V or 12V once I can find heat-sinks that will fit inside the chassis and have decent cooling properties.
Yes, a bunch of 4148s.
terryking228
Hi, you may also be getting other types of EMI (Electro Magnetic Interference)
There are some hints on the http://ArduinoInfo.Info WIKI here: http://arduino-info.wikispaces.com/RelayIsolation
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
MarkT
Its likely the motor start-up current spike is pulling the supply down to about 0V briefly.
Simplest solution: use a separate supply for the motor(s).
TheNonbeing
I still haven't got around to fixing it.  :P
If adding a cap doesn't work, I'll focus on further reducing EMI. Using two sources though is out of the question.
Thank you for the suggestions!
zoomkat
I doubt that the above will fix your problem. You might consider getting two UBECs on ebay for powering the arduino and motors from the same power source. I use the below setup to prevent the servos from causing a low voltage drop out of the servo chip when the servo motors start.
