Topic: Micro Robot Arm: Question about arm joints (Read 3491 times) previous topic - next topic
nass
Hello,
I'm dithering between using a small stepper of a geared DC worm drive to rotate subsequent limbs of a micro robot arm (15 cm high). Can anyone point me at any reference sites or blogs which might show me some of the options for connecting the drive and gears between micro arm segments? I'm unsure whether to go for a worm drive, a bevel gearbox or if there is some other option that I'm not as yet aware of that gives highly geared rotational movement on a subsequent arm segment.
Thank you for your time
groundFungus
I would lean to the worm drive because when the motor is off the weight won't move the arm by turning the moter backward.  you don;t need to brake the motor to hold position.
nass
Hello groundfungus,
Thank you very much, that's exactly what I was thinking too. My thing needs a very steady arm driven by a motor so this would look apt. I don't suppose you happen to know of any suppliers of tiny worm gears that'll fit onto a 3mm d shaft?
Thanks again
groundFungus
I'm sorry to say that I don't.
Charlie
justone
Maybe something like this might do.
http://www.pololu.com/catalog/product/69
groundFungus
Darn good price and adaptable for gear ratio.  The worm certialnly looks steep enough so that it won't be moved by weight alone.  with metal final gears,too.  If they provide enough torque?
AWOL
Quote
Photography nut trying to make the flux capacitor of macro photography
Wow!
Can I ask how long it takes to make stacks like that?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
nass
#7
May 17, 2013, 10:13 pm Last Edit: May 17, 2013, 10:15 pm by nass Reason: 1
Wow!
Thank you! It all depends on the depth of the stack - a 300 image stack might take me anything upwards of 8 hrs or so, preparation (1hr), shooting (2 hr), stacking & substacking (4 hr), postprocessing (1 hr). Example below for those who don't have the first clue what this talk of stacking is all about, not an especially deep stack.
In fact my entire Arduino adventure is for this, my aim is to build a universal stage driven by motors inside a Peltier chamber. Hence the need for small but torquey motors :)
Extreme Hoverfly by Johan J.Ingles-Le Nobel, on Flickr
AWOL
I'm amazed how you keep the subjects so clean - I used to shoot macro with my Pentax bellows, but the merest hint of dust or pollen or fluff ruined shots.
Those really are beautiful shots.
