Topic: Controlling LED from a PC (Read 993 times) previous topic - next topic
con_lambrou
Hi all, pretty new at this, been playing with arduino for a couple of weeks now, the arduino code seems pretty straight forward but trying to kill two birds with one stone here and also learn c++, would like to control the LED (switch on and off) on the arduino board from a pc via the usb port, anybody written a c++ windows application? If so what compiler was used and does anybody have the code? I haven't done C++ programming in about 15 years.
Thank you in advance.
gnusci
This can be a good place for you to start
http://www.techideas.co.nz/
gnusci
maxwelltsai1987
I think I have the same problem too. I think Serial Communication is the best way. My post: http://forum.arduino.cc/index.php?topic=167042.0
gnusci
#3
May 19, 2013, 05:48 pm Last Edit: May 19, 2013, 05:54 pm by gnusci Reason: 1
You will need something like WinAVR:
http://winavr.sourceforge.net/
And AVRDUDE:
http://www.nongnu.org/avrdude/
You can also use Firmata to do that:
https://github.com/eetorres/fl_firmata
gnusci
anlsoft
i did some in VB6, controling 16 channel relay.
If you want it, just ask, and i will give it to you, the vb6 files, the exe file, and arduino file.
dataino
and why not using an ethernet shield? and a online database?
www.dataino.it
