Topic: Help me make sense of these bits (Read 586 times) previous topic - next topic
fuzail
i am trying to decode an air conditioner IR remote. and i could use some help understand how these bits are set
i have 2 possible sets of data, depending on how the incoming data interpreted. the are bits are just inverted in each of the sets.
18c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000100,10000000,00000000,00000000,00000000,00000000,11110101
19c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001100,10000000,00000000,00000000,00000000,00000000,11111001
20c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000010,10000000,00000000,00000000,00000000,00000000,11110001
21c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001010,10000000,00000000,00000000,00000000,00000000,11111110
22c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000110,10000000,00000000,00000000,00000000,00000000,11110110
23c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001110,10000000,00000000,00000000,00000000,00000000,11111010
24c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000001,10000000,00000000,00000000,00000000,00000000,11110010
25c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001001,10000000,00000000,00000000,00000000,00000000,11111100
26c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000101,10000000,00000000,00000000,00000000,00000000,11110100
27c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001101,10000000,00000000,00000000,00000000,00000000,11111000
28c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000011,10000000,00000000,00000000,00000000,00000000,11110000
29c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00001011,10000000,00000000,00000000,00000000,00000000,11111111
30c-00101000,11000110,00000000,00001000,00001000,00111111,00010000,00001100,00000111,10000000,00000000,00000000,00000000,00000000,11110111
now i noticed that only 2 bytes of data are getting changed with every increment in temperature.
the first byte of data, this is what i believe is manipulating the temperature.
00000100 at 18
00001100 at 19
00000010 at 20
00001010 at 21
00000110 at 22
00000110 at 23
00001110 at 24
00000001 at 25
00001001 at 26
00000101 at 27
00001101 at 28
00000011 at 29
00001011 at 30
00000111 at 20
the second byte of data that changes is
11110101
11111001
11110001
11111110
11110110
11111010
11110010
11111100
11110100
11111000
11110000
11111111
11110111
the first byte that changes is a representation of the temperate in some way. the range for the temperatures is 18 to 30.
the second byte that changes i believe is some kind of check sum of the entire message.
i am weak when it comes to binary operations.
could someone please help me understand how the value of temperate is being manipulated ?
and also how the final byte is related to the entire message.
AWOL
00000100 at 18
00001100 at 19
00000010 at 20
00001010 at 21
Does it make more sense if you reverse the bits, and possibly subtract an offset?
fuzail
i didn't think of that.
ill try to see if that is a possible.
tobyb121
It looks as though the second byte is some sort of sequence number, if you discard the highest 4 bits (all 1111) and reverse the order of the lower 4 bits you get:
1010
1001
1000
0111
etc.
which is just decrementing. When it gets to 0000 it underflows (is that a word?) and goes back to 1111
fuzail
#4
May 17, 2013, 12:35 pm Last Edit: May 17, 2013, 12:45 pm by fuzail Reason: 1
thank you very much awol.!
you suggestion went a very long way in helping me solve this.
it turns out that my bit interpretation was wrong.
now with the inverted bits the entire data becomes
18c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111011,01111111,11111111,11111111,11111111,11111111,00001010
19c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110011,01111111,11111111,11111111,11111111,11111111,00000110
20c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111101,01111111,11111111,11111111,11111111,11111111,00001110
21c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110101,01111111,11111111,11111111,11111111,11111111,00000001
22c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111001,01111111,11111111,11111111,11111111,11111111,00001001
23c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110001,01111111,11111111,11111111,11111111,11111111,00000101
24c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111110,01111111,11111111,11111111,11111111,11111111,00001101
25c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110110,01111111,11111111,11111111,11111111,11111111,00000011
26c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111010,01111111,11111111,11111111,11111111,11111111,00001011
27c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110010,01111111,11111111,11111111,11111111,11111111,00000111
28c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111100,01111111,11111111,11111111,11111111,11111111,00001111
29c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11110100,01111111,11111111,11111111,11111111,11111111,00000000
30c-11010111,00111001,11111111,11110111,11110111,11000000,11101111,11110011,11111000,01111111,11111111,11111111,11111111,11111111,00001000
the relevant data becomes
1011
0011
1101
0101
1001
0001
1110
0110
1010
0010
1100
0100
1000
now reversing the bits gets me decimal numbers from 13 to 1.
subtracting the decimal value from 31 gives me the temperature setting required.
thanks AWOL
any clues on the last byte of data ?
how is that byte related to the rest of the data ?
fuzail
1010
1001
1000
0111
etc.
toby, i am pretty sure that the last byte in the whole data is related to the every other byte before it. i just don't know how.
i think it is some sort of error checking, to make sure that the entire data gets transmitted correctly.
however i will try to make some sense of it, using what you suggested.
