Topic: i need some help in g lcd with a keypad 4x4 (Read 4210 times) previous topic - next topic
mostafa_zied
i have a graphical lcd and i want to connect it with keypad
i use this library "u8glib" for the graphical lcd and it is work correctly
but when i interface it with a (4*4) keypad
it not work correctly
it delay too much !!!it's need to press 8 times to show the number in the g. lcd
HazardsMind
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
mostafa_zied
Code: [Select]
#include "U8glib.h"
#include <Keypad.h>
U8GLIB_T6963_240X128 u8g(49, 48, 47, 46, 45, 44, 43, 42, 35, 34, 37, 36, 16);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','a'},
  {'4','5','6','b'},
  {'7','8','9','c'},
  {'#','0','*','d'}
byte rowPins[ROWS] = {A3, A2, A1, A0}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A8, A7, A5, A4}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int val; // Y value (Read from the Analog input)
int xPos = 0; // X position
int prevXPos = 0; // Previous x position
int scanVal[128]; // Array to hold the graphs values as it scans.
int xDraw; // Used to
int p =0;
int oldvalue =0 ;
int newvalue =0 ;
int a =0;
int b =0;
int c =0;
int t =0;
int i =0;
int D =0;
int h =0;
int drflowrate = 0 ;
int timesolenoid = 0 ;
const int buttonPin1 = 9;
const int buttonPin2 = 8;
int vaul1;
int vaul2;
void drawText(void) {
  val = analogRead(A0);// Poll ADC
  val = map(val,0,1023,63,0);// Scale things down to fit the vertical pixel count of the LCD.
  scanVal[xPos] = val;// Write the Y value to the appropriate element (X value).
  u8g.setPrintPos(100, 100);// Set Cursor.
  u8g.print("Y");
  p = ((val-0.2)/0.09);
  u8g.print(p);// Print out the Y value.
  u8g.print("kp");
  u8g.setPrintPos(20, 100);// Set Cursor.
  u8g.print("X");
  u8g.print(xPos);// Print out the X value.
void drawScan(void) {// This function cycles 128 times per update to draw the full scan of the line.
  val = scanVal[xDraw];// Pull the Y value from the appropriate element.
  newvalue = val;
  u8g.drawLine(xDraw,oldvalue,xDraw+1,newvalue);// Set a pixel.
  xDraw++;// Increment the column position (X value).
  oldvalue = newvalue ;
}// End of scan
void setup(void)
  u8g.setRot180();// Flip screen
  u8g.setFont(u8g_font_6x10r);// Set Font
  u8g.setPrintPos(1, 1);// Set Cursor.
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
void draw ()
{                vaul1 = digitalRead(buttonPin1);
                 vaul2 = digitalRead(buttonPin2);
                 u8g.setPrintPos(1, 10);// Set Cursor.
                 u8g.print("pleas choose the mode from the following");
                 u8g.setPrintPos(1, 30);// Set Cursor.
                 u8g.print("press 'f1'for 'CMV' ");
                 u8g.setPrintPos(1, 50);// Set Cursor.
                 u8g.print("press 'f2' for 'SIMV'");
                 u8g.setPrintPos(1, 70);// Set Cursor.
                 u8g.print("press'f3' for 'cpap'");
                 char key = customKeypad.waitForKey();
                 if (key !=NO_KEY)
                 if (key == a)
                        u8g.setPrintPos(130, 10);// Set Cursor.
                        u8g.print("the mode selected is CMV ");
                                 if (i==0)
                                        char keym = customKeypad.waitForKey();
                                        if (keym !=NO_KEY)
                                               u8g.setPrintPos(130, 30);// Set Cursor.
                                               u8g.print(keym);
                                               const char keya [2]={keym , '\n'};
                                               a = atoi (keya)*1000;
                                               i=1;
                                 if (i==1)
                                        char keyn = customKeypad.waitForKey();
                                        if (keyn !=NO_KEY)
                                            u8g.setPrintPos(134,30);// Set Cursor.
                                            u8g.print(keyn);
                                            const char keyb [2] = {keyn , '\n'};
                                            b = atoi(keyb)*100;
                                            i=2;
                                if (i==2)
                                      char keyz = customKeypad.waitForKey();
                                      if (keyz !=NO_KEY)
                                          u8g.setPrintPos(138,30);// Set Cursor.
                                          u8g.print(keyz);
                                          const char keyc[]={keyz ,'\n'};
                                          c =atoi(keyc)*10;
                                          i=3;
                                 if (i==3)
                                      char keyH = customKeypad.waitForKey();
                                      if (keyH !=NO_KEY)
                                           u8g.setPrintPos(142,30);// Set Cursor.
                                           u8g.print(keyH);
                                           const char keyh[]={keyH ,'\n'};
                                           int h =atoi(keyh);
                                           i=4;
                                  if (i == 4)
                                        drflowrate = a+c+b+h ;
                                        timesolenoid = (drflowrate * 60)/10000 ;
                                        u8g.setPrintPos(150, 100);// Set Cursor.
                                        u8g.print("drflowrate");
                                        u8g.print(drflowrate);// Print out the number of the flowrate value.
                                        u8g.print("timesolenoid");
                                        i=0;
                                       delay (3000);
void loop(void) {
   u8g.firstPage();
   do
               draw();
               } while( u8g.nextPage() );
HazardsMind
1) Use Ctrl + T to Auto Format your code!
2) What Arduino are you using that has 9 analog inputs? "byte colPins[COLS] = {A8, A7, A5, A4}; "
3) int p =0; Why are making P an int, but you are using floats here, "p = ((val-0.2)/0.09);" ???
4) I would condense these, unless you want to show it like this
Quote
5) Problem here, if (key == a), it should be if (key == 'a') it needs single quotes ' '  Do the same for the rest of them.
6) Take out the delays
My GitHub:
mostafa_zied
first thanx for your replies
i upgrade the code as you say
and i used the serial monitor to debug the values and the cod it's work correctly but without any show in the glcd
i check the connection it's okey and i use a default program to show a "hallow world "  it's work!!!
but with this code no shows in the glcd  :~  :~  :smiley-sad-blue:
Code: [Select]
#include "U8glib.h"
#include <Keypad.h>
    '1','2','3','a'      }
    '4','5','6','b'      }
    '7','8','9','c'      }
    '#','0','*','d'      }
  A0, A1, A2, A3}; //connect to the row pinouts of the keypad
  A4, A5, A6, A7}; //connect to the column pinouts of the keypad
float p ;
int oldvalue =0 ;
int newvalue =0 ;
int a =0;
int b =0;
int c =0;
int t =0;
int i =0;
int D =0;
int h =0;
  u8g.print("Y");
  u8g.print("kp");
  u8g.print("X");
  newvalue = val;
}// End of scan
void setup(void)
  if ( u8g.getMode() == U8G_MODE_R3G3B2 )
    u8g.setColorIndex(255);     // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
    u8g.setColorIndex(3);         // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW )
    u8g.setColorIndex(1);         // pixel on
void draw ()
  u8g.setFont(u8g_font_unifont);
  u8g.drawStr( 1, 10, "pleas choose the mode ");
  u8g.drawStr( 1, 30, "press 'f1'for 'CMV' ");
  u8g.drawStr( 1, 50, "press 'f2' for 'SIMV' ");
  u8g.drawStr( 1, 70, "press 'f2' for 'SIMV' ");
  int mod = customKeypad.waitForKey();
  if (mod !=NO_KEY)
    Serial.println("key");
    if (mod == 'a')
      Serial.println("helow");
      u8g.drawStr( 1, 1, "        ");
      u8g.drawStr( 10, 10, "the mode selected is CMV ");
      Serial.println("the mode selected is CMV");
      if (i==0)
        if (keym !=NO_KEY)
          u8g.print(keym);
            keym , '\n'                              };
          Serial.println(keym);
          i=1;
      if (i==1)
        if (keyn !=NO_KEY)
          u8g.setPrintPos(130, 34);
          u8g.print(keyn);
            keyn , '\n'                              };
          b = atoi(keyb)*100;
          Serial.println(keyn);
          i=2;
      if (i==2)
        if (keyz !=NO_KEY)
          u8g.setPrintPos(130, 38);
          u8g.print(keyz);
          const char keyc[]={
            keyz ,'\n'                              };
          c =atoi(keyc)*10;
          Serial.println(keyz);
          i=3;
      if (i==3)
        if (keyH !=NO_KEY)
          u8g.setPrintPos(130, 42);
          u8g.print(keyH);
          const char keyh[]={
            keyH ,'\n'                              };
          h =atoi(keyh);
          Serial.println(h);
          i=4;
      if (i == 4)
        Serial.println(drflowrate);
        u8g.drawStr( 100, 100, "drflowrate");
        u8g.setPrintPos(150, 114);
        i=0;
void loop(void) {
  u8g.firstPage();
  do
    draw();
HazardsMind
#7
May 23, 2013, 06:37 pm Last Edit: May 23, 2013, 06:41 pm by HazardsMind Reason: 1
int mod = customKeypad.waitForKey(); Needs to be char, not int.
What does the screen show, do you see anything at all?
My GitHub:
mostafa_zied
the screen not refresh the show to the new data until i press more than 4 times in the keypad and when it show it's show a part from it it's like " THE MODE" it's show the upper part of the litters and the lower part not appear
where is the problem ???
then i need to know how i can  the screen when i need ??
HazardsMind
Quote
Something like this should never be used to clear a line, unless you know how much to clear. This is TOO much white space and it will cause many visual issues.
My GitHub:
HazardsMind
Here are two functions I'm going to see if I can get put into the new LCD library that I have. You can adapt these to fit to your library.
Code: [Select]
void ClearSect(uint8_t row, uint8_t start, uint8_t stop)
  for(start; start !=  stop; start++)
    lcd.setCursor(start, row);
    lcd.print(' ');
void ClearLine(uint8_t row, uint8_t size)
  for(uint8_t start = 0; start < size; start++)
    lcd.print(' ');
My GitHub:
olikraus
The basic problem of your code is this: The draw() procedure does not repeat exactly the same code. Instead the graphics commands depend on the result of the key events. This will never work.
Please have a look at http://code.google.com/p/u8glib/wiki/tmenu. The suggested solution is to separate draw() and keyboard polling (update() procedure in the referenced tutorial).
This should be done once in the setup:
Code: [Select]
"mod" should be global and the check for the key should be in an additional procedure:
Code: [Select]
Oliver
mostafa_zied
sadly nothings works at all
so i used two arduino kits ; one for glcd and the other thing is for keypad .
thanx for your help
but i still need to know >>>>>why ?????? :( :( :( :( :( :(
