Topic: RTC Stopwatch (Read 10343 times) previous topic - next topic
Osiris
Hey everyone,
I've been using the Chronodot V2.1, which is based on the DS3231, and I have it up and running. I wound up using
Code: [Select]
print(time, HEX); to the BCD conversion (honestly, I am not sure if it is a true BCD conversion, but it seems to work without flaw). My next step is to add a stopwatch function for the RTC. Currently, I am able to press a button which returns the current second's time, when I press a second button it will return the difference in seconds pass. However, I am having trouble with the rollovers past 59 seconds (when using Macetech's BCD conversion), and printing it out in HEX format is not always correct (again looks like when it rolls pass 59 seconds, it prints out the actual HEX value), due to BCD conversions.
Some edited code snippet:
Code: [Select]
byte seconds, init_seconds, elap_seconds;
int Timer() {
  elapsedTime();
  seconds=elap_seconds-init_seconds;
int initialTime() {
  /*Wire Code*/
  init_seconds=Wire.read();
int elapsedTime() {
  /*Wire Code*/
  elap_seconds=Wire.read();
Sorry if the code is brief (right now, going off memory), but it does return some expected values. I think my problem is the BCD conversions, so any help or experience here is appreciated.
JChristensen
Pretty hard to help with such a small bit of code. Best to post everything, #includes and all.
JChristensen
#2
May 19, 2013, 03:39 am Last Edit: May 19, 2013, 03:42 am by Jack Christensen Reason: 1
Looks like you are working with the seconds register value from the RTC directly. This is indeed BCD and will have to be converted to decimal before subtracting. Then some modular arithmetic to ensure a positive result. Of course this code only works if the elapsed time never exceeds 59 seconds. I didn't go and dig up Macetech's code, but the BCD-to-Decimal conversion function that I use is below. I'd bet it's very similar if not identical. Printing the hex value is not what you want. That will show the BCD value but can't do the calculation with it.
Code: [Select]
int Timer() {
   elapsedTime();
   seconds = ((60 + elap_seconds) - init_seconds) % 60;
int initialTime() {
   /*Wire Code*/
   init_seconds=bcd2dec(Wire.read());
int elapsedTime() {
   /*Wire Code*/
   elap_seconds=bcd2dec(Wire.read());
* BCD-to-Decimal conversion                                            *
uint8_t bcd2dec(uint8_t n)
   return ((n / 16 * 10) + (n % 16));
robtillaart
maybe this code helps to make your stopwatch - http://playground.arduino.cc/Code/StopWatchClass -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Osiris
#4
May 20, 2013, 04:45 am Last Edit: May 20, 2013, 04:48 am by Osiris Reason: 1
Thanks Rob. I did take a look at that, but I'm trying to see if I can implement the RTC.
Thanks Jack. I printed the HEX value since at first I was only interested in seeing the value (I think my attempt was to return a value in HEX and convert it to an int). Macetech, if I'm understanding their conversion correctly, uses bitwise AND (&) to check against each bit:
Code: [Select]
seconds = (((seconds & 0b11110000)>>4)*10 + (seconds & 0b00001111)); // convert BCD to decimal
I've seen your BCD-Decimal conversion in a few other posts, but as I'm recalling, I thought there might be another way for it to work. I was able to get a correct time lapse until the 59 second mark and is then restarted, which then gives an incorrect difference. I began to work on this by using an if statement to reset the second time, but haven't gone back to working on it. But here is the code I've been working on. I've have been going back and forth with a few things, so it has gone through some different versions (I was using Macetech's conversion during the last version, seen below).
Code: [Select]
#include <Wire.h>
const int button1 = 2;
const int button2 = 3;
const int LED = 13;
boolean butt1State;
boolean butt2State;
 Wire.begin();
 pinMode(button1, INPUT_PULLUP);
 pinMode(button2, INPUT_PULLUP);
 pinMode(LED, OUTPUT);
 // clear /EOSC bit
 // Sometimes necessary to ensure that the clock keeps running on just battery power.
 // Once set, it shouldn't need to be reset but it's a good idea to make sure.
 Wire.beginTransmission(0x68); // address DS3231
 Wire.write(0x0E); // select register
 Wire.write(0b00011100); // write register bitmap, bit 7 is /EOSC
 Wire.endTransmission();
 //Below was used for decoding and debugging
 //Serial.print("BIN");Serial.print("\t");Serial.print("DEC");Serial.print("\t");Serial.println("HEX");
 butt1State=digitalRead(button1);
 butt2State=digitalRead(button2);
 if(butt1State==LOW) {
   initialTime();
   Serial.println(init_seconds);
   //Serial.print("\t");Serial.print(init_seconds, DEC);Serial.print("\t");Serial.println(init_seconds, HEX);
 if(butt2State==LOW) {
   elapsedTime();
   Timer();
   digitalWrite(LED, !butt2State);
   Serial.print(elap_seconds);Serial.print("\t");Serial.print(seconds);Serial.print("\t");Serial.print(seconds, BIN);Serial.print("\t");Serial.println(seconds, HEX);
   digitalWrite(LED, LOW);
int Timer() {
int initialTime() {
 Wire.beginTransmission(0x68); // 0x68 is DS3231 device address
 Wire.write(0x00); // start at register
 Wire.requestFrom(0x68, 1);
 while(Wire.available()) {
   init_seconds = Wire.read();
   init_seconds = (((init_seconds & 0b11110000)>>4)*10+(init_seconds & 0b00001111));
   return(init_seconds);
int elapsedTime() {
   elap_seconds = Wire.read();
   elap_seconds = (((elap_seconds & 0b11110000)>>4)*10+(elap_seconds & 0b00001111));
   return(elap_seconds);
This is the first time I'm working with BCD and Decimal conversions, and my issue may also be my math after the conversions. I will attempt your conversion tomorrow.
JChristensen
I'm not clear on your requirement, do you need to time intervals longer than 59 seconds? If so, how long? In order to time longer intervals, more than the seconds register from the RTC will need to be used.
The result of Macetech's conversion will be exactly the same as mine. His may be more efficient, I'm not sure that the modulo operator (%) is always the best in that regard. I should have a look into that.
robtillaart
#6
May 20, 2013, 03:07 pm Last Edit: May 20, 2013, 03:20 pm by robtillaart Reason: 1
macetech's code assumes seconds is in the range 0..59
imho the compiler should be able to optimize this modulo - (n % 16) - as it can also optimize  /16
update:
this is almost fastest conversion I can think of. It replaces the /16*10 with 2 shifts and an addition. The masking still exists
Code: [Select]
int bcd2dec(uint8_t in)
  uint8_t out = (in & 0xF0) >> 1;
  return out + out >> 2 + (in & 0x0F);
Rob Tillaart
JChristensen
Indeed it does, in fact the two approaches turn out to be identical. (I'm always amazed by this compiler when I try to check into something like this, a person really has to jump through some hoops just to ensure everything doesn't get optimized clean away!)
Quote
update:
Code: [Select]
Code: [Select]
00000140 <_Z8bcd2dec1h>:
uint8_t bcd2dec1(uint8_t n)
140: 98 2f        mov r25, r24
142: 92 95        swap r25
144: 9f 70        andi r25, 0x0F ; 15
146: 8f 70        andi r24, 0x0F ; 15
148: 2a e0        ldi r18, 0x0A ; 10
14a: 92 9f        mul r25, r18
14c: 80 0d        add r24, r0
14e: 11 24        eor r1, r1
150: 08 95        ret
00000152 <_Z8bcd2dec2h>:
uint8_t bcd2dec2(uint8_t n)
return ((n & 0b11110000) >> 4) * 10 + (n & 0b00001111);
152: 98 2f        mov r25, r24
154: 92 95        swap r25
156: 9f 70        andi r25, 0x0F ; 15
158: 8f 70        andi r24, 0x0F ; 15
15a: 2a e0        ldi r18, 0x0A ; 10
15c: 92 9f        mul r25, r18
15e: 80 0d        add r24, r0
160: 11 24        eor r1, r1
162: 08 95        ret
00000164 <_Z8bcd2dec3h>:
int bcd2dec3(uint8_t in)
164: 28 2f        mov r18, r24
166: 20 7f        andi r18, 0xF0 ; 240
168: 30 e0        ldi r19, 0x00 ; 0
16a: 8f 70        andi r24, 0x0F ; 15
16c: 90 e0        ldi r25, 0x00 ; 0
16e: 02 96        adiw r24, 0x02 ; 2
170: 02 c0        rjmp .+4      ; 0x176 <_Z8bcd2dec3h+0x12>
172: 35 95        asr r19
174: 27 95        ror r18
176: 8a 95        dec r24
178: e2 f7        brpl .-8      ; 0x172 <_Z8bcd2dec3h+0xe>
17a: c9 01        movw r24, r18
17c: 08 95        ret
robtillaart
Rob Tillaart
Osiris
#9
May 20, 2013, 09:11 pm Last Edit: May 20, 2013, 09:38 pm by Osiris Reason: 1
Thank you very much guys. I apologize if my questions were vague, I had a hard time putting into words exactly what I was looking for. The piece of code I was looking for was this:
Code: [Select]
This would allow the "counter" to count up to 60 seconds and reset to 0 at 60. Here, I only worked with seconds to keep it a bit simpler, and not deal with minutes just yet. So yes, this code is only concerned with intervals of 59 seconds. I am now able to focus on the minutes (and hours) for the rollover time. My Timer function now looks like this:
Code: [Select]
int Timer() {
 elapsedTime();
 if(seconds%60==0) {
   minutes = ((60 + elap_minutes) - init_minutes) % 60;
 if(minutes%24==0) {
   hours = ((24 + elap_hours) - init_hours) % 24;
When a full 60 seconds pass, it rolls over to minutes, and continues counting seconds.
The code I know have is below:
Code: [Select]
#include <Wire.h>
const int LED = 13;
boolean butt1State;
boolean butt2State;
int seconds, minutes, hours, init_seconds, init_minutes, init_hours, elap_seconds, elap_minutes, elap_hours;
 Wire.begin();
 // clear /EOSC bit
 Serial.print("Initial Time");Serial.print("\t");Serial.print("Current Time");Serial.print("\t");Serial.println("Elapsed Time");
   initialTime();
   Serial.print(init_hours);Serial.print(":");Serial.print(init_minutes);Serial.print(":");Serial.println(init_seconds);
   digitalWrite(LED, !butt1State);
   Timer();
   Serial.print(init_hours);Serial.print(":");Serial.print(init_minutes);Serial.print(":");Serial.print(init_seconds);Serial.print("\t");
   Serial.print(elap_hours);Serial.print(":");Serial.print(elap_minutes);Serial.print(":");Serial.print(elap_seconds);Serial.print("\t");
   Serial.print(hours);Serial.print(":");Serial.print(minutes);Serial.print(":");Serial.println(seconds);
int Timer() {
 elapsedTime();
 if(seconds%60==0) {
 if(minutes%24==0) {
int initialTime() {
 Wire.requestFrom(0x68, 3);
   init_minutes = Wire.read();
   init_hours = Wire.read();
   init_seconds = (((init_seconds & 0b11110000)>>4)*10 + (init_seconds & 0b00001111)); // convert BCD to decimal
   init_minutes = (((init_minutes & 0b11110000)>>4)*10 + (init_minutes & 0b00001111)); // convert BCD to decimal
   init_hours = (((init_hours & 0b00100000)>>5)*20 + ((init_hours & 0b00010000)>>4)*10 + (init_hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode)
int elapsedTime() {
   elap_minutes = Wire.read();
   elap_hours = Wire.read();
   elap_seconds = (((elap_seconds & 0b11110000)>>4)*10 + (elap_seconds & 0b00001111)); // convert BCD to decimal
   elap_minutes = (((elap_minutes & 0b11110000)>>4)*10 + (elap_minutes & 0b00001111)); // convert BCD to decimal
   elap_hours = (((elap_hours & 0b00100000)>>5)*20 + ((elap_hours & 0b00010000)>>4)*10 + (elap_hours & 0b00001111)); // convert BCD to decimal (assume 24 hour mode
Osiris
I just modified the code a bit to include a leading zero for the hour, minute or second < 0
Code: [Select]
// Program Size: 6,660/32,256 bytes
#include <Wire.h>
const int LED = 13;
boolean butt1State, butt2State;
 Wire.begin();
 // clear /EOSC bit
   initialTime();
   if(init_hours<10) {
     Serial.print("0");Serial.print(init_hours);
   Serial.print(":");
   if(init_minutes<10) {
     Serial.print("0");Serial.print(init_minutes);
   Serial.print(":");
   if(init_seconds<10) {
     Serial.print("0");Serial.println(init_seconds);
   Timer();
   if(init_hours<10) {
   Serial.print(":");
   Serial.print(":");
     Serial.print("0");Serial.print(init_seconds);Serial.print("\t");
   if(elap_hours<10) {
     Serial.print("0");Serial.print(elap_hours);
   Serial.print(":");
   if(elap_minutes<10) {
     Serial.print("0");Serial.print(elap_minutes);
   Serial.print(":");
   if(elap_seconds<10) {
     Serial.print("0");Serial.print(elap_seconds);Serial.print("\t");
   if(hours<10) {
     Serial.print("0");Serial.print(hours);
   Serial.print(":");
   if(minutes<10) {
     Serial.print("0");Serial.print(minutes);
   Serial.print(":");
   if(seconds<10) {
     Serial.print("0");Serial.println(seconds);
int Timer() {
 elapsedTime();
 if(seconds%60==0) {
 if(minutes%24==0) {
int initialTime() {
int elapsedTime() {
If anyone wants to see the output (the initial time and elapsed time are printed in 24 HR time format):
Code: [Select]
Initial Time Current Time Elapsed Time
15:22:30
15:22:30 15:22:31 00:00:01
15:22:30 15:22:32 00:00:02
15:22:30 15:22:33 00:00:03
15:22:30 15:22:34 00:00:04
15:22:30 15:22:35 00:00:05
15:22:30 15:23:25 00:00:55
15:22:30 15:23:26 00:00:56
15:22:30 15:23:27 00:00:57
15:22:30 15:23:28 00:00:58
15:22:30 15:23:29 00:00:59
15:22:30 15:23:30 00:01:00
15:22:30 15:23:31 00:01:01
15:22:30 15:23:32 00:01:02
15:22:30 15:23:33 00:01:03
15:22:30 15:23:34 00:01:04
15:22:30 15:23:35 00:01:05
15:22:30 15:24:25 00:01:55
15:22:30 15:24:26 00:01:56
15:22:30 15:24:27 00:01:57
15:22:30 15:24:28 00:01:58
15:22:30 15:24:29 00:01:59
15:22:30 15:24:30 00:02:00
15:22:30 15:24:31 00:02:01
Thanks again for all your help. English is my native language, but programming is still a bit foreign to me  XD
You guys have been discussing the accuracy of the BCD conversion, I'm not exactly sure why Macetech's is "more efficient". Is this more of a programming reason, or a mathematical reason (e.g., 10%6 will still return a value, just not an integer)?
My next step with this, is to time different events and add them together. That is;
I walk into a room->timer starts,
I walk out 31 seconds later: T = 00:00:31,
5 minutes later I walk into the room, timer starts again,
I walk out 2 minutes and 14 seconds later: T = 00:02:45
and so on...
JChristensen
No problem. Nice job on the code. (BTW, the language that all programmers know best is profanity ;) )
Quote
It's not at all a question of accuracy, I could tell that Macetech's conversion would give the same results as mine. However, I thought that his might be more efficient (fewer instructions). Once I looked at the assembler code, I found that the two were in fact identical.
Choose whichever looks better to you, play rock-paper-scissors to decide, etc. :D
Osiris
Thanks and I'm well versed in profanity  :)
I'm now running into a bit of trouble of getting this work as a start/stop timer. Basically, I'd like to hit a button and the timer starts:
Code: [Select]
00:00:00 // Initial Time
// Button press
00:00:01
00:00:02
// Button release
// Wait some time, e.g., 10 seconds
// Button press
00:00:03
00:00:04
The above code would continuously count after the initial button press, i.e., as soon as the button is pressed the time is reset and begins and continues counting. I was then able to have it start and stop on button presses and declared a new variable t_seconds += seconds, however, let's say the initial timer ended at 00:00:05, during the second start of the timer (which now makes sense), it is going to compound the time so I would get:
Code: [Select]
00:00:06 //+1
00:00:08 //+2
00:00:11 //+3
etc...
and would potentially miss, and continue counting pass the 60 second mark [currently only focusing on the second timer]. I thought I could solve this by dividing seconds into itself: seconds+=(seconds/seconds), but this would sometimes return unexpected numbers.
I have a few ideas of what it might be, but having a bid hard of a time interpreting it I guess (who am I kidding, it's coming down to math again  XD !). If anyone has any ideas, please. Thanks.
el_supremo
A minor fix:
Code: [Select]
That is equivalent to:
Code: [Select]
seconds = (elap_seconds - init_seconds) % 60;
The same type of thing applies to the minutes and hours.
Pete
Don't send me technical questions via Private Message.
Osiris
A minor fix:
Code: [Select]
Code: [Select]
Pete
Hmm. I thought perhaps the "extra" 60 was to prevent negative values when elap_time resets and then becomes less than init_time?
So i understand a bit more of what is going on here...
I'm just going to deal with the seconds here (and is probably the only thing we have to concern ourselves with). Below is the pasted code, but I'l reference.
Code: [Select]
#include <Wire.h>
const int LED = 13;
    elap_seconds, elap_minutes, elap_hours,
    t_seconds, t_minutes, t_hours;
  Wire.begin();
  // clear /EOSC bit
    initialTime();
  //Use digitalRead(button2)==LOW for start/stop
  if(digitalRead(button2)==LOW) {
    runTime();
    //Use t_seconds to store each second that passes when button is pressed
    //divide seconds into itself for compound addition of one
    t_seconds+=(seconds/seconds);
    //Resets the seconds when t_seconds reaches 60
    if(t_seconds%60==0) {
      t_seconds=0;
      t_minutes++;
    Serial.print(hours);Serial.print(":");Serial.print(minutes);Serial.print(":");Serial.print(seconds);Serial.print("\t");
    Serial.print(t_hours);Serial.print(":");Serial.print(t_minutes);Serial.print(":");Serial.println(t_seconds);
int runTime() {
  elapsedTime();
/* This code was an attempt to reset the initial time and avoid the -1 error
  if(elap_seconds%60==0) {
    elap_minutes++;
    initialTime();
int initialTime() {
    init_seconds = init_seconds - init_seconds; //set init_seconds to zero
int elapsedTime() {
I am using t_seconds to store the seconds ONLY when the button is pressed. This part works, but there are two problems:
(1) When seconds rolls over from 59 to 0, t_seconds=(seconds/seconds) actually becomes 0 divided by 0 and returns -1. This then subtracts 1 from t_seconds, but will continue adding and repeat this at the same time point. I've tried negating the -1 by multiplication, or adding 2 i.e., ((-1)+1=0+1=1), but it will always subtract the 1.
(2) The use of delay waits for the second to pass, removal of the delay, will add +1 as fast as the MCU can, e.g., if I were to set delay(500); than each passing "actual" second the MCU would actually be adding 2 seconds. The delay here was more for debugging, and I am trying to avoid the use of delay.
Therefore, I seem to be back at square one. Any ideas anyone?
