Topic: WD-C2401P Question (Read 895 times) previous topic - next topic
mwmatthewkc51
So I have received a WD-C2401P Display from my engineering teacher, and I am wondering if it is possible, or even compatible to use it with the Arduino Duemilanove w/ ATMega328. I have tried using the provided example that is coded and pined out for the 16 x 2 display monitor, but this screen is a 24 x 1 monitor (with no back light) and it appears that I have no success with displaying the "hello world" code. If someone can help me use the right pins and/or any modification of the coding for this display to work, that would be greatly appreciated. Thank You.
floresta
Quote
Yes, but not with the LiquidCrystal library since it uses a different controller although the instruction set is similar.
Check out this thread --> http://forum.arduino.cc/index.php?topic=78002.0, especially Reply #5.
Don
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
