Topic: Due has short across two CPU leads (Read 877 times) previous topic - next topic
barrybrown
My new Due came with a short across two leads on the CPU. Is it supposed to be there?
Grumpy_Mike
Quote
Well I have two and it is not on either so I would say no.
barrybrown
Thanks. I put an X-acto knife to it and it came right off. Hopefully there aren't any other stray bits of solder on the board.
Grumpy_Mike
Quote
Yes they often do when they are like this, I have seen a few of that sort of things from factories. It tends to be stray contamination that occurs after the main oven, so they are not attached very firmley.
By rights they ( the Aduino team ) want to know this as it is a manufacturing fault and they will be tracking these. So I would send them a PM pointing to this thread and the photo.
ivanseidel
Those are Pins 23 and 24 (PA14 and PA15).
If you didn't configure them as Output, and changed them as oposite, your port will be just fine =]
Arduino DueTimer | https://github.com/ivanseidel/DueTimer
Arduino Thread | https://github.com/ivanseidel/ArduinoThread
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
