Topic: Arduino Dummy Terminal for gUi Help (Read 983 times) previous topic - next topic
JB_AU
The following sketch i found on the net, from somewhere ??? If it's you, my apologies .
I have edited the sketch to make it more ledge-able.
sketch.ino
String pinnum = "";
String commands = "";
String instruct = "";
int value = 0;
int pin;
void setup(){
void loop(){
  char inchar;
  int count = 0;
  if(Serial.available() > 0){
    while(inchar != '\n'){
      if (Serial.available()){
        inchar = Serial.read();
        if(inchar == '\n'){
          break;
        if(count<4){
          commands += (char)inchar;
          count++;
        else{
          instruct += (char)inchar;
    //value = instruct.toInt();
    pinnum = commands.substring(2,4);
    pin = pinnum.toInt();
    switch(commands.charAt(0)){
    case 'a':
      analog();
      break;
    case 'd':
      digital();
      break;
    clearall();
void analog(){
  switch(commands.charAt(1)){
  case 'r':
    value = analogRead(pin);
    Serial.println(value);
    break;
  case 'w':
    Serial.print(pin);
    Serial.println("ok");
    pinMode(pin,OUTPUT);
    analogWrite(pin,value);
    break;
void digital(){
  case 'r':
    pinMode(pin,INPUT);
    value = digitalRead(pin);
    break;
  case 'w':
    Serial.print(pin);
    digitalWrite(pin,value);
    break;
void clearall(){
  commands = "";
  instruct = "";
  pinnum = "";
I have played with this to make and understand gui development easier, i am mixing this with my own code, this gives me an extra layer of control-ability. By itself , it just makes the arduino a simple terminal , waiting for instructions from U. The U in gUi.
I have used this in Auto-IT, Realbasic, Terminal & Flowstone (which is what i am currently using).
From terminal or your preferred IDE, The following are used, when a serial connection has been established;
d = digital
a = analog
w = write
r = read
dw12+1   //digitalwrite pin 12 HIGH
dr12   //digitalread pin 12
aw0+10   //analoglwrite pin 0 value of 10
ar0   //analoglread pin 0
This adds flexibility, giving you the chance to simulate situations without any extra components needed.
I exclude the use of Pins D0, D1 & D13, i exclude the RX/TX lines & Pin 13 as;
dw13+0 //make 13 low
dr13 // you get 0/low but the ping goes high after reading  :~
I hope this helps somebody, because it is reallllllly helping me.
Amateurs built the ark, Professionals built the Titanic
mrburnette
#1
Jun 30, 2013, 08:06 pm Last Edit: Jun 30, 2013, 08:14 pm by mrburnette Reason: 1
http://n.mtng.org/ele/arduino/iarduino.html
Check it out
IF YOU ONLY want read-only for all ports, then HID is useful:
http://forum.arduino.cc/index.php?topic=135623.msg1032421#msg1032421
- Ray
