Topic: Intercepting 433mHz Signals from Bios CE1177 Weather Station (Read 44898 times) previous topic - next topic
robwlakes
May 20, 2013, 03:26 pm Last Edit: Dec 25, 2013, 06:07 am by robwlakes Reason: 1
News Flash: Bios WS Anemometer dropped a bearing, so now posting solution to Oregon Scientific sensors.
Pls search Forum  (reason could not buy direct Bios replacement in Australia)  Adieu Bios!!!!
Hi Folks,
I use a Bios weather station to link into my Web Server in my garage to add real time local weather information to my website.  Currently the system has a wind direction, wind speed, temperature and rainfall sensor information being radio relayed 433mHz off the roof to a receiver inside the shed.  The Bios receiver has a USB interface that is currently interfaced into my Ubuntu server with a piece of code that produces a serial interface which is interrogated by a complicated Python program (mainly due to processing the Bios format that I want to bypass) I wrote.  This Python program produces 12 hour graphs and other nice things, see : http://www.laketyersbeach.net.au/weather.html.
1. Our Mains Power is lost due to occasional outages, or batteries dying, and re-establishing the link with the transmitter is tedious.
2. Sniffing the signal with a Uno+433MhzRx is easy (see images below).
3. Demodulating the signal using Manchester Encoding to a stream of 1&0's is under way and now working correctly, rock solid.
4. Four types of data structures are sent alternatively every 40secs approx. Sync, Wind, Temp and Rainfall
5. Data is repeated 4 times over for error detection, though length of data changes for the four different data types, sync, wind, temp, rain.
6. Binary version can be used to calculate, Wind Speed, Wind Direction, Temperature and Rainfall.
7. CSV values exported to Ubuntu Web Server at exactly 1 minute intervals
This is the final version of the code for the moment, it works extremely well.
I note with a little pleasure that quite a  few people have followed this post up, though I expected it to be a rather specialist area, while not too intellectually challenging, maybe of little interest to so many, however I will continue to post my progress with my code so far in the hope that maybe some other enthusiast will build on what I have done and maybe figure out how they do the "wind gusts" and "battery condition" and "Signal strength" in their transmissions.
Also I believe I have a really good handle on Manchester En/Decoding in this program and even that maybe of use others decoding other brands of weather stations.
I am looking forward to a much simplified data transfer format.  Ahh blisss!!!  I can then simplify the Python program and update it as well.
Cheers, Rob
PS Please read later postings for improved Arduino Code
Learning Flute and C++, heading for a meltdown.
MrFollies
Hiya Rob,
I just picked up a weather station today with the aims of doing exactly the same thing as you have.
I've got some Arduino gear but no 433Mhz rx yet.   Can you point me to where you got yours?
I'll add any info I find about my station to your page.
Thanks!
-Dan
robwlakes
#2
Jun 18, 2013, 06:53 am Last Edit: Jun 18, 2013, 07:09 am by robwlakes Reason: 1
hi Dan,
Just be aware I have updated this page a few times and the latest Arduino sketch should be #17.  I finally cracked a very good Manchester decoding routine in #17 that I am very pleased with.  I have also got a simple Python program below to demonstrate how easy is it to get Arduino serial data back through the USB into a Linux machine running Ubuntu and Python.
Code: [Select]
import serial
ser = serial.Serial('/dev/ttyACM0', 115200)
print " ii, pp, Quad, Speed, Rain, ExTemp, InTemp, Press,Humi  @115200"
while True:
  print ser.readline()
A Rx at 433mHz that might interest you is http://www.jaycar.com.au/productView.asp?ID=ZW3102.
Plus my weather Station is badged a "BIOS BW972", however a similar looking one is the Thermor DG950 Wireless Home Weather Station (see photo below).  I suspect the internals are exactly alike (the externals are!) so the code should work on these as well.  I have tried to find my Bios on the web and it looks as if it getting low in numbers.  I had to buy a whole new system about 2 years ago because a cup broke off the anemometer and the same storm damaged the input from anemometer/direction unit to the transmitter.
I would be very interested to hear of what brand station you are using, as the data protocols differ from brand to brand.
Cheers, Rob
MrFollies
Cheers Rob,
The one I got is this one:
http://www.jaycar.com.au/productView.asp?ID=XC0348
I've ordered what looks to be the same receiver as you mentioned.   I also took a punt on a couple of cheap ones from china.   They were only about $1.30 each with free shipping so I figured it was worth a gamble.
When they get here I'll see what I can do with the arduino.
With the data stream that you got, how did you know what it was?  I mean, did you filter it for ascii conversion or was it just a stream of numbers?
robwlakes
#4
Jun 18, 2013, 03:43 pm Last Edit: Jul 08, 2013, 12:44 pm by robwlakes Reason: 1
Aha Dan,
That was the one I was considering if I couldn't find a Bios replacement.  So that could be good if I swap brands.  I particularly like the compact nature, ie they all fit on the one pole and there is a solar power option (I think?) as well.  My code will be very unlikely to transfer straight into it but the general principles could help heaps.  However I suggest you don't immediately bolt it to your roof but keep it in your lounge room so that can set up the direction etc in a trial situation and see how the number you find change.  Mine is on the roof right now and I am just guessing a fair bit of the time, and seeing how it correlates with what the console tells me.
The data stream will probably be Manchester encoding so that part of the program will help heaps, however once you have the binary data samples you will need to tease them apart to find what binary relates to which readings.  This can be a pain and any research you can do on that before the RX's turn up the better, it could save hours of frustration and after all, why did they invent the internet if it was not for these major IT discoveries to be shared  :)
The Bios machine uses a mixture of simple 4 bit binary to integer (wind direction), rain  is 12 bits integer, temp is 3 bits of BCD and speed is an integer with about 12 bits again.  Rather messy.  If you are going to do any maths with them you maybe converting them all the time backwards and forwards as it suits.  There are quite a few other binary bits I have no idea what they mean, maybe things such as battery condition but I don't know where it is in the data patterns.  ^_^  There maybe a CRC there but as yet I have not decoded it.
I have changed my program slightly, I was truncating the air pressure and there was only zeroes after the decimal point.  I will post it probably tomorrow night, I am momentarily distracted by getting it to work on my python program. Not so easy either (NB fixed by subtracting the LF/CR from the imported serial string in python).
Cheers, Rob
MrFollies
Thanks Rob,
Yeah the solar battery recharger is standard on this unit.    I noticed that there was some discharge from one of the rechargable batteries so I'll probably buy some new ones rather than let it corrode the system.
I'll definitely check to see is anyone else has decoded the stream before me ;-)    Then when the rx units arrive I'll have to dive back into arduino/electronics.   The arduino programming side does not phase me but I'm a pretty big newb when it comes to circuits.
Stay tuned....
robwlakes
Forgot to add, Dan, that the detect a header part of my Manchester en/decoding should be Ok with a little tweaking of the delays, this can be debugged pretty easily and once that far, knocking out some binary dumps of the data is pretty easy. Assuming that it is Manchester.  Then the fun detective work will begin.
I hope those Rx's are quick.  I can help on the circuit side, I taught Electronics from yr8-yr12's in local secondary school for 12 years  :smiley-roll-sweat:  Nearly all Picaxe for them as it was easier, but Arduino is lovely as it is not so dumbed down, and I feel like I can spread my wings.  I retired 18months ago.
Cheers, Rob
robwlakes
#7
Jun 21, 2013, 03:08 am Last Edit: Dec 25, 2013, 06:14 am by robwlakes Reason: 1
Hi Dan,
Progress has been excellent if not smooth.  Usual bumps and grind, however I now have a functioning superior replacement for my old set up.  So the Bios BW972 Weather Station or Thermor DG950 should yield to this 433mHz and Arduino interception.  The BMP085 air pressure detector is excellent and no more corrections required, just read it and plot it.  I have also had a go at calibrating the rain gauge by pouring 250ml of water into a container with a small hole to drain into it, calculated collecting area, and found #tips*0.183 = mm rain.  The wind speed is still a problem as I do not have a good anemometer to check it properly.  I have ordered the humidity detector and I will add it in soon. At the moment the Arduino just generates a dummy value to keep my python program happy.
I am now ready to solder up a permanent  shield and make an installation.  It has taken me 3-4weeks of hard slog (ie on and off, depending on inspiration and perspiration), but has been about 6 years in the searching phase, so to speak.  Thank you Arduino team!! Brilliant!!
I have also been able to clean out my python code of all the cruddy compensation code that tried to make up for the linux/USB interface I previously used.  This pathway simplifies the task and puts real control back in the hands of the designer.  I am very pleased with the outcome so far.
Enjoy, Rob
PS I wish I could modify the heading of this posting as the CE1177 actually refers to the RF Interference certification and not the model number of the Weather Station!!!   =(  :smiley-roll-sweat:
PPS Please see above postings  for improved listing
robwlakes
Hi Dan
Working really nicely at the moment, rock solid!!!  http://www.laketyersbeach.net.au/weather.html
I am now working on a rainfall page now that I have complete control over the data, I was hesitant to develop the python side of things these last few years, but now I am a lot more confident of the accuracy and source of the data.
Have you got your 433-RX's yet?
Rob
robwlakes
#9
Jun 26, 2013, 01:10 am Last Edit: Dec 25, 2013, 06:13 am by robwlakes Reason: 1
Hi Dan,
I have built and tested the shield with the RX and Barometer attached.  I intend to use the patch board version until the Humidity detector arrives and mount it straight to the permanent shield, get it working, and then swap the permanent board into service with a bells and whistles.
I have also made some good progress with the Linux/Python set up as well but that is another story.
Rob
robwlakes
#10
Jun 26, 2013, 04:01 am Last Edit: Dec 25, 2013, 06:11 am by robwlakes Reason: 1
Hi Dan,
Wouldn't you know it? I post a picture this morning and the Humidity detector arrives in the mail. Out with the soldering iron and on she goes.  Only took a few minutes to add in the library, then copy in a half dozen lines from the supplied example, re-jig the python and hey presto I now have humidity on my WWW as well.  Lovely.
The latest program is MyOwnEX22.ino is attached with latest photo of final (?) shield version.
I also stripped the broken wind/temp sensor apart and will post the Bios internals on a later post (not much interest to you but it does reveal a few design strategies).
Cheers, Rob
robwlakes
#11
Jul 01, 2013, 11:20 am Last Edit: Jul 07, 2013, 05:27 am by robwlakes Reason: 1
This could be interesting Dan, from Sourceforge  ie http://wmrx00.sourceforge.net/Arduino/OregonScientific-RF-Protocols.pdf
But I am not sure what brand your weather station is?  The Altronics link did not mention a brand?
Rob
robwlakes
#12
Jul 04, 2013, 12:27 am Last Edit: Dec 25, 2013, 06:02 am by robwlakes Reason: 1
Hi Dan,
So you have an Ambient. It looks a good machine, I particularly like the solar charging of the batteries. I have looked up the three articles, but not the first.  Both Manchester and OOK use ASK in these Weather Station cases. ie the 433 carrier totally disappears in between bursts.  How this is interpreted is up to the way it is encoded.  That one Ambient article would indicate that they probably use OOK for all their machines and probably vary the packet structure accordingly.  So assuming OOK and the timings given would be a very good starting point.
Check this guy's article too, not Arduino but Raspberry-Pi but he makes very good observations that back up your articles
http://www.susa.net/wordpress/2012/08/raspberry-pi-reading-wh1081-weather-sensors-using-an-rfm01-and-rfm12b/
My Manchester code may not be that useful in its present form as Manchester has a standard data pattern length, whereas other OOK's can vary. This one has variable lengths for 1 (high 05.ms, low 1ms) and a 0 (high 1.5ms, low 1ms) but has the same the underlying concept of
  • getting the status of the line, waiting and
  • re-sampling  to check it's not noise ( ie polarity has stayed the same) and then
  • wait some more to see if polarity has reversed, ie it is a 1, or has stayed the same, it is a 0, then
  • test similarly for the 1ms "low" separator and
  • try again.
You might like to use timer interrupts, but I prefer simple delays, conceptually easier for me to deal with, and this is the main task so no real need for pulse checking in the "background".
Cheers. Rob
robwlakes
#13
Jul 07, 2013, 05:38 am Last Edit: Jul 08, 2013, 12:38 pm by robwlakes Reason: 1
Hi Dan,
Another trick I found handy when my Manchester decoding was decidedly flaky was to toggle output 13 (+LED) at critical debug points in the program and then look at the output of the Rx (as fed into the Arduino) into, say, LH Channel of Audacity and the Output 13 in the RH Channel of Audacity.  Take a screen grab at the right res' and a printout and it doubles as a cheap dual trace storage 'scope. I got the pencil out,     ... found my delays were quite accurate and level sensing OK, but discovered after that my Manchester decoding was what was flaky!!!
My son Nick put me on the right algorithmic track about being more careful about keeping track of the state of the signal with wobbly status variables.  Tightened that up and now it is rock solid.
Looking forward to being able to compare the two weather stations at the code level.
Cheers, Rob
robwlakes
#14
Sep 15, 2013, 04:55 am Last Edit: Dec 08, 2013, 05:34 am by robwlakes Reason: 1
Hi Folks,
My Arduino replacement for the Bios BW972 Weather Station (or Thermor DG950) base unit has been working very reliably for the last two months or so. I will provide the latest version (22nd) of the software below with Pressure and Humidity sensors fully working.  I have also included a graphic of the 7 images of graphs my Python program produces from this data (arriving every minute, though the three types of packets arrive at 40 second intervals so it takes 3x40=120secs for a full update).  The website is http://www.laketyersbeach.net.au/weather.html if you are interested in seeing it action.
I have also done a "tear down" on the wind direction and wind speed unit as well and can publish the photos here if you are interested.  It is better than the price would indicate.
There are a few extra statements/routines that don't appear to be used, but can un-commented if debugging is required.
The code lends itself to reporting the data as either processed weather readings and out-putting the accumulative real values (eg temperature in degrees Centigrade) every 60 seconds, or if desired the raw numbers in each packet could be output every 40 seconds and broken up and converted by the Python program,  The former is convenient, however if there was a need to transmit other data to the receiver the latter maybe more versatile in processing different data sources.
I have also devised a program that broadcasts data that this program can receive and process and will publish it here if people are interested.  It provides a very stable 433MHz data link with Manchester encoding.
Cheers, Rob
PS Sorry if you are a C++ Guru and find the comments excessive, but it is the only way I can build a picture in my head.
