Topic: Sharp IR Remapping (Read 945 times) previous topic - next topic
daz1761
I've just purchased a Sharp IR Range Finder 20cm to 150cm.  I'm trying to remap the ADC so that when nothing is in range it reads 0 and when something has approached the 20cm limit to read 100.
This is my code:
Code: [Select]
#define irSensor 1
void setup () {
  int irVal = analogRead(irSensor);
  int irMapVal = map(irVal, 0, 1024, 0, 100);
  Serial.println(irMapVal);
For some reason my maximum reading within the boundaries is 50 not 100 as I expected.
M
johnwasser
If you look at the specifications you will see that the output range for the GP2Y0A02 is about 0.5V to 2.75V.  With a 5V analog input that's about 102 to 563.  You might want to constrain the inputs before mapping:
Code: [Select]
  int irMapVal = map(constrain(irVal,102,563), 102, 563, 0, 100);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
daz1761
Code: [Select]
Thanks very much, thats perfect  :)
If you don't mind me asking, how did you work out the 102 to 563 range with the incoming and outgoing voltages?  I know the Arduino Uno ADC is 10bit (0, 1024).  Did you multiply the 0.5 and 2.75 by something?
M
johnwasser
The default analog input reference voltage is 5V.  That means that 0V maps to 0 and 5V maps to 1024 (yes, even though the highest number you can get is 1023).
To calculate the analog input number from a voltage, divide the voltage by 5 and multiply by 1024.
0.5V / 5V = 0.1 * 1024 = 102.4
2.75V / 5V = 0.55 * 1024 = 563.2
Of course the actual numbers are truncated to integers: 102 and 563.
daz1761
That makes perfect sense  :)
Thanks for your help, much appreciated!
M
