Topic: divmod10() : a fast replacement for /10 and %10 (unsigned) (Read 64531 times) previous topic - next topic
robtillaart
May 20, 2013, 08:39 pm Last Edit: May 20, 2013, 08:43 pm by robtillaart Reason: 1
For a project I needed both / 10 and  %10 several times. Although the straightforward code was fast enough I investigated if it could be even faster. Could be useful e.g. for a library or so. This resulted in the following divmod10() function that calculates both the divide by 10 and the modulo 10 "simultaneously".
Note 1: the code is written for unsigned 32 bit math. It can not be used for signed numbers. One can derive a 16 bit version by removing one line and making the types 16 bit.
Note 2: tested only on a UNO
Code: [Select]
void divmod10(uint32_t in, uint32_t &div, uint32_t &mod)
 // q = in * 0.8;
 uint32_t q = (in >> 1) + (in >> 2);
 q = q + (q >> 4);
 q = q + (q >> 8);
 q = q + (q >> 16);  // not needed for 16 bit version
 // q = q / 8;  ==> q =  in *0.1;
 q = q >> 3;
 // determine error
 uint32_t  r = in - ((q << 3) + (q << 1));   // r = in - q*10;
 div = q + (r > 9);
 if (r > 9) mod = r - 10;
 else mod = r;
The code is based upon the divu10() code from the book Hackers Delight1. My insight was that the error formula in divu10() was in fact modulo 10 but not always. Sometimes it was 10 more.  I wrote a small test-sketch that is not exhaustive but gives quite some confidence. The performance of the divmod10() is very good, the output of the test-sketch determines timing in microseconds per call.
   i/10      38.6920
   i%10      38.6120
   divmod10   14.9240
Divmod10() is more than twice the speed of /10  or  %10. When both are needed the gain is approx a factor 5, or ~60 micros per calculation.
Test-sketch
Code: [Select]
//    FILE: divmod10.ino
//  AUTHOR: Rob Tillaart
//    DATE: 2013-05-20
// PUPROSE: fast divide and modulo by 10 in one function
// Code based upon book hackers delight
unsigned long start = 0;
unsigned long stop = 0;
volatile unsigned long q;
 Serial.println("testing divmod10()\n");
 Serial.print("i/10\t");
 start = micros();
 for (unsigned long i = 0; i < 1000; i++)
   q = i/10;
 stop = micros();
 Serial.println((stop - start)/1000.0, 4);
 Serial.print("i%10\t");
 start = micros();
   q = i%10;
 stop = micros();
 Serial.println("--------------");
 Serial.print("divmod10\t");
 start = micros();
 uint32_t m = 0;
 uint32_t d = 0;
   divmod10(i, d, m);
 stop = micros();
 Serial.println("test div 0..65535");
 for (unsigned int i = 0; i< 65535; i++)
   uint32_t a = i/10;
   uint32_t d;
   uint32_t m;
   divmod10(i, d, m);
   if ( abs(a - d) > 0)
     Serial.print(i);
     Serial.print("\t");
     Serial.print(a);
     Serial.print("\t");
     Serial.println(d);
 Serial.println("test mod 0..65535");
 for (unsigned int i = 0; i < 65535; i++)
   uint32_t a = i%10;
   uint32_t d;
   uint32_t m;
   divmod10(i, d, m);
   if ( abs(a - m) > 0)
     Serial.print(i);
     Serial.print("\t");
     Serial.print(a);
     Serial.print("\t");
     Serial.println(m);
 Serial.println("test div 0..maxlong (20K random samples)");
 for (unsigned int i = 0; i< 20000; i++)
   uint32_t n = random(0xFFFFFFFF);
   uint32_t a = n/10;
   uint32_t d;
   uint32_t m;
   divmod10(n, d, m);
     Serial.print(n);
     Serial.print("\t");
     Serial.print(a);
     Serial.print("\t");
     Serial.println(d);
 Serial.println("test mod 0..maxlong (20K random samples)");
   uint32_t a = n%10;
   uint32_t d;
   uint32_t m;
   divmod10(n, d, m);
     Serial.print(n);
     Serial.print("\t");
     Serial.print(a);
     Serial.print("\t");
     Serial.println(m);
 Serial.println("done");
 q = q + (q >> 4);
 q = q + (q >> 8);
 q = q + (q >> 16);
 q = q >> 3;
 div = q + (r > 9);
 else mod = r;
As always comments, remarks are welcome.
1 - http://www.amazon.com/Hackers-Delight-Edition-Henry-Warren/dp/0321842685/ -
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Coding Badly
No timing comparison to the[font=Courier New] div / ldiv [/font]functions?
robtillaart
Not thought of div and ldiv. So wrappeed them into the test sketch :
testing divmod10()
i/10   38.6920
i%10   38.6120
ldiv   44.7880
div   15.3960
divmod10   14.9200
test div 0..65535
test mod 0..65535
done
ldiv is very interesting as for almost the same performance one gets / & %
div is 16 bit and signed, where the rest is 32 bit (unsigned), still interesting numbers.
Should make a 16 bit test version.
snippet to add
Code: [Select]
  Serial.print("ldiv\t");
  start = micros();
  ldiv_t ld;
  volatile long x;
    ld = ldiv(i,10);
  stop = micros();
  x = ld.quot;
  Serial.print("div\t");
  start = micros();
  div_t id;
    id = div(i,10);
  stop = micros();
  x = id.quot;
Rob Tillaart
genom2
#4
May 25, 2013, 01:33 pm Last Edit: May 25, 2013, 01:45 pm by genom2 Reason: 1
Hi robtillaart,
I wondered why the correction term (and therefore if-then-else) is needed. (This slows down performance.) I tried to find a precise approximation and came up with this:
Code: [Select]
// for in between 0x0 .. 0x7fffffff
 uint32_t x=in>>1; // div = in/10 <==> div = ((in/2)/5)
 uint32_t q=x;
 q = x + (q >> 8);
 q = x + (q >> 8);
 x++;
 q = x + (q >> 8);
 q = x + (q >> 8);
 q = 3*q;
 div = (q + (q >> 4)) >> 4;
 mod = in - ((div << 3) + (div << 1));
On my Duemilanove it's faster then the divu10() code from the book Hackers Delight you gave. Maybe because no if-the-else is needed or shift by 8 is good for the optimizer. But I have no insight into the resulting assembler code.
Its a somewhat "weird" solution, again.
robtillaart
added your version to the test sketch :
i/10   38.6920
i%10   38.6120
ldiv   44.7880
div   15.3960
divmod10   14.9200  ( )
divmod10 2   13.6040  ( in/2/5 version)
That is 10% faster. Yes! almost 3x faster than the native one
your comments states it works for 0..0x7FFFFFFF  that is half of the possible numbers.
My 20 K random test show it seems to work also above it (akthough 20K samples is no proof)
- can it be faster?
Rob Tillaart
robtillaart
inspired by 10 = 2 x 5 as you did  I found this one
Code: [Select]
void divmod10_2(uint32_t in, uint32_t &div, uint32_t &mod)
  uint32_t x = in>>1;
  uint32_t q = x;
  q = x + (q >> 8);
  q = x + (q >> 8);
  x++;
  q = x + (q >> 8);
  q = x + (q >> 8);
  q = 3*q;
  mod = in - (((div << 2) + div)<<1);  // <<<<<<<<<<< this line changed, in total one shift less.
it resulted in : 13.1600    another slice off
Rob Tillaart
genom2
#7
Jun 01, 2013, 01:44 pm Last Edit: Jun 01, 2013, 01:56 pm by genom2 Reason: 1
Yes, constrain 0..0x7FFFFFFF was needed because it only works in this interval.
BTW: Your test with random() is useless for testing in 0..0xFFFFFFFF because it produces only values between 0..RANDOM_MAX (with RANDOM_MAX = 0x7FFFFFFF). ( See http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html )
"can it be faster?"
Yes, it can!
I took the challenge and found a solution which is the fastest (so far on my atmega328p) and finally works on the complete interval 0..0xFFFFFFFF.
Code: [Select]
uint32_t x=(in>>1); // div = in/10 <==> div = ((in/2)/5)
uint32_t q=x;
q= (q>>8) + x;
q= (q>>8) + x;
q= (q>>8) + x;
q= (q>>8) + x + 1;
x= q;
q= (q>>1) + x;
q= (q>>3) + x;
q= (q>>1) + x;
div = (q >> 3);
mod = in - (((div << 2) + div) << 1);
robtillaart
Rob Tillaart
ajk_
Make them q and x register variables, it should go even faster.  :smiley-mr-green:
robtillaart
tried adding register to q and x, but no success,
Think the compiler either already optimizes the vars as they are not volatile, or the compiler ignores the keyword.
Rob Tillaart
pYro_65
I was curious so I had a quick browse.
According to the C++ standard,
Quote
D.4 register keyword [depr.register]
1 The use of the register keyword as a storage-class-specifier (7.1.1) is deprecated.
And 7.1.1:
Quote
The register speci?er shall be applied only to names of variables declared in a block (6.3) or to function parameters (8.4). It speci?es that the named variable has automatic storage duration (3.7.3). A variable declared without a storage-class-speci?er at block scope or declared as a function parameter has automatic storage duration by default.
So to summarize, register has the same semantics as auto. Local variables are auto by default, therefore register is completely redundant in C++.
In C, it simply stops you from taking the address as this isn't allowed, whereas if done in C++, the register semantics are simply ignored.
Forum Mod anyone?
https://arduino.land/Moduino/
ajk_
Nice to know that G++ does this. Not all compilers to though.
It does not mean that the code is incorrect in any case.
I guess it depends on the compiler and optimizer.
Cool hack none-the-less.
pYro_65
Quote
Thats not GCC documentation, its the ISO C++99 standard. The same goes for C++11.
Optimizing compilers are able to pick register candidates far better than us. Even then 'register', like 'inline' is only a hint, and can be ignored.
Forum Mod anyone?
genom2
Sorry for this. I don't want to abuse this thread for progress reports on senseless optimization. But, please excuse me ... I'm in a kind of flow.
Another ~1.5% off:
Code: [Select]
uint32_t x= (in|1) - (in>>2); // div = in/10 <~~> div = (0.75*in) >> 3
uint32_t q= (x>>4) + x;
x= q;
q= (q>>8) + x;
q= (q>>8) + x;
q= (q>>8) + x;
q= (q>>8) + x;
div = (q >> 3);
