Topic: String Concatenation ? [solved] (Read 3611 times) previous topic - next topic
mrbbp
Mar 03, 2006, 04:34 pm Last Edit: Mar 03, 2006, 11:58 pm by mrbbp Reason: 1
Massimo,
you've said in a previous thread that string operation are allowed in Arduino...
I've tried a printf() like this but it doesn't work !:-/
the compilator doesn't generate error !
What i'm doing wrong ?
Code: [Select]
printStringLCD(printf("Poeme %d ligne 1", Poeme));
i suppose this is very simple but i'm newb in C.
i just want to concatene a string with an integer variable !
regards
mrbbp
mrbbp
I've tried with an sprintf()
Code: [Select]
 sprintf(combo,"%s%d%s", "Poeme ", Poeme, "ligne 1");
  printStringLCD(combo);
No error but doesn't work anymore.
Nothing on LCD and Arduino led on pin13 Blink (on each main loop i suppose)
mrbbp
;D
I've found...
Code: [Select]
strcat(str1,str2);// append str2 to str1
// if str2 is an integer, have to convert it to string before append.
itoa(int2, str2, 10); // 10 is the radix
hope this'll help. and i'm not saying wrongs things
it's work for me::)
mrbbp
