Topic: My "where do babies come from?" of electronics. (Read 6829 times) previous topic - next topic
GoForSmoke
And if something happens to enough of those leds, the rest will start to die in a manner that would make a funny video.....
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
3) http://gammon.com.au/interrupts
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
majenko
So I learn best by trial and error. I got out the breadboard and a bunch of LEDs. first I setup up about 12 LEDs and a 1k resistor for each (what I have in mass quantities) and connected them in parallel. gave it some power. they werent as bright as they can be but they lit up. next I tried them in series. I believe I was able to get about 4 to light up. I had one 1k resistor on that circuit. then I decided to live dangerous and dropped LEDs all along the voltage and ground rails. 117  leds give or take. connected a 9v with no resistors and they all lit up nice and bright. I don't know what I learned but I like it.
What you learned is that little 9V PP3 batteries can't give much current, which is why all the LEDs didn't spontaneously combust.
fungus
117  leds give or take. connected a 9v with no resistors and they all lit up nice and bright. I don't know what I learned...
Did you try holding the battery in your hand while you were admiring the LEDs...?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
computurwizard
Here's something that may help you a lot, once I realized this, things made a lot better sense to me:
Current in a circuit is (generally) not "set" by the power supply, it is set by the load (resistor, motor, hair dryer, etc)
The load "pulls" or "draws" current.  Think of household wiring.  You may have an outlet in your bathroom on a 15 amp breaker.  Let's say a hair dryer on high "pulls" 10 amps.  Now if you plug in TWO hair dryers on high, they would attempt to draw 20 amps, thus tripping the 15 amp breaker.
Now, power supplies have a maximum amount of current they can deliver, as you saw in your huge 9v/LED experiment.  The LED's wanted more, but the 9v simply couldn't deliver.  BTW, you probably need a new 9v now.  Better yet, toss that thing and use better batteries (like some AA, C, or D in series, or a wall wort).  Batteries have an "Amp Hour" or "Milliamp Hour" (mAh) rating that you can use to actually calculate how long a battery will power your circuit! :D
Note that LED's are not the same as a light bulb though.  Without a resistor, an LED will pull so much current that it will burn itself up.
When learning electronics, if you don't blow some stuff up here and there you're not learning properly LOL :D
AlxDroidDev
If your 9V source wasn't a battery (that has a very limited current capacity), but instead was a bench supply, a wall wart or any other source of AC-DC adapter, you'd have learned what it means to divide V/R when R=0: you get inifinite current (well, not infinite, but very high). All of your leds would give a very bright glow, right before exploding or simply dying. If your LEDs had held the high current (very unlikely), you might have had a blown fuse in the power supply.
So you learned that 9V batteries have an internal resistance that limits its maximum current.
Some of my projects:
Shield for DS1337+, DS1624 and AT24C1024B (RTC, temp & mem): http://forum.arduino.cc/index.php/topic,126197.0.html
CHDK Camera remote shutter (BT, IR, USB): http://forum.arduino.cc/index.php?topic=295377.0
bwoogie
Ah. It's starting to come together. That makes sense BackWoodsBrewer.
I was actually pretty surprised that none of them did blow. On one of the smaller experiments the wire on the battery accidentally touched the lead of an led past the resistor and it was bright so that's what "sparked" the idea for the as many led's as I could fit. I have blown a led with this exact 9v just for kicks.
I literally just tested the battery with the multimeter and its putting out 8.8V
fungus
As much as that? I'm surprised, I would have said more like 8V. The battery must be very new.
But again...try holding the battery in your hand for a minute while you admire all those LEDs.
majenko
Those 9V batteries are capable of putting out a couple of amps, but only for a few minutes before they're completely drained.
The typical internal resistance of a PP3 is between 1? and 3? depending on manufacturer and chemistry.  Let's take 2? as a good mean value.
At 2? and a nominal 9V voltage, I=V/R, so I = 9 / 2 = 4.5A.  That's the short circuit current of a typical PP3.
Pass that through 117 LEDs in parallel (assuming the "perfect" LED - exactly the same voltage drop as all other LEDs and zero resistance) - 4.5/117 = 38mA.  That's normally above the IF of a typical LED, but won't normally cause the LED to blow immediately.
Now, the world is not perfect.  So what you have is equivalent to a perfect 9V power supply, with a 2? current limiting resistor, and a bunch of LEDs, each with its own VF.  What that means in practice is that some LEDs will get a slightly higher current than others.  You probably noticed that the LEDs may not have all been the same brightness.
The ones with the most current will blow first.  That will mean there's a greater proportion of the current available to the rest of the LEDs.  The next ones to blow will do the same - increase the current available to the rest, and so on.  A cascade effect will rapidly occur where just one LED blowing could cause the rest of the LEDs to blow.
Of course, all this relies on the battery holding out, which at 4.5A and the typical 565mAh of an alkeline PP3, would take (T=mAh/mA = 565/4500) = 0.12555...h, or about 7 and a half minutes.
fungus
I accidentally shorted out a 3xAA battery pack yesterday and it melted the battery box.
majenko
Nice.
Talking of that...  Back to the PP3.  4.5A through 2? -
P=I²R
= 4.5² * 2
= 20.25 * 2
= 40.5W
That's gonna get warm :)
Learning
So I learn best by trial and error. I don't know what I learned but I like it.
You learned that rather than researching and understanding what's going on, that you can simply wait for answers from others, nice!
