Topic: what does this error mean (avrdude: stk500_getsync(): not in sync: resp=0x00) (Read 11155 times) previous topic - next topic
ApacheOmega
I'm trying to upload a server sketch to my Arduino uno Microcontroller and even though the code compiles I get this message right at the end of compilation (avrdude: stk500_getsync(): not in sync: resp=0x00) usually when I know the sketch is uploaded my router (that's hooked up to the Ethernet shield) usually blinks a few times but that's not happening. I recently had to switch the ide on another computer because my laptop I originally used for arduino projects is acting funny and the IDE cannot find my COM3 port and I can't seem to fix that problem either.
So what should I do?
fix the problem with my laptop and try to run the sketch there or just figure out why I'm getting this error?
P.s. my laptop wont even recognize the microcontroller as being plugged in (through the USB connect) for some reason
Please help
Thank You
Arrch
Could be a bad driver.
Could be the wrong COM port selected.
Could be something hooked up to the Arduino that is messing with its ability to communicate.
ApacheOmega
How do I know I have a good COM port cause it seems if it knows my device is there then I should be good but I gues thats not the case. and as far as the problem with my laptop how do I get it to recognize that its even hooked up?
Arrch
Unplug the Arduino. Check the Tools > Serial Port menu and take note of anything currently listed. Plug it in, and check the menu again. The new one would be the correct one.
Quote
Try re-installing the drivers.
ApacheOmega
Thanks Arrch
I unplugged and a new port COM3 pulled up but when I plugged back up it still creates the same message.
I guess I have to figure out which of my USB ports is the actual COM3 (I have 5 USP ports) how do I find out which one is COM3 pointed at?
HazardsMind
Probably a dumb question, but are you uploading the sketch with the Ethernet shield on or off? Also, can it upload one of the basic example programs?
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
Arrch
That's not how it works. Things plugged into USB ports become COM ports; USB ports themselves, are not COM ports.
Sonendra
Pls help me regarding this error , i am frequently getting this error 'Re: what does this error mean (avrdude: stk500_getsync(): not in sync: resp=0x00)'while uploading the program in arduino fio using programmer
Sonendra
Pls help me regarding this error , i am frequently getting this error 'Re: what does this error mean (avrdude: stk500_getsync(): not in sync: resp=0x00)'while uploading the program in arduino fio using usb serial.
ApacheOmega
HazardsMind whats up man
No it wont even load up the example programs and the ports option in the tools menu is just greyed out to where I cant even select it (how do I uninstall and reinstall the software?)
Thanks Partner!!!
HazardsMind
Just delete the Arduino 1.0.3 / 1.0.4 folder, and re-download it. But I don't think it has anything to do with the software, I think you need to update your drivers in Device Manager > (that particular COM port for your arduino)
You can try to re-download the software and then update the driver.
Usually when I got that error, it was because I had my Bluetooth module still plugged into the TX/RX pins. Once I removed it, I was able to upload my sketchs.
My GitHub:
tiltstern
HazardsMind, you nailed it.  Moving connections out from the TX/RX (0/1) pins did the trick.
Thank you so much.  I NEVER would have guessed this!
jasdall
Hi I am experiencing the ssme problem. Can anyone guide me how to solve the problem? My board is anrduino duemilanove.
It is very strange when I try to upload a sketch using IDE 0022 everything works as it should but when Iuse the latest IDE 1.0.5 I get the error as mentioned in this subject.
IDK more what to do.
PaulS
Quote
There is a sticky at the top of the forum. It says that if you are posting on the Programming section, you post your code. Without your code, how can we possibly help you?
Without your code, you can bump until the cows come home, and you'll just be wasting your time, and ours.
