Topic: GSM Shield weired characters in SMS (Read 19285 times) previous topic - next topic
davidgoth
Hi!,
I find the "CSMP" not right due to this issue.
CSMP's dcs setting is 8, which means this is in UCS2  coding, but the CSCS using "GSM" coding. Here is the conflict.
Just set AT+CSMP=17,255,0,0 first,then try to send SMS again..
If you have any doubt, reply this post.
musterstrasse
hi,
I am glad that you still find new ways for me to try.
however even after following your instruction (see below) I am getting the same result (when sending "test" I am getting "??" as string within the sms).
any other ideas that i could try?
thanks a lot!!
Code: [Select]
Start commands...
Start Reset
End Reset
Ready for commands...
AT+CPIN=1234%13%%13%%10%
+CPIN: READY%13%%10%
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
AT+CMGF=1%13%%13%%10%
OK%13%%10%
AT+CSMP? %13%%13%%10%
+CSMP: 17,255,0,8%13%%10%
%13%%10%
OK%13%%10%
AT+CSMP=17,255,0,0%13%%13%%10%
OK%13%%10%
AT+CSMP?%13%%13%%10%
+CSMP: 17,255,0,0%13%%10%
%13%%10%
OK%13%%10%
davidgoth
Try now changing character set to UCS2 with AT+CSCS="UCS2" and send any message. Post the results.
musterstrasse
i followed your suggestion:
Code: [Select]
Start Reset
End Reset
%-8%AT+CPIN=1234%13%%13%%10%
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
AT+CSCS="UCS2"%13%%13%%10%
OK%13%%10%
AT+CSCS?%13%%13%%10%
+CSCS: "UCS2"%13%%10%
%13%%10%
OK%13%%10%
unfortunately there is no change in behavior.
message string "test" still leads to "??" when receiving the sms
any idea on how to fix that?
davidgoth
Sorry, I forget to say you that you have to save CSCS configuration with AT&W.
1 - Change CSCS with: AT+CSCS="UCS2"
2 - Save with: AT&W
3 - Restart modem and check that it is saved with: AT+CSCS?
4 - Send SMS!!
musterstrasse
Hi!
Your suggestion ("save" before restart) had some impact but not the desired one.
Here is the output that I gathered from serial output
Code: [Select]
Start Reset
End Reset
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
OK%13%%10%
AT&W%13%%13%%10%
OK%13%%10%
Start Reset
End Reset
%-8%AT+CSCS?%13%%13%%10%
%13%%10%
OK%13%%10%
Then I sent out some sample SMS via "send SMS" example code and got "completed" message.
Code: [Select]
SMSMS Messages Sender
GSM initialized
Enter a mobile number: +49151???????
Now, enter SMS content: SENDING
Message:
test
COMPLETE!
Unfortunately none of them arrived.
Then I changed back to GSM (AT+CSCS="GSM") and I got again the "old" erroneous behavior (receiving weird asian characters in the sms).
I also made sure that I followed your previous suggestion (AT+CSMP=17,255,0,0) but without any impact.
Any more ideas?
davidgoth
Check if AT+CSMP=17,255,0,8 and try again with AT+CSCS="UCS2" saving with AT&W.
If not working, try AT+CSMP to 17,71,0,0 and AT+CSCS="GSM".
musterstrasse
hi!
First run with UCS2
Code: [Select]
Start Reset
End Reset
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
AT+CSMP=17,255,0,8%13%%13%%10%
OK%13%%10%
OK%13%%10%
AT&W%13%%13%%10%
OK%13%%10%
With the settings above (UCS2) SMS do not go through at all (sample sms-send program gives COMPLETION message).
Now checking previous settings and then second run with GSM
Code: [Select]
Start Reset
End Reset
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
%13%%10%
OK%13%%10%
%13%%10%
OK%13%%10%
AT+CSMP=17,71,0,0%13%%13%%10%
OK%13%%10%
AT+CSCS="GSM"%13%%13%%10%
OK%13%%10%
AT&W%13%%13%%10%
OK%13%%10%
SMS goes through with GSM but the show erroneous characters and are unreadable.
Do you have any other ideas?
Btw: Anybody else using GSM shield in Europe (especially Germany) with T-Mobile provider? I am interested in seeing what your settings are for
AT+CSCS? and AT+CSCS?
Thanks
Musterstrasse
davidgoth
Try this AT commands sequence:
1. AT+CSCA?
2. AT+CSMP?
3. AT+CSMP=17,255,0,0
4. AT+CSAS=0
(Reboot your Arduino + shield)
5. AT+CSMP? for check if 17,255,0,0 has been saved. If it done, send a SMS.
musterstrasse
Hi davidgoth,
That was it. You fixed it.
I do now receive SMS in correct character set ("test" stays "test" on the receiving side).
Thanks a lot for taking care!
Best Regards,
Musterstrasse
P.S.: For anybody interested here is the output in serial monitor when following through your commands:
Code: [Select]
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
AT+CSCA?%13%%13%%10%
+CSCA: "+491710760000",145%13%%10%
%13%%10%
OK%13%%10%
%13%%10%
OK%13%%10%
OK%13%%10%
AT+CSAS=0%13%%13%%10%
OK%13%%10%
AT&W%13%%13%%10%
OK%13%%10%
Nos-Al7arbi
Hi davidgoth,
Best Regards,
Musterstrasse
Code: [Select]
%13%%10%
OK%13%%10%
%13%%10%
Call Ready%13%%10%
%13%%10%
OK%13%%10%
%13%%10%
OK%13%%10%
OK%13%%10%
OK%13%%10%
AT&W%13%%13%%10%
OK%13%%10%
Mr.Musterstrasse
Couldyou share the program code for sending SMS after fix it
( I have the same problem  =( and I'm beginner in arduino )
Thanks ^_^
musterstrasse
Dear Nos-Al7arbi,
I am using the official "SendSMS Example" from Arduino.
See "http://arduino.cc/en/Tutorial/GSMExamplesSendSMS" and scroll down to the bottom.
This code along with the hint on how to change character set described in this post worked out for me.
Cheers,
Musterstrasse
