Topic: MIDI library doesn't work on Arduino Due (Read 2171 times) previous topic - next topic
schiller
Well, the midi library doesn't work on Arduino Due.
I'm strongly disappointed in this.
Each time i try to compile a midi sketch, the following error occour:
In file included from /Applications/Arduino .app/Contents/Resources/Java/hardware/arduino/sam/cores/arduino/Arduino.h:36,
                 from MIDI_Basic_IO_edited.ino:3:
/Applications/Arduino .app/Contents/Resources/Java/hardware/arduino/sam/cores/arduino/wiring_constants.h:90: error: conflicting declaration 'typedef unsigned int word'
/Users/schiller/Documents/Arduino/libraries/MIDI/MIDI.h:65: error: 'word' has a previous declaration as 'typedef uint16_t word'
Generic code:
Code: [Select]
#include <MIDI.h>
  MIDI.begin();
MIDI.read();
schiller
Solved it
I edited the MIDI.h file with a text editor application.
Basically, i replaced this line
Quote
with this one
Quote
according to the declaration in wiring_constants file.
Now it works fine, but if anyone would suggest another way to fix that problem, suggestions are wellcome!
pjrc
We had this same problem on Teensy 3.0.
It turns out that line is never used.  You can simply delete it without any problems.
