Topic: Perhaps a really silly question (Read 801 times) previous topic - next topic
DDRYA
Hi I have found this code in another thread, however the only problem I am encountering (which im assuming is going to be a 'duh' moment when someone responds) but how do i set up my PIR? I am using an UNO... i had the 5v lead of PIR in 5v of arduino, ground in GND and the 'OUT' lead of PIR in digital pin 2... but I get nothing at all?
thanks... :)
const int firstLED = 3;      // pin for the LED
const int inputPin = 2;      // input pin for the PIR sensor
int PIRstate;               // variable to hold the last PIR state
int val;                    // variable for reading the pin status
  pinMode(inputPin, INPUT);              //declare PIR as input
  PIRstate = digitalRead(inputPin);      //assign PIR state to PIRstate
  val = digitalRead(inputPin);      // read input value
  if (val != PIRstate)                      // check if the input has changed
    if(val == HIGH){
      analogWrite(firstLED, 255);
    else{
      for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
        // sets the value (range from 0 to 255):
        analogWrite(firstLED, fadeValue);
        // wait for 30 milliseconds to see the dimming effect
        delay(30);
  PIRstate = val;                 // save the new state to the variable
Erdin
Some PIR sensor have a open collector output. You would need a pull-up resistor.
Some PIR sensor are for 12V.
Some PIR sensor have an output signal of only 2V.
Grumpy_Mike
There is no such thing in electronics there is always something. Here you will have a logic zero or one. Which is it? Write a sketch to find out, a simple one that say just transfers what it reads on pin 2 to the output pin 13 to light up the LED.
What voltage do you measure on pin 2? You can't do electronics without any measuring equipment.
