Topic: CALIPERS (Read 944 times) previous topic - next topic
supertechqc
+++++++++CALIPER DATA INTERFACE++++++++
-----FOOT SWITCH USED TO CAPTURE SINGLE MEASUREMENTS--------
-----LM339 VOLTAGE COMPARATOR FOR ACCURATE TTL---------------
-----CALIPER REGULATED VOLTAGE----------------------------------------
-----NO WEIRD LIBRARIES OR IDE'S TO DOWNLOAD----------------------
-----ALL FUNCTIONS ARE 100% VERIFIED----------------------------------
-----COMPLETE CODE AND SCHEMATIC ARE BELOW---------------------
=======HERE'S THEY ARE!!!===========
Code: [Select]
________________________________________________________________
************Program Name:CALIPER_DATA_OUTPUT_05_20_2013
************By J. Poston:
**********Date Initiated:4-22-213
************Date Revised:5-20-2013
int dataIn = 4;
int clockIn = 2;
const int buttonPin = 5;     // the number of the pushbutton pin
int buttonState =0;         // variable for reading the pushbutton status
const int i=10;  //Determines the DELAY Low and High for each led state
int isin=0; //inch=1?mm=0
int isfs=0; //
int index;
unsigned long xData,oData;//
long previousMillis = 0; // will store last time LED was updated
long interval = 500; // interval at which to blink (milliseconds)
long previousGetMillis = 0; //
long Timeout = 8; // 8ms
const int ledon=3; // verification for experimenting change
int m;
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  digitalWrite(dataIn, 1);
  digitalWrite( clockIn, 1);
  pinMode(dataIn, INPUT); //DATA line goes to Arduino digital pin 4
  pinMode(clockIn, INPUT);
  attachInterrupt(0,getBit,RISING); //CLOCK line goes to Arduino digital pin 2
  index =0;
  xData=0;
  oData=999;
  Print_Header();//Runs the Subroutine
  pinMode(ledon,OUTPUT); //makes digital pin 3 and output
  Test_Light();  //Runs the subroutine that makes pin 3 blink and LED
  buttonState = digitalRead(buttonPin);
  delay(5);
  if (buttonState == HIGH) {
    if ((index !=0) && (millis() - previousGetMillis > Timeout) ) {
      index=0;
      xData=0;
    if (index >23) {
      if (oData !=xData) {
        if (isfs==1)
          Serial.print('-');
        if (isin==1){ //
          xData *=5;
          Serial.print(xData/10000);
          Serial.print('.');
          if ((xData % 10000)<1000){
            if ((xData % 10000)<100){
              if ((xData % 10000)<10){
                Serial.print('0');
              Serial.print('0');
            Serial.print('0');
          Serial.println(xData % 10000);
          delay(100); //keeps inches from spitting out lots of the same measures
        else { // mm
          Serial.print(xData/100);
          Serial.print('.');
          if ((xData % 100)<10) //0
              Serial.print('0');
          Serial.println(xData % 100);
      oData =xData;
      index=0;
      delay(5);
      xData=0;
    if (millis() - previousMillis > interval) {
      previousMillis = millis();
void getBit(){
  previousGetMillis=millis();
  if(index < 20){
    if(digitalRead(dataIn)==1){
      xData|= 1<<index;
  else {
    if (index==20)
      isfs=digitalRead(dataIn);
    if (index==23) //24 1=inch
      isin=digitalRead(dataIn);
  index++;
^^^^^^^^^^^^^^^^^^^^^^^^Sub Routines^^^^^^^^^^^^^^^^^^^^^^^^^^^^
void Print_Header()
  Serial.println("****************************************************************");
  Serial.println("     Program: Digital Caliper Data SPC  (Running)               ");
void Test_Light()
  delay(100);
  for(m=0;m<20;m++)
    digitalWrite(ledon,HIGH);
    delay(30);
    digitalWrite(ledon,LOW);
    delay(30);
supertechqc
      Schematic at:  http://www.flickr.com/photos/johnsfunoutdoors/8799107095/
======= HERE THEY ARE!!!  ===========
(Cleaned up and Modified/Tested 05-27-2013)
Code: [Select]
Caliper Data Output: Updated 05/27/2013
Code and Circuit Compiled by: J. Poston
Special Thanks To:
Forrest M. Mimms III Engineer's Notebook 1st Edition (pg 106)
David Cook's Website on Caliper Data
http://www.robotroom.com/Caliper-Digital-Data-Port-2.html
Rob Tillaart for code cleanup and insight (from the Arduino Forum)
int dataIn = 4;
int clockIn = 2;
int buttonState =0;
const int i=10;
int isin=0;
int isfs=0;
int index;
long Timeout = 8;
  index =0;
  xData=0;
  oData=999;
Print_Header();
  delay(5);
      index=0;
      xData=0;
    if (index >23) {
if (isin == 1) //Inches
  float val = xData * 0.5 /1000;
if (isfs == 1)
{val = -val; }
  Serial.println(val, 4);}
else // mm
{  float val = xData / 100.0;
  if (isfs == 1)
{val = -val;}
  Serial.println(val, 2);
      oData =xData;
      index=0;
      delay(5);
      xData=0;
void getBit(){
  if(index < 20){
      xData|= 1<<index;
  else {
    if (index==20)
    if (index==23)
  index++;
void Print_Header()
{ Serial.println("****************************************************************");
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
