Topic: CALIPER INTERFACE (Read 9667 times) previous topic - next topic
supertechqc
May 24, 2013, 04:57 am Last Edit: Jul 12, 2013, 04:26 am by supertechqc Reason: 1
+++++++++CALIPER DATA INTERFACE++++++++
-----FOOT SWITCH USED TO CAPTURE SINGLE MEASUREMENTS--------
-----LM339 VOLTAGE COMPARATOR FOR ACCURATE TTL---------------
-----CALIPER REGULATED VOLTAGE----------------------------------------
-----NO WEIRD LIBRARIES OR IDE'S TO DOWNLOAD----------------------
-----ALL FUNCTIONS ARE 100% VERIFIED----------------------------------
-----COMPLETE CODE AND SCHEMATIC ARE BELOW---------------------
     Schematic at:  http://www.flickr.com/photos/johnsfunoutdoors/8799107095/
======= HERE THEY ARE!!!  ===========
(Cleaned up and Modified/Tested 05-27-2013)
Code: [Select]
Caliper Data Output: Updated 05/27/2013
Code and Circuit Compiled by: J. Poston
Special Thanks To:
Forrest M. Mimms III Engineer's Notebook 1st Edition (pg 106)
David Cook's Website on Caliper Data
http://www.robotroom.com/Caliper-Digital-Data-Port-2.html
Rob Tillaart for code cleanup and insight (from the Arduino Forum)
int dataIn = 4;
int clockIn = 2;
const int buttonPin = 5;
int buttonState =0;
const int i=10;
int isin=0;
int isfs=0;
int index;
unsigned long xData,oData;
long previousMillis = 0;
long interval = 500;
long previousGetMillis = 0;
long Timeout = 8;
 pinMode(buttonPin, INPUT);
 digitalWrite(dataIn, 1);
 digitalWrite( clockIn, 1);
 pinMode(dataIn, INPUT);
 attachInterrupt(0,getBit,RISING);
 index =0;
 xData=0;
 oData=999;
Print_Header();
 buttonState = digitalRead(buttonPin);
 delay(5);
 if (buttonState == HIGH) {
   if ((index !=0) && (millis() - previousGetMillis > Timeout) ) {
     index=0;
     xData=0;
   if (index >23) {
     if (oData !=xData) {
if (isin == 1) //Inches
 float val = xData * 0.5 /1000;
if (isfs == 1)
{val = -val; }
 Serial.println(val, 4);}
else // mm
{  float val = xData / 100.0;
 if (isfs == 1)
{val = -val;}
 Serial.println(val, 2);
     oData =xData;
     index=0;
     delay(5);
     xData=0;
   if (millis() - previousMillis > interval) {
     previousMillis = millis();
void getBit(){
 previousGetMillis=millis();
 if(index < 20){
   if(digitalRead(dataIn)==1){
     xData|= 1<<index;
 else {
   if (index==20)
     isfs=digitalRead(dataIn);
   if (index==23)
     isin=digitalRead(dataIn);
 index++;
void Print_Header()
{ Serial.println("****************************************************************");
 Serial.println("     Program: Digital Caliper Data SPC  (Running)               ");
Don't get dismayed to Negative Activist!!!  These are usually Trolls who are first responders to your post.
robtillaart
#1
May 24, 2013, 10:20 am Last Edit: May 24, 2013, 10:22 am by robtillaart Reason: 1
Capitals is shouting on a forum!, please don't, it is not appreciated by most members.
That said, the code is interesting, especially if you could wrap its core functionality in a library so it can be easy incorporated in another sketch.
which calipers it is tested on?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
Quote
I shrunk the font so it would not burst your eyeballs when you read it...
Thanks, I can put off my sunglasses ;)
Quote
Any ideas where I can better post the schematic?
Playground, interfacing with hardware (don't know the exact name)
A youtube movie would be great to see it working.
Code: [Select]
         xData *=5;
          Serial.print(xData/10000);
          Serial.print('.');
          if ((xData % 10000)<1000){
            if ((xData % 10000)<100){
              if ((xData % 10000)<10){
                Serial.print('0');
              Serial.print('0');
            Serial.print('0');
          Serial.println(xData % 10000);
can be simplified by using a float.
Code: [Select]
float val = xData * 5.0 / 10000;
Serial.print(val, 4);  // means 4 decimals
The setup of your sketch has a minor flaw. You first setup the interrupt and then you initialize the xData, if an interrupt comes in between the two -> gotcha ;)
I would create a setupCaliper() function that does what the name says. It makes the main setup much easier to read and maintain.
Other functions can be created to. This is how the high level setup/loop could look like if you use functions more extensively.
Code: [Select]
  printHeader();
  setupCaliper(datapin);
  setupLed();
  setupButton();
  if (buttonPressed)
      readCaliper();
      printCaliper();
Next step is to make a class Caliper() that have methods like setup() read() and print()
Rob Tillaart
robtillaart
should be something like this.
Code: [Select]
if (isfs == 1)
  xData = -xData;  // sign
if (isin == 1) // is Inch
  float val = xData * 0.5 /10000;
  Serial.println(val, 4);  // 4 decimal places
else // mm
  float val = xData / 100;
  Serial.print(val, 2);  // 2 decimal places
Rob Tillaart
robtillaart
there is a bug in my code, for mm .
it should be
float val = xData / 100.0;  // force a conversion to float.
Rob Tillaart
robtillaart
Quote
Thanks... I tried the new code, but it will send out chaotic numbers occasionally.
If there is noise on the line and a bit flips you will always get strange values.
Do you have a pull up resistor on the data/clock lines?
Rob Tillaart
robtillaart
aauutch my ears hurt!
Please adjust this screaming font
Quote
There isn't anyone smart enough to code leonardo to interface with calipers.
Think the "biggest problem" is that most people don't have an incentive to do so, although I recall a post of someone who did make it work on an UNO.
If you make it a challenge with a good price there will be enough, I'm sure there will be people smart enough.
Rob Tillaart
robtillaart
check this - http://www.instructables.com/id/Reading-Digital-Callipers-with-an-Arduino-USB/ -
what do you think? (please don't shout unless of joy ;)
Rob Tillaart
SESA197434
Hey supertechqc.
Do you have any pictures of the connections from [+, -, data, clock] to the [arduino] and also [foot switch] to [arduino].  Your schematics are great, its just that I do not have any electrical background and cannot make sense of what goes where.  I'd appreciate any pictures that might help dumb it down for me.
Cheers
Sean
