Topic: Sparkfun or Adafruit for arduino? (Read 3429 times) previous topic - next topic
Tryndus
Hey,
just a quick question for those whom know.
What do you consider better and what are your experiances with either the:
Adafruit Wav sheild - http://www.adafruit.com/products/94
or
The Sparkfun mp3 Shield - https://www.sparkfun.com/products/10628
Thanks
-Tryndus
robtillaart
The title of your request does not reflect your question. The words wav /mp3 shield would make it more clear ;)
wrt your question: The word "better" is the tricky one as it depends on the requirements of your project and/or your expectations and budget.
Did you notice one is mono and the other stereo?
So Q1 is: What do you want to do with the shield?
Rob Tillaart
Grumpy_Mike
It is like saying which is best a banana or an orange. The two are not the same things so there is no answer to the question as posed.
xl97
I agree.. to give any feedback.. we need to know more about your project(s), and intended usage..
Do you have a preference between MP3's & WAV files?
I have played with the Waveshield and have experience with it..  but have never played with or used any sort of MP3 module/chip to decode .mp3 files..
I also suggest reading the comments about items from the users.. they usually post good & valid topics that pertain to the item
such as some modules can ONLY play files if they are numbers 1, 2, 3 ,4, 5..etc..etc..  some you can use/pass in a file name..
I found the stock/default Waveshield to be NOT very loud.. (although I read about adding a resistor for a volume hack that might help this)
Waveshield can only play 1 track at a time (can only open 1 file on SD card at a time)..  not sure if others have same restrictions or not..
outline what you plan to do with it might help sway our suggestion one way or another.
mmcp42
I have used the SparkFun board with the on-board and an external SD shield
works a treat with .mp3 files
claims to play .wav files
but isn't very good
there are only 10 types of people
them that understands binary
and them that doesn't
