Topic: Pulldown resistor power requirement (Read 2130 times) previous topic - next topic
firehorse
Hey guys
Yipeeee, I got it working (after 2 bloody hours dammit :))
I am using a 10k resistor to "pull_down" ground as the sensor needs stability
I have a 10k connected now but its 1/4 watt
is 1/2w better in case it gets hot  ?
Yes No ?
I don't know how to calculate power on that 10k resistor
I know I=V/R, but the rest is rocket science to me..
Any thoughts ?
cheeers
fungus
What on earth are you trying to do?
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
pito
P(watt)=I*I*R
So you need 50V on the 10k resistor to dissipate 1/4 watt on it..
fungus
P(watt)=I*I*R
On a pulldown...?
pito
#4
May 24, 2013, 02:29 pm Last Edit: May 24, 2013, 02:31 pm by pito Reason: 1
Quote
Quote
On a pulldown...?
I do not know what firehorse does, but you can have a pulldown 10k resistor with more than 50Volts on it..  :)
Grumpy_Mike
oric_dan
#6
May 24, 2013, 07:59 pm Last Edit: May 24, 2013, 11:22 pm by oric_dan Reason: 1
Edited per Bob:
P = V^2 * R = V * V / R    also works.
P = V^2 / R = V * V / R    also works.
P = 5V * 5V / 10K = 0.0025 watts
To dissipate 1/4W at 5V, R = V^2 / P = 5V*5V/0.25W = 100 ohms.
So, your 1/4W 10K R is cool [literally], for voltages in the range 0..5V.
CrossRoads
little typo there:
P = I^2*R = V^2/R
Comes from P = I*V
V=IR or I=V/R, subbing in for I or V yields the above.
oric_dan
firehorse
Wonderful, now rocket science isn't so bad, Ohms law works really well here
thanks guys
Pull downs are not normal, are you doing things right?
I dunno, it is working for the situation I need
Here's the story:
I have the 10k resistor connected to ANALOG INPUT and ground because of a floating input, when the sensor open circuits,
ie: INPUT goes LOW
Thanks for the link, I tried both pullup & pulldown, both work fine
They say pullup circuits uses less current traditionally but does my hardware need pullup or will pulldown work OK too ?
Just not sure why I would need, to use pullup if that's the case ???
Grumpy_Mike
Ok you never said it was an analogue input.
Quote
No I don't think there is anything in that.
Quote
just not sure why I would need, to use pullup if that's the case ?
You need one or the other but as I said in that page it is a touch safer having a long lead with a ground rather a long lead with power.
CrossRoads
http://www.atmel.com/Images/doc8349.pdf
Atmel uses pullups here as part of power reduction technique.
I think  Nick Gammon also did some testing on this
http://www.gammon.com.au/forum/?id=11497
firehorse
OK, makes sense
thanks for the info
