Topic: Uno only semi works on two of four computers (Read 2077 times) previous topic - next topic
fungus
Used to be that some laptops had weaker USB ports.  Might check the supply voltage to the board to make sure they are getting enough voltage?
I agree and that's what I thought too.  But then when connecting a external 9V battery to the Vin pin, should this not have fixed the problem?
Nope. A 9v battery probably supplies a lot less current than a USB port.
OTOH if you're outputting enough current on an I/O pin to cause problems then that pin isn't going to last very long.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
