Topic: Basic HTTP authentication (Read 3648 times) previous topic - next topic
s1nringleader
Hi this my code trying to make a basic http authentication. I only need guidance on what is the problem. I have highlighted the problem in my code which is the substring. Any help is appreciated. Please If you can help me finish my project.
Thank you
#include <SPI.h>
#include <Ethernet.h>
#include <WebServer.h>
#include <String.h>
byte mac[] = { 0x00, 0x09, 0x34, 0x15, 0x18, 0xEA }; //physical mac address
byte sampledata=50;            //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin1 = 2;  // LED pin 1
int ledPin2 = 3;  // LED pin 2
int ledPin3 = 4;  // LED pin 3
int ledPin4 = 5;  // LED pin 4
int ledPin5 = 6;  // LED pin 5
char m_authCredentials[51];
boolean auth_page=false;
boolean authorised = false;
unsigned char m_pushback[32];
char m_pushbackDepth;
char pc;
String user_auth = String(250);
EthernetServer server(80);
EthernetClient client;
String readString = String(32); //string for fetching data from address
boolean LEDON1 = false; //LED status flag
boolean LEDON2 = false;
boolean LEDON3 = false;
boolean LEDON4 = false;
boolean LEDON5 = false;
void push(int ch)
 // don't allow pushing EOF
 if (ch == -1)
   return;
 m_pushback[m_pushbackDepth++] = ch;
 // can't raise error here, so just replace last char over and over
 if (m_pushbackDepth == SIZE(m_pushback))
   m_pushbackDepth = SIZE(m_pushback) - 1;
bool expect(const char *str, EthernetClient aclient)
 char c;
 boolean auth_str = false;
 int size_of_str = strlen(str);
 Serial.println(str);
 Serial.println(size_of_str);
 while (auth_str == false)
   if ((aclient.available()) && (aclient.connected()))
     Serial.print("\nClient available\n");
     user_auth="";
     while ((c = aclient.read()) != '\n')
       if (user_auth.length() < 250)
         //Serial.print(c);
         user_auth.concat(c);
         //Serial.println(user_auth);
============PROBLEM AREA============================================
     user_auth.trim();
     Serial.println("Substring");
     Serial.println(user_auth.substring(1, 14));
     if (user_auth.substring(1, 14) == str) {
       Serial.print("\nSubstring found");
       auth_str = true;
       user_auth[0]=0;
 return false;
void readHeader(char *value, int valueLen)
 int ch;
 memset(value, 0, valueLen);
 --valueLen;
 // absorb whitespace
 do
   ch = client.read();
 } while (ch == ' ' || ch == '\t');
 // read rest of line
 do
   if (valueLen > 1)
     *value++=ch;
     --valueLen;
   ch = client.read();
 } while (ch != '\r');
 push(ch);
bool checkCredentials(const char authCredentials[45])
 char basic[7] = "Basic ";
 if((0 == strncmp(m_authCredentials,basic,6)) &&
    (0 == strcmp(authCredentials, m_authCredentials + 6))) return true;
 return false;
void setup(){
//start Ethernet
 Ethernet.begin(mac);
 server.begin();
 // disable w5100 SPI while starting SD
 pinMode(10, OUTPUT);
 digitalWrite(10, HIGH);
//  Serial.print(F("Starting SD..."));
//  if(!SD.begin(4)) Serial.println(F("SD failed"));
//  else Serial.println(F("SD Ok"));
 Serial.print(F("Starting ethernet..."));
 if(!Ethernet.begin(mac)) Serial.println(F("Ethernet failed"));
 else Serial.println(Ethernet.localIP());
 // give the Ethernet shield a second to initialize:
//Set pin 4 to output
 pinMode(ledPin1, OUTPUT);
 pinMode(ledPin2, OUTPUT);
 pinMode(ledPin3, OUTPUT);
 pinMode(ledPin4, OUTPUT);
 pinMode(ledPin5, OUTPUT);
//enable serial datada print
void loop(){
// Create a client connection
 if (client) {
   while (client.connected()) {
  if (client.available()) {
   char c = client.read();
   //read char by char HTTP request
   if (readString.length() < 32)
       //store characters to string
       //-----readString.append(c);
         readString.concat(c);
         pc = c;
       //output chars to serial port
//        Serial.print(c);
       //if HTTP request has ended
       if ((c == '\n')) {
         // Print on serial port what we collected
         Serial.println(readString);
         // If the user is NOT authorised then send
         // authorisation message
         if ((authorised == false)&& (auth_page == false))
             Serial.print("\n*** Sending Page");
             client.println("HTTP/1.1 401 Authorization Required");
             client.println("Server: HTTPd/1.0");
             client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
             client.println("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01 Transitional//EN\"");
             client.println("\"http://www.w3.org/TR/1999/REC-html401-19991224/loose.dtd\">");
             client.println("<HTML>");
             client.println("<HEAD>");
             client.println("<TITLE>Error</TITLE>");
             client.println("<META HTTP-EQUIV=\"Content-Type\" CONTENT=\"text/html; charset=ISO-8859-1\">");
             client.println("</HEAD>");
             client.println("<BODY><H1>401 Unauthorized.</H1></BODY>");
             client.println("</HTML>");
             client.println();
             Serial.print("\n*** Page Sent, Expect Authorisation ");
             auth_page = true;
         else if((authorised == false)&& (auth_page == true))
             if(expect("Authorization:", client))
               // User has sent username and password aG9tZTpzZWN1cml0eQ==
               readHeader(m_authCredentials,51);
               //if WEBDUINO_SERIAL_DEBUGGING > 1
               Serial.print("\n*** got Authorization: of ");
               Serial.print(m_authCredentials);
zoomkat
You might be running out of memory. Try putting all the static html strings in the F() macro.
s1nringleader
I don't think so but I don't know why the highlighted part is being read by my arduino. Any other ideas? is my code correct?
