Topic: 1 megabit SRAM for SPI or parallel interface. (Read 6208 times) previous topic - next topic
GoForSmoke
I saw a link to this while surfing for solutions to something different.
http://www.vlsi.fi/fileadmin/news/PressReleaseVS23S010.pdf
Quote
The VLSI Solution VS23S010 is an easy to
use one megabit static RAM device. The
memory can be accessed via a standard SPI
compatible serial bus (1, 2 and 4-bit modes),
or via an 8080-type 8-bit parallel bus similar
to nand flash devices.
One of the main applications for the
VS23S010 is microcontroller RAM extension.
Internet streaming applications, which are
becoming increasingly popular, will benefit
from the large buffer memory provided by
VS23S010. For an example of usage, please
see VLSI's internet streaming presentation at
http://www.vlsi.fi/fileadmin/presentations/vlsi/Internet_streaming.pdf .
That's a pretty big bucket to not have the occasional holdups that SD will get.
They don't have them in the store and the request engineering samples gets 404'd.
But the target quantity price is .99 Euros.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
graynomad
Hmmm, interesting chip. Now I'm trying to think of a use for it :)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
GoForSmoke
It could make a nice SPI buffer or even set of buffers.
Suppose it could fit between MCU and SD?
CrossRoads
How would it fit in between? Don't you need the MCU to  control the SPI lines? So you're still stuck with one or the other.
Maybe if you had two microcontrollers and a dual port SRAM, or a large FIFO chip - one parts reads data and writes it to the memory, the other pulls it and writes it to the SD card.
Cypress carries dualport SRAMs, I didn't dig in to see if any have serial interfaces. If parallel, then you'd probably need a few shift registers/part to hold the address & data while writing, or to hold the address and then capture the data while reading.
GoForSmoke
Or a data server module with dedicated MCU, SD and RAM buffer that would always take in data and write to the SD when it's ready, keep pages buffered for quick re-access.
Something like the DEC Rainbow drives? I only ever heard of those shortly though.
Every so often I see a project idea that got thwarted because of SD delays, but not even every month. Usually the solution is do it a different way or use bigger hardware.
As it is, I have 64k bit SPI SRAMs I haven't had more than a mess-with use yet. Got a
couple 256k's but they're surface mount which for me they might as well be on the moon.
Coding Badly
Someone (Microchip?) sells RAM battery backup chips (similar to the battery backup for RTCs).
With a battery backup the VS23S010 would make a nice SD card or EEPROM replacement.
CrossRoads
Could also use FRAM chip, then no battery is needed.
I should work on that FRAM shield I keep thinking about.
Too bad the chips are pricey, ~$12 for 128K x 8
http://www.mouser.com/Semiconductors/Memory/_/N-488qu?Keyword=fram+memory&FS=True
GoForSmoke
CB: I hadn't thought of that. It's DRAM that sucks more power just staying on and refreshing, isn't it?
CR: Cool stuff! Give it 3 years and the price will be down, or are things moving faster now? At first when I saw the name Ferroelectric RAM I thought "New age core?". Too bad, not really.
graynomad
You can get 64kx8 FRAMs for about $2.50-5.00, maybe that's the sweet spot price wise at present.
______
Rob
CrossRoads
#9
May 24, 2013, 06:54 pm Last Edit: May 24, 2013, 06:57 pm by CrossRoads Reason: 1
Those prices are too low Rob - 8kx8 might be that low, but 32Kx8, 64Kx8m 128Kx8 are all more.
You can find 2V16Kx8 for < $5, anything larger is more.
At mouser.com anyway.
Last time I checked, they had much better selection than Digikey too.
Coding Badly
I have no idea.  It's been too long since I needed to know that stuff.
GoForSmoke
You're lucky enough to have ever -needed- to know. I hope the work was interesting!
graynomad
Quote
stack overflow imminent.
DRAMs do need constant refreshing, but whether or not they use a lot more power because of it I don't know.
Bob, yes you're right, I missed the "kb" thought it was "kB".
______
Rob
