Topic: Close keyboard contacts from Arduino (Read 2191 times) previous topic - next topic
xovez
May 26, 2013, 03:12 am Last Edit: May 26, 2013, 01:59 pm by xovez Reason: 1
Hi!
I need to control a system wich have a keyboard from Arduino, simulating the push of its keys.
How can I close the contacts of the keys from Arduino? Using an optocoupler?
I do not know if I can use an optocoupler, and if where possible, wich model to use.
Note: I measured that when I push a key in the keyboard, its contacts aren't closed with a 0 Ohm resistence, but they are closed with about 55-75 Ohm.
Any ideas? schematics? Has anyone tried it?
PD: I attach a picture the keyboard contacts
Thanks!
Osgeld
what voltage is the device
could use a transistor, collector on non common pad, emitter on ground, 1k to base with the arduino on the other side
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
xovez
Thanks Osgeld
The device voltage is about 3.5v - 5v.
You suggest a simple NPN ? like a 2N2222???
The common pad is not ground. The pads make a matrix with common on columns and rows (like the attached image).
Your suggested solution can work properly anyway?
CrossRoads
Or a bunch of little relays. Here's a 1284 driving 15 relays, design had 18 originally, 3 were removed for some other expansion.
USB and RS232 interfaces.
xovez
Thanks CrossRoads for your suggestion. Simple to develop, but my circuit must be installed inside other device and I haven't space to place about 14-15 relays :)
I readed the datasheet that sais Telecommando, the CD4066. Seems an interesting solution, but for simplicity and availability of components in my city, I prefer using a few simple optocoupler. Do you know any recommended model? Can it be a valid 4N35 or TIL116?
Thanks!!!
Osgeld
given your image you could do it with 16 transistors, theres a common ABCDE and 1234
given the jack squat current configurations for this type of layout you could accomplish it with a transistor array in a dip format
