Topic: BitVoicer for Arduino Due (Read 1 time) previous topic - next topic
I have setup BitVoicer Speech Recognition using computer to capture voice then send commands via COM port to Arduino Mega2560 and Ethernet Shield to send http commands to control my home automation system. It works great without problem except SRAM is closing its limit. Now I change it to Arduino Due but I found a lot of compiler errors in BitVoicer11.cpp. Does anyone get around it on Arduino Due? Thanks.
Jul 18, 2013, 05:01 am Last Edit: Jul 18, 2013, 05:02 am by msb4180 Reason: 1
The BitVoicer11 library does not support the Due board. The Atmel microcontroller on this board has a completely different set of registers, so you will need to redesign the library.
Maybe add the 512k external RAM module from Rugged Circuits.
The new BitVoicer Server has  libraries that work with the DUE board. Unfortunately, the new libraries do not work with the old BitVoicer.
