Topic: digitalWrite bug in Arduino Mega 2560 (Read 2762 times) previous topic - next topic
porlune
May 28, 2013, 07:04 am Last Edit: May 28, 2013, 09:20 am by Porlune Reason: 1
On my newly purchased Arduino Mega, using pinMode(11, OUTPUT); then digitalWrite(11,LOW); will set pin 11 to a HIGH value. (and vice versa).
Not supposed to do this right?
CrossRoads
setPin(11, OUTPUT);
Why are you using that instead of
pinMode (11, OUTPUT);
CrossRoads
I've not seen setMode before, only pinMode.  Try that.
http://arduino.cc/en/Reference/HomePage
http://arduino.cc/en/Reference/PinMode
porlune
Bug in my Arduino MEGA 2560:
  // initialize the digital pin as an output.
  Serial.println(PORTB);    //prints 0
  pinMode(led, OUTPUT);
  bitClear(PORTB, 5);      //turns ON led connected to pin 11
This must be a bug.. A pin should not drive an LED when it is cleared.
Carlmikael
Grumpy_Mike
#5
May 28, 2013, 10:53 am Last Edit: May 28, 2013, 01:58 pm by Grumpy_Mike Reason: 1
It will if it is wired for current sinking rather than current sourcing
Anyway why are you using direct port manipulation to turn on an LED? What is wrong with the normal digitalWrite?
Are you counting the bits from zero not one?
porlune
would you mind explaining more about what you mean by: "It will if it is wired for current sinking rather than current sourcing". Would be greatly appreciated! thank you!! :D
SurferTim
One lead of the LED is connected to D11. Where is the other end of the LED/resistor connected? Is it connected to 5v (current sink) or ground (current source)?
If the anode of the LED/resistor is connected to 5v and cathode to D11, it will light when D11 is LOW.
If the cathode of the LED/resistor is connected to ground and anode to D11, it will light when D11 is HIGH.
cmiyc
#8
May 28, 2013, 02:34 pm Last Edit: May 28, 2013, 02:35 pm by James C4S Reason: 1
This is not a bug because no body else has ever reported this issue.
It is more likely the behavior of the pin is different from what you expect.  So let's look at your code.
If the cathode of the LED is connected to the pin (through a current limited resistor) and the anode is connected 5V, this could turn on the LED.
This is, of course, assuming that "led" is set to 11.  That part is missing in your code.  Which is troubling.  You're describing a behavior that nobody else experiences but you have yet to:  a) explain exactly how your hardware is connected and b) post proper code.
porlune
Thank you James C4S! That explains a lot :)
